Old 05-23-2021, 09:15 PM   #10319
DorsoDuroJohn
Drives: 2021 Camaro LT1
Put some Forgestars on.
305/30/20
285/30/20
Yes I know, double post in the Black car thread.
DorsoDuroJohn is offline   Reply With Quote
Old 05-23-2021, 09:52 PM   #10320
Chevelle vs Camaro
Chevelle vs Camaro's Avatar
Drives: 2018 Camaro SS
305/30/20
285/30/20
Looks good..... she needs to go low next...
Chevelle vs Camaro is offline   Reply With Quote
Old 05-23-2021, 11:59 PM   #10321
DorsoDuroJohn
exactly my plan. thx.
Old 05-24-2021, 06:01 AM   #10322
Vette468
Vette468's Avatar
Drives: 68 Camaro 6.0Turbo 2016 Camaro LT
I traded a .38 Rossi snub for a 2018 ZL1 Trunk lid and spoiler..it's Gunmetal and my cars Hot Red..I might wrap it in Black..but I like it the way it is..the Gunmetal is a awesome color..and the Irony'. 😁
Vette468 is offline   Reply With Quote
Old 05-24-2021, 06:03 AM   #10323
Infamus
Infamus's Avatar
Drives: 2018 Camaro ZL1
305/30/20
285/30/20
cool wheels, work very well with the car
2018 ZL1 - Daily driver
2018 Mercedes Benz AMG GTS
2017 C7 Grand Sport - Stage two Edelbrock
Infamus is offline   Reply With Quote
Old 05-24-2021, 05:13 PM   #10324
sandm
sandm's Avatar
Drives: no more camaro :(
had the car 2 days. removed the ss/camaro usa badges on the front/rear/sides this morning...
makes it look 100% better imo.
sandm is offline   Reply With Quote
Old 05-27-2021, 01:39 PM   #10325
camarofifty
camarofifty
Drives: 2017 Camaro Fifty
Put new Delco battery in it (5 years old, do BEFORE it causes havoc. Hate the post “clamping system”! Tried to coat post/clamp with dialectic grease to prevent corrosion but wound up taking it off because the F#€¥@&n clamp kept creeping up and would not tighten! Otherwise not too bad 🤬
camarofifty is offline   Reply With Quote
Old 05-27-2021, 02:28 PM   #10326
craigss50
craigss50's Avatar
Drives: 2017 Camaro SS Fifty
They could have made a better access to the battery so you didn't have to remove trunk panels.
craigss50 is offline   Reply With Quote
Old 05-27-2021, 03:01 PM   #10327
NotFast
Drives: 2021 LT1
And, too, my old mechanic told me that post battery posts are recycled - I was having electrical problems with a car because the posts were slightly too small due to their re-use.
NotFast is offline   Reply With Quote
Old 05-27-2021, 06:32 PM   #10328
BrianL
BrianL's Avatar
Drives: 2016 2SS, Red Hot, NPP, Nav, M6
I got the bug seeing this posted from another member, so I bought the Hooker crush pipe delete kit and installed it today. Just never set right with me to have the pipes crushed to 50% due to sharing the pipes with the convertibles that have a cross member that needed the clearance. I know Mishimoto says they tested and found no gains, I also have seen another where it showed a slight Gain. Been 40+ years since my fluid dynamics mechanical engineering class, but restrictions in any form just went against my grain.
Pain in the ass to do in my driveway on ramps, but got it done.
BrianL is offline   Reply With Quote
Old 05-28-2021, 06:19 AM   #10329
01pewterz28
#TeamBeckyD
01pewterz28's Avatar
Gave her a pat on the ass and said I will get your new battery today and take you out this weekend (1st time since October) as I headed out to hop in the Yukon and go to work.
#TeamBeckyD
**FIFTY HBM 2SS VERT**
Old 05-28-2021, 03:52 PM   #10330
clg82
Drives: 2020 Camaro ZL1
Put a coat of Adams Americana wax on it, and put on the new wheels...I like the look so far.
Old 05-28-2021, 06:53 PM   #10331
Infamus
Infamus's Avatar
Well done and PIA is a gross understatement LOL
Old 05-29-2021, 10:20 AM   #10332
DannyC
Drives: 17 Camaro SS
It wasn't exactly today but I did solve a major tuning issue today. Installed a Magnuson 2650 last week and have been using HP Tuner software to get it dialed in. Everything was fine except I could tell the air was off meaning it wasn't reading air flow correctly. I couldn't figure if it was my MAF or the new LS9 MAP sensor that comes installed on the blower.
My bud at Goat Rope Garage suggested the scaling on the MAP sensor could be off so did a little research and found the scaling for the LS9 MAP sensor was waay different than the stock SS MAP sensor. Plugged the right numbers in and BAM it runs like factory again only with way more power
Now all I have to do is finish the water/methanol injection installation.
Flow Tech axle back, Roto-Fab, Nick Williams 103, AEM Wide Band, Defrost vent pod, billet catch can, BBK long tube headers and NGK LTR6GP, #90198, one step colder, Magnuson 2650, Snow Performance water/methanol injection. (Also tune myself w/HPTuners)
DannyC is offline   Reply With Quote
