#1009 |
SoCal Camaro5 Race Team
Drives: 2021 Shadow Grey Camaro 2SS 1LE Join Date: Mar 2010
#1010 | ||
![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2018 Camaro 1SS 1LE Join Date: Sep 2018
I hope to make the Lincoln nats events next year so hopefully I'll see ya there. What are you doing for suspension? I recently got a DSC controller and am considering ordering some custom springs with higher rate, 1" overall drop and they'd also account for the fact Vorshlag plates drop the front end a bit, so more rear drop than front. Rate increase may be limited by the rebound valving in the OEM shocks but I'd guess it can be a good bit higher.
#1011 | |
![]() ![]() ![]() ![]() Drives: 22 1SS 1LE Summit White Join Date: Sep 2016
I do think futzing with a DSC controller would be fun and talking to Robert it would help, but id rather go with their whole coilover setup. Just a large expense right now and FS is, "cheaper" lol
#53 F Street
2025 FS National Champion 2025 Sponsor autocrossdigits.com Autocrossing Videos https://www.youtube.com/channel/UCm-...3tiMt0KOg_2Aag Instagram: apexit_53 |
#1012 | |
I think the DSC and a set of springs may make for some nice improvements for a more reasonable price. I picked up the V4 DSC used for $800. I also looked at removing the AFM lifters and adding a cam + flex fuel, it's about the same cost as a DSC coilover setup! That money is going into a GT4 fund, lol. No way I'm spending big-$ for a CAM setup. If I wanted to I'd probably start with a CAM-T Mustang.
#1013 | |
![]() ![]() ![]() ![]() ![]() Drives: Chevrolet SS 1LE Join Date: Oct 2019
[/quote]Rate increase may be limited by the rebound valving in the OEM shocks but I'd guess it can be a good bit higher.[/QUOTE] My understanding is that the MR dampers can effectively be locked with enough voltage to the fluid, so there's no real limit on damping rates in either direction. I think the springs currently in the aftermarket are all too soft for fastest speeds, and 1" lower could also be better.
Matt Miller
2020 SS 1LE |
#1014 | |
Good to hear the OEM magride damping is nearly unlimited, I wasn't sure if that would limit the potential increase in spring rate. The off-the-shelf spring options need to stay pretty close to OEM rates to avoid damping issues, but if we can adjust damping then we can adjust spring rates too. Ideally, I'm thinking of something in between SLE and ZLE rates, maybe slightly closer to ZLE. It would be a pretty large change overall but right now the car is a bit soft and overdamped in track mode. It is amazing how well it works, GM's damping is really good but compromised for a smooth ride. I also wasn't super happy the Vorshlag camber plates lowered the front end a bit, there's no great way to correct for that, but new springs could.
#1015 | ||
Matt Miller
2020 SS 1LE |
#1016 |
Ok, looks like custom springs are possible.
I have not finalized anything, open to input on rates and drop. Also if anyone knows OEM SLE and ZLE rates off the top of their head let me know, I haven't had a chance to research that yet. I am thinking something like 1.7x OEM rates, 5/8" drop up front, 1" in back (accounts for Vorshlag plates, and camber reduces ride height a bit too). Also if anyone is interested please let me know, post here or PM me. Price depends on volume so it would be good to gauge interest. The DSC magride controller would be necessary to adjust the shocks to match the new springs. It's $1400 msrp. However, the DSC coilover kit is $6500, so about $8k total. I am hoping the springs will be a few hundred a set if we can get a little volume, so a much more affordable solution.
#1017 | ||
Just a thought: this might be worthy of its own thread.
Matt Miller
2020 SS 1LE |
#1018 | |
![]() Drives: 2019 ZL1 1LE Join Date: Sep 2010
Ran the SW divisional last weekend, it was my first time going to GrandSport Raceway, what a great site! My driving on Saturday was pretty poor, putting me out of contention for Top PAX, but I put in some good runs on Sunday-
#1019 |
![]() ![]() ![]() ![]() Drives: 1LEs Join Date: May 2009
#1020 |
when did you move to texas??
#53 F Street
#1021 |
#1022 |
