Old 11-30-2018, 07:27 AM   #10319
CCS71
LFX to LT1
CCS71's Avatar
Drives: 2017 Camaro Fifty 2SS M6
Originally Posted by Soleil View Post
If you put it in transport mode the battery should last ......but. Don’t start the engine unless you get the oil and exhaust really warm /hot. You will create so much condensation and the rust will come. in the worst case remove the battery and store it in your basement recharge it in spring.
I could live with that. It'll be a pain for everything to reset to factory defaults, but looks like I wont have much choice.
2013 Rally Yellow 1LT - Traded
2017 Camaro Fifty 2SS; Sequence #270 - Sunroof/Nav/NPP/MRC/6speed
CCS71 is offline   Reply With Quote
Old 11-30-2018, 08:53 AM   #10320
Fifty SS
Fifty SS's Avatar
Drives: 2017 Camaro SS FIFTY
Nice, garage queens stay in the best shape over time usually.
Just peel off the backing about an inch at a time as you hold your mark at the top of the rock guard.
If you stick the top and bottom at the same time, the center will have tension from the curve and pull away after a short time in the heat. Ask me how I know
Heath
Hi Heath,
Based upon your installation suggestions and feedback, I went ahead and placed my order for a set from ZL1 Addons (Black Friday 18% Discount)!
Thanks again for your help, Eric
2017 Camaro 2SS Coupe - FIFTY #299; H50, M5U, NPP, RIK. Purchased 22Feb17.
Fifty SS is offline   Reply With Quote
Old 11-30-2018, 09:09 AM   #10321
Kaizer_911
Kaizer_911's Avatar
Some possible info about the dreaded TC Shudder Q1 2019 update that is coming.
Very much like the Reo Speedwagon lyrics go...”Heard it from a friend who, heard it from a friend who...”
A Head Mechanic at a Chevy dealership states that GM is coming out with a TCU flash Q1 2019 as the update to the TC Shudder. The Head Mechanic further stated the problem isn’t the actual converter or trans itself but that it’s the programming of the TCU causing what some would call gear searching, which in turn causes the shudder. The mechanic even stated the fix will apply to not only Camaros but Corvettes, Silverados and anything else running the A8 with associated TCU tune.
The TC Shudder has been found to be rectified by some HP Tuners users after adjusting certain settings which does corroborate this news.
For those affected with the TC Shudder and waiting for this new fix, it is unknown at this time if the new procedure will inspect and replace any damaged/burnished units as well as if this will be a recall or TSB.
As I find out more I will be sure to share with everyone.
6000 - 07/08/16 | Club F1FTY
Old 11-30-2018, 09:53 AM   #10322
KyBoy
KyBoy's Avatar
Drives: '17 2SS H50
Originally Posted by Fifty SS View Post
Hi Heath,
Sweet, you'll like them. Like I said, if you need any help, just let me know.
Heath
1100 - 5/26
0000 - Cancelled - 7/5
Contacted Becky - 7/1
2000 - 7/5
3000 - 7/6
3000 - 7/11 TPW 8/1
3100 - 7/18 TPW 8/1
3300 - 7/20
3400 - 7/21
4300 - 8/3
5000 - 8/5
6000 - 8/13
Old 11-30-2018, 09:56 AM   #10323
KyBoy
KyBoy's Avatar
Drives: '17 2SS H50
Thanks for the info Adam. The wife's 1SS has fallen ill to this disease. Had the double flush done at the dealer...it works fine for now.
Heath
1100 - 5/26
2000 - 7/5
3000 - 7/6
3000 - 7/11 TPW 8/1
3100 - 7/18 TPW 8/1
3300 - 7/20
3400 - 7/21
4300 - 8/3
5000 - 8/5
6000 - 8/13
Old 11-30-2018, 09:57 AM   #10324
Kaizer_911
Kaizer_911's Avatar
Heath
Most welcome. And sorry hers is dealing with that.
Old 11-30-2018, 10:55 AM   #10325
KyBoy
KyBoy's Avatar
Drives: '17 2SS H50
Thanks, I am too. I have to hear about it.
Heath
1100 - 5/26
2000 - 7/5
3000 - 7/6
3000 - 7/11 TPW 8/1
3100 - 7/18 TPW 8/1
3300 - 7/20
3400 - 7/21
4300 - 8/3
5000 - 8/5
6000 - 8/13
Old 11-30-2018, 11:10 AM   #10326
RicSimonis
RicSimonis's Avatar
Drives: '17 2SS H50 Vert
I know it's off-topic but do you happen to know if the A8/TC is used by other manufacturers? Our Jeep GC has an A8 and I'm noticing a slight shake running through 2nd gear under moderate acceleration.
Just curious before I start a dealership discussion. Thanks.
Old 11-30-2018, 11:22 AM   #10327
Kaizer_911
Kaizer_911's Avatar
Good question Ric. I’m not sure. But this isn’t outside the realm of possibility. The auto manufactures like to cooperate on some of the tech in vehicles. I will see if I can find any info.
Old 11-30-2018, 11:23 AM   #10328
Kaizer_911
Kaizer_911's Avatar
Heath
Lol I bet.
Happy wife = happy life.
Old 11-30-2018, 11:37 AM   #10329
ljc
ljc's Avatar
Drives: 2ss Nightfall Grey
CCS71...A suggestion that you may want to consider is a solar battery tender/charger. I saw them at Harbor Freight last week. They aren't expensive and plug into the 12v socket, so it may be worth a shot.
ljc is offline   Reply With Quote
Old 11-30-2018, 12:45 PM   #10330
HartfordRacingCaptain
HartfordRacingCaptain's Avatar
Drives: 2017 Camaro 1SS, 2023 Colorado Z71
Lol I bet.
A case can also be made for "slightly irritated wife, amusing life"
2017 1SS, Summit White, Black 2SS Interior, MRC, NPP
2023 Colorado Z71, Nitro Yellow
HartfordRacingCaptain is offline   Reply With Quote
Old 11-30-2018, 12:49 PM   #10331
I also have the shudder. I hope that this new solution does not nullify the fluid update. I would like to update the fluid, then immediately apply the flash as well.
Old 11-30-2018, 12:51 PM   #10332
Kaizer_911
Kaizer_911's Avatar
I personally feel the flush will still be a part of this. Flush then flash. But I could be wrong. As I get more details I will be sure to share. Still waiting to see if it’s a TSB or Recall. If TSB I can snag it quicker than Recall.
