Old 09-23-2021, 06:56 AM   #10865
Bearded_Seamonkey
Bearded_Seamonkey's Avatar
Drives: 2022 ZL1 1LE
Brought my 2022 Red Hot ZL1 1LE home!!!!
1972 Chevy Nova
Sold: 1997 Z28 Camaro
2000 Corvette
Bearded_Seamonkey is offline   Reply With Quote
Old 09-23-2021, 07:03 AM   #10866
jamala00
jamala00's Avatar
Drives: 2016 Camaro 2SS Hyper Blue Metallic
Very nice. You guys that have lifts in your personal garage.... So Jealous...
jamala00 is offline   Reply With Quote
Old 09-23-2021, 07:06 AM   #10867
KILLA BEE
Black lightning
KILLA BEE's Avatar
Drives: 2021 ZL1 1LE A10
Originally Posted by jamala00 View Post
I contacted the manufacturer of the ceramic coating that was put on my bike because it was put on every part of my bike. Plastic, Plexiglass windshield, etc... I mainly contacted them because part of my bike is demin paint and I wanted to be sure it wouldn't leave it shiny. That is why I posted what I did. There exact response was that it is perfectly fine to put it on everything, but it's formulated to bond to clear coat, so all though you can put it on everything, depending on the surface it won't last long. Their words... Not mind...
If I decide to ceramic coat my car, it will also get put on everything since it won't hurt anything.
[ 2021 Camaro ZLE 10 speed
KILLA BEE is offline   Reply With Quote
Old 09-23-2021, 07:09 AM   #10868
KILLA BEE
Black lightning
KILLA BEE's Avatar
Rain shouldn't be an issue, it is the minerals in the ground water from the sprinklers...
Wouldn't nobody get it if rain messed it up damn, you cant beat mother nature lol
Old 09-23-2021, 07:14 AM   #10869
KILLA BEE
Black lightning
KILLA BEE's Avatar
Originally Posted by Chevelle vs Camaro View Post
Ceramic coating is basically Glass (sio2). Absolutely will work on glass and have decent durability. Except windshield due to wipers.
There are even dedicated glass sio2 coatings. Most likely relabeled coatings.
Most rain won’t leave spots like ground watet unless it has a high mineral content.
And I gotta say it's been raining and the water is beading up like it's sitting on cryptonite, then dries like it never rained WOW I would definitely recommend
Old 09-23-2021, 07:40 AM   #10870
Bearded_Seamonkey
1972 Chevy Nova
2000 Corvette
Old 09-23-2021, 08:04 AM   #10871
jamala00
jamala00's Avatar
That's a pretty nice collection of cars in there. Very nice!
Old 09-28-2021, 12:31 AM   #10872
JamesNoBrakes
JamesNoBrakes's Avatar
Drives: 2SS 1LE
Got ahold of some used-for-one-season Toyo studded winter tires (255/40R19) to replace my old worn non-studded winter tires! I have the same tires in 255/40R18 for my other car and they are outstanding. Finally be able to drive it a bit in the ice and snow.
2018 2SS 1LE
2023 Colorado ZR2
2022 Stinger GT-line AWD
JamesNoBrakes is offline   Reply With Quote
Old 09-28-2021, 06:18 PM   #10873
craigss50
craigss50's Avatar
Drives: 2017 Camaro SS Fifty
My car is 5 years old now so I did a coolant system flush with Prestone DexCool concentrate for GM. Got 1 gal unmixed at Walmart for $17.95 and 1 gallon distilled water for .99. Mixed it to 50/50 myself. So many bolts to remove the belly pan to get to the drain. That was the most time consuming part. I also had to remove the strut tower brace (convertible) which was easy, just 4 bolts to fill the smaller tank hole. I did not know there were 2 fill caps for the reservoir (one large and one very small) upper and lower tank. Did a YouTube to be sure to burp it properly as I had air in the system when I did a fluid flush in my previous C5 Corvette and it overheated after doing the flush. I only got about 6 qts out not the 10 qts that is the system capacity without additional coolers since I have a convertible. I drove it around and drained another 3 qts out and refilled. In the old days you drained and ran water through with a garden hose with the engine running to flush and get the old fluid out of the engine then refilled with antifreeze but I did not see this method being used now so I did it the YouTube way. Good for another 5 years now.
craigss50 is offline   Reply With Quote
Old 09-28-2021, 10:58 PM   #10874
2SS Capt
2020 Shadow Gray 2SS
2SS Capt's Avatar
You should be good! I remember the old days buying the Prestone kit with the T fitting to hook the garden hose to, it definitely got all the old coolant out, but you ended up putting a bunch of very high mineral water into your system... Haven't done that since the late 90's... I think what you did is the way to go, drain what you can and refill with a 50/50 of the factory grade coolant and distilled water, it'll keep your system as healthy as possible... If you really want to be anal about it, do the first drain and fill, drive it 20 miles then do another drain and fill, you'll probably get close to a 75% "refresh" on the fluid... Anything beyond that would be a waste of resources and money...
Old 09-29-2021, 04:48 PM   #10875
JamesNoBrakes
Drives: 2SS 1LE
These tires sing the song of my people.
2018 2SS 1LE
2023 Colorado ZR2
Old 09-29-2021, 05:47 PM   #10876
hotlap
hotlap's Avatar
Soon …my car will sing the song of winter too.
Thanksgiving to April 1st
Ronald Reagan -
Old 09-30-2021, 01:06 AM   #10877
ZachU
ZachU's Avatar
Installed AEM wideband, Powerstop drilled and slotted rotors & pads, and relocated the Aeroforce to the pillar. New tires on the front also.
2017 Camaro 1SS
Procharger P1X Stage 2 intercooler
ZachU is offline   Reply With Quote
Old 09-30-2021, 05:30 AM   #10878
jamala00
jamala00's Avatar
Studded tires hey...(or at least it looks like they are) I didn't even know those were made, but I also didn't realize you could use them on public roads. I just looked in WI and they are illegal except for certain emergency vehicles.
