#10711 |
![]() ![]() ![]() Drives: 2020 Camaro ZL1 Join Date: Oct 2020
2020 ZL1 A10 Shadow Gray Metallic
Magnuson Magnum DI TVS2650R| Mamo Throttle Body V2| RotoFab Intake| AWE Touring Catback Exhaust| TCM Tune| Tune| Eibach Pro| BMR Rear Cradle Lockout| PPF| Ceramic| BCForged HCS21 |
#10712 |
![]() ![]() ![]() ![]() ![]() Drives: 19' ZL1 A10, w/pdr Join Date: Sep 2014
Replaced engine cross braces with refurbished and painted new ones.
BTR Stg II cam w/ 38% fuel lobe, ARH 2" headers into 3" w/cats, Kong X port, Weapon X triple ht exchangers, NW 103, Rotofab big gulp, DSX lowside, TCM tune, BMR Lockout, Mustang dyno 720 rwhp, 634 rwtq on 93 pump.
#10713 |
Drives: '21 Wild Cherry ZL1 Join Date: Aug 2018
It does look nice. Let me fix em for ya. |
#10714 |
#10715 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 20 1LE 2SS M6 Rally Green Join Date: Mar 2014
Xpel is worth the money regardless of how often you drive your car.
The film will absorb 99.9% of the stone hits. Occasionally, it will get a slight nick. My 13 ZL1 got a 3/8" gash on the front fender but the paint was not harmed. The ppf did its job. You can drive without fear and the ppf can be replaced. Your original paint stays perfect and you can't tell the ppf is there if applied by a pro.
"the trouble with our liberal friends is not that they're ignorant; it's just that they know so much that isn't so.” Ronald Reagan - |
#10716 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: like an old lady Join Date: Jun 2012
i put myself through the ppf debate. ultimately i decided
1) the car is not and never will be a show/collector car 2) the original gm paint is cheap & simply terrible 3) once i get tired of the rock chips ill repaint with quality products and then ppf it i refuse to spend very much money trying to protect the worst paint in automotive history what did i do to my camaro today (technically yesterday)? it competed its second long haul hot rod power tour, although this years tour was just a little guy.
#10717 |
雪の玉
Drives: '22 Z71 RST Silverado Join Date: Feb 2011
Got left front rim damage fixed and back on the car.
#10718 | |
I've spent $20k on paint ...for a show car. ![]()
#10719 | |
#10720 | |
![]() Drives: 22 Camaro 2SS, 20 Subaru Crosstrek Join Date: Aug 2021
Your only real solution is to remove the damaged piece entirely and replace it.
Earth is an oblate spheroid
2022 | 2SS | M6 | NPP | Summit White | Carbon Flash Wheels | Black Lugs | Red Calipers | Adrenaline Red | Red Knee Pads | Nav | - 1100 - 8/16/21 - 3000 - 9/21/21 - TPW 10/18/21 - 3400 - 10/1/21 - 3800 - 10/20/21 - built 10/19/21 - 5000 - 11/12/21 - 6000 - 11/13/21 |
#10721 | |
That gash happened early into my first Xpel job. When I showed it to the installer, he said "the ppf did its job". The paint wasn't damaged. Based on the size and shape of the gash, whatever it was had mass and a sharp edge.
#10722 |
D3RPZILLA
Yes.. Probably can install without doing so but removing them gives you more room to work and you can adjust everything easier.
Website: z1lla.com | YouTube: youtube.d3rpzilla.com YouTube Playlists: Performance Mods | Interior & Exterior Mods | Other Mods |
#10723 | |
![]() Drives: SS 1LE, 89 TTA, 91 GTA, 91 Formula Join Date: Jul 2019
I was at Indy and Champaign sections, were u the guy with the 18(i think) 1LE and bolt on mods and E85 I talked to? I had my crush orange 21 1LE there with me. |
#10724 |
D3RPZILLA
Last night I installed a couple more pieces of carbon fiber to the interior... window switch trim cover as well as carbon fiber door trim surround cover...
![]() And a quick comparison (top is a stock photo but shows the OEM interior)... ![]()
