Old 11-08-2015, 01:06 PM   #10501
menendez1293
Emerald Coast Camaros
menendez1293's Avatar
Drives: 2010 Camaro 2LT/RS M6
Originally Posted by Tricksta View Post
you need a tune.
I mean a tune wouldn't really help a manual trans with the issue he is describing.
Sent from my Nexus 6 using Tapatalk
Old 11-08-2015, 02:03 PM   #10502
xc_SS/RS
Drives: 2010 Camaro SS/RS
Originally Posted by CamaroDreams76 View Post
How so? Lol
Have you changed your trans fluid? Seems really odd how you get locked out of third when the trans gets warm/hot.
2010 2SS/RS
Z/28 intake, NW, FAST 102, speed engineering LT's, some exhaust, ATI -10% pulley, GM flex fuel injectors, DSX flex fuel sensor, MGW shifter, HP Tuners, some suspension work, stickers and a little weight loss. 12.63 @113.53
xc_SS/RS is offline   Reply With Quote
Old 11-08-2015, 02:13 PM   #10503
rebelyell22
rebelyell22's Avatar
Drives: 2011 SIM 2SS/RS LS3
Put redline d4 in it
2011 2SS/RS built 8/24/10
rebelyell22 is offline   Reply With Quote
Old 11-08-2015, 03:14 PM   #10504
CamaroDreams76
Tri-County Camaro SWFL
CamaroDreams76's Avatar
Drives: 2013 IOM 2SS/RS/1LE
It's the plastic release bearing these cars come with. The clutch is pushed on the floor and its as if the clutch isn't even pushed in at all. So 3rd grinds really bad and won't go in gear and after about 3-4 pushes it'll go in gear....clutch is on the floor the entire time. I'm just waiting for that bearing to melt to get a monster billet bearing.
Car is on factory tune, factory trans, brake/clutch fluid. 29000miles
CamaroDreams76 is offline   Reply With Quote
Old 11-08-2015, 03:47 PM   #10505
rebelyell22
1-2 is the one that sucks on mine
Old 11-08-2015, 05:15 PM   #10506
CamaroDreams76
Mine was always fine up until a year ago or so. I went to wannagofast in ocala and that's when I noticed my car was locking out 3rd. Only happens when I the trans temp is high. The aux gauge is at 180 when it happens. So much for the ZL1 trans cooler the 1LE comes with.
Old 11-08-2015, 08:18 PM   #10507
Tricksta
Tricksta's Avatar
Drives: 2018 ZL1 A10
180 isn't high for trans temp though :/
Modifications
GM Dark Tail Lights / 3rd Brake Light & Reflectors | LED Reverse Lights | Diode Dynamics Side Markers | Borla "ATAK" Cat Back Exhaust
Tricksta is offline   Reply With Quote
Old 11-08-2015, 08:54 PM   #10508
CamaroDreams76
That's what the aux gauge said. No clue what the actual temp is or the fluid temp. I've read somewhere on here that those gauges arnt 100% accurate, they are based off an algorithm from different readings of things.
Old 11-08-2015, 09:26 PM   #10509
xc_SS/RS
Thats really weird how you have issues with the trans temps. What are the oil temps at that time as well? Curious if those temps would have an impact or maybe the coolant. I think the trans cooler goes through the radiator.
2010 2SS/RS
Old 11-08-2015, 09:37 PM   #10510
CamaroDreams76
I have no clue. I only monitor a few things on my scan gauges (ignition advance, oil pressure, IAT, knock retard) and then the aux gauges only are those 4 things (oil pressure, voltage, oil pressure, trans temp) didn't even think about looking at coolant temp or oil temp. I know my IATs were typically 120 after sitting in the staging lane. After hot lapping the car i saw 152 IATs because i sat in tbe staging lane for 20 min. I've never seen the trans temp and gauge read past 180.
The 3rd gear lock out happened on my final run. Which was my 4th run. The car sat at least 2 hours to cool down. Probably wasn't really cooling down though......
Old 11-09-2015, 09:42 AM   #10511
racergirl
racergirl's Avatar
Drives: 2014 Red Hot 2SS/RS A6 Camaro
Mondays are evil
Current Camaro: 2014 2SS
Performance Mods: BBK Headers, Borla S type axle back, tune, TSP Stage 1 cam, Vararam Intake, DR's
11.77 @ 119.21
Former Camaro: 2013 2LS
BONE STOCK: 13.953@100.77 With Bolt-Ons: 13.646@101.60
With 75 shot and Bolt-Ons: 12.587@111.25
Performance Mods: CAI Intake, MRT V2, SLP Underdrive Pulley, DRs, Skinnies, Rear seat delete
racergirl is offline   Reply With Quote
Old 11-09-2015, 11:09 AM   #10512
Linker239
Linker239's Avatar
Drives: 2022 WC 2SS
Originally Posted by racergirl View Post
Mondays are evil
Amen to that.
Current 2022 Wild Cherrry 2SS; Recaros, NPP, 5 Split Spoke Polished Rims, Satin Black Package
Ordered 7-11-2023 1100: Riptide Blue 2SS, Not Built
2023 Red Hot 1LT RS V6; Sold
2010 VR 1LT RS; Sold
Linker239 is offline   Reply With Quote
Old 11-09-2015, 11:59 AM   #10513
hrpiii
AKA "Beefcake"
hrpiii's Avatar
Drives: 2023 ZL1 Sharkskin
not too bad for me so far. But we will be doing legs tonight in the gym, that will suck some.
hrpiii is offline   Reply With Quote
Old 11-09-2015, 12:00 PM   #10514
jewel25
Mother of PWA Babies
jewel25's Avatar
Drives: 2011 RJT 2LT/RS
UGH
jewel25 is offline   Reply With Quote
i can haz a tag?
