Old 09-10-2017, 10:13 AM   #1065
17CamaroZL1
Life's Short, Live Fast!
17CamaroZL1's Avatar
great pass zl1 and great to meet you too.
Thanks! Wish I could've ran again or had a do over on that one. Lol! For some reason my stability control light wasn't coming on as I was lining up to run. I tried everything, even turning off the car for a second. I tried going into PTM and it still wouldn't come on, nor go into PTM. I was thinking it would shut me down once it started spinning and getting sideways, but surprisingly it didn't. The problem was, I accidentally deep staged. Thought about throwing it in reverse real quick, but I knew the lights were about to come on, so I didn't. I didn't think it would make that big of a difference, but I really think it may have knocked me out of a possible 10.
The car felt like it hooked the best it did all day (only 3 passes, but) and my first pass had a 1.72 60', and that last pass felt better than that, so I guess it was the deep stage that killed my 60' and therefore hurt the rest of my run. If the car actually did launch better and would've cut another low 1.7, I'd been looking at a high 10 and probably 128 or 129 mph. Lesson learned. I should've just chanced the lights coming on and backed up and launched it. I tried to hotlap it to get another shot at it, but they said I only got one pass that round and that I was done for the night.
12/26/2016 Ordered!
2/8/2017 Built!!
3/2/2017 Brought Home!!!
Old 09-10-2017, 10:20 AM   #1066
17CamaroZL1
Originally Posted by KyWildcats View Post
Tires used on the pass: Hoosier 28x10 17 slicks
Transmission - M6 STICK SHIFT
Performance Mods (if any): CAI, PTB, Ported MSD IM, Cat Delete, E85, drag pack, Tune
Category submitted for: Please List the Category - Category #3 Bolt on no internal mods (stock displacement)
R/T.......... -.173
60'............. 1.778
330'........... 4.895
660'........... 7.436
660’ mph... 97.059
1000'.......... N/A our track doesn't have a 1000' sensor
1320'.......... 11.460
1320’ mph… 120.688
Name of the track: Mountain park drag way Clay City, Kentucky
Date of pass: 9-8-17
Nice pass!! What did the DA get to a Clay City
12/26/2016 Ordered!
2/8/2017 Built!!
Old 09-10-2017, 01:14 PM   #1067
PRAY
PRAY's Avatar
Drives: 2016 2SS
Track was complete junk and I couldn't launch the car or keep it from spinning every shift down the track. There was a lot left in it. We will never know though. And yes I know the date and times are wrong. Every slip I have ever posted has the same date on it. It is what it is.
Tires used on the pass: 28" 305/45/17 MT ETr's
Transmission - A8
Performance Mods (if any): CAI, PTB, Ported MSD IM, Ported Heads, 2" Kooks, E85, drag pack, Tune
Category submitted for: Please List the Category - Category #4 since I have heads but no cam.
R/T..........
60'............. 1.513
330'........... 4.446
660'........... 6.881
660’ mph... 101.44
1320'.......... 10.76
1320’ mph… 126.90
Name of the track: Fayetteville MSP
DA +1,100
Old 09-10-2017, 01:21 PM   #1068
17CamaroZL1
Transmission - A8
Category submitted for: Please List the Category - Category #3 Bolt on no internal mods (stock displacement) or Cat #4 since I have heads but no cam.
R/T..........
660’ mph... 101.44
1320’ mph… 126.90
DA +1,100
Attachment 896011
Awesome runs! Looks like very good 60s for a junk track.
12/26/2016 Ordered!
2/8/2017 Built!!
Old 09-10-2017, 01:36 PM   #1069
PRAY
PRAY's Avatar
Drives: 2016 2SS
This car always 60fts at this track from 1.46-1.48 and dead hooks under full power. I couldn't leave with any application of power this time. The car would just spin. With the 4C converter, if you spin 1st it will short shift the 1/2, hit the limiter on the 2/3 and 3/4 due to the converter not locking. It also spun every shift down the track. I never got one clean pass in the entire night. The passes I would leave super soft and get it to sort of hook it would either spin once I was out or spin bad on the shift. Not having the converter lock just before or during the 2/3 shift kills MPH big time. The car had 10.60's in it at 128 I feel.
Old 09-10-2017, 04:47 PM   #1070
17CamaroZL1
So is the converter not locking an issue you've been having or related to the spinning and short shifting, which is how I'm reading that? I know a guy with a 9 second Mustang that was telling me how it screws up the shift logic on his car if it spins. I hadn't heard of that before.
12/26/2016 Ordered!
2/8/2017 Built!!
Old 09-10-2017, 05:19 PM   #1071
PRAY
PRAY's Avatar
Drives: 2016 2SS
So the converter won't lock prior to 6,400rpm or 60mph (unlocked) in 2nd gear no matter what. I am pretty sure that is where I lost the mph I did with the converter over the stock converter. The stock converter is basically locked by 3K in first no matter how you try to set it up. The 4C only locks if I have traction from the hit. If I spin, it won't lock till 4th. The problem is that the converter is so loose, to do it's job, that I had to drop 5-7mph out of my 1/2 and my 2/3 shifts as to not hit the limiter which is set 500rpm over the shift points. With the stock ported IM on there it wouldn't lock till after the shift to 3rd. With the MSD, it wants to lock right at the top of second which is very hard to tune for due to the huge mph difference for shifts between locked and unlocked. So now I have to battle with 1mph increments and for the lock up and drop the shift mph by 1 each time so it locks at the very top of 2nd or in the shift. If it hits 3rd not locked up it drags for quite some time before it locks.
I hope all of that made sense.
Old 09-10-2017, 10:25 PM   #1072
17CamaroZL1
Yes. Thanks. It all makes sense, except I can't wrap my head around why spinning or not, determines if it locks for you or not. It sounds like you are so tight on the lock point and running out of engine speed, it makes it tough no matter what. That would definitely be a mph killer going from a locked converter to one that doesn't. Hope you get it all sorted out. It's still one bad ride either way.
12/26/2016 Ordered!
2/8/2017 Built!!
Old 09-11-2017, 12:23 AM   #1073
bhillakaiceberg
bhillakaiceberg's Avatar
Drives: 2011 2SS/RS & 2017 1SS
To my understanding, I do not think Ported Heads have ever been considered "Bolt Ons."
Utilizing Ported Cylinder Heads moves us to Category #4.
2011 Chevrolet Camaro 2SS/RS L99 (1 of 782)
10.78 @125mph ALL MOTOR SBE
Built/Tuned by Me
2017 Chevrolet Camaro 1SS Auto
9.29 @144.57mph ALL MOTOR SBE
#TEAMGPI Gwatney Performance Innovation
bhillakaiceberg is offline   Reply With Quote
Old 09-11-2017, 02:59 AM   #1074
Bo White
Bo White's Avatar
Drives: 2015 Summit White 2SS 1LE
Imo if it touches engine oil or a power adder its not a bolt on
Retired wanna be cylinder head porter
2015 2SS 1LE Clutch reservoir, Vararam DRX, ported TB, TSP 2" headers, MGW shifter, stage 4 cam and Wilkes 11° 65cc heads
Totalled:
2010 1SS Wilkes Performance/Eagle 416 shortblock, TSP custom valvetrain, PRC 260 heads, Edelbrock Pro Flo 102, th400 swap, 8" PTC 5500 stall= 535/435 at the wheels tuned Gen 3 Performance and Dyno 10.97 @ 124 full weight in 3100 DA CamaroFest X
Bo White is offline   Reply With Quote
Old 09-11-2017, 05:51 AM   #1075
Rhino79
Rhino79's Avatar
Drives: 2010 Camaro SS L99/Auto
That is exactly right. That's how's it's been since the ls1 days.
Rhino79 is offline   Reply With Quote
Old 09-11-2017, 06:00 AM   #1076
PRAY
PRAY's Avatar
Drives: 2016 2SS
Whaaaaat, heads are not a bolt on. That's crazy. I didn't go internal to the short block and I just bolted them on. Took less time than the headers. I thought you three would have my back on this one. LOL. I have been saying from the start that heads shouldn't be considered a bolt on. I even put in my past Category 4 since I have heads. Just no one confirmed that and I have heard some in conversation say they should be considered a bolt on, which I don't agree with. Category 4 is fine with me. Merc won't count my slips anyway so it doesn't really matter. I need to get to another track to get this thing to hook and get one complete pass and have a time slip that meets the standards.
Old 09-11-2017, 11:59 AM   #1077
Merc
In The Circle
Merc's Avatar
With the C5 lists we allowed porting of the TB and Intake manifold but not the heads. Same rules apply in C6 as C5.
Old 09-11-2017, 12:02 PM   #1078
Merc
In The Circle
Merc's Avatar
Fall is here now and things have slowed down for me. Over the next week I'll start working on bringing the C5 and C6 lists back up to date. I hope all my fellow Camaro Friends in the Gulf and Florida regions are all safe and sound.
