08-22-2013, 09:41 AM | #10067 |
ZLT!!! COTW (8/5/13)
Drives: 2011 IOM 1LT RS M6 Join Date: Mar 2012
Interesting! ok! Is obvious that less weight is better and more air flow more power,I know that better suspension better handle, but changing bushings, gears & coils how improve in the track? It's a straight line...
08-22-2013, 09:42 AM | #10068 |
Drives: Really Slow Join Date: Apr 2010
GAME ON
08-22-2013, 09:47 AM | #10069 | |
08-22-2013, 09:51 AM | #10070 | |
Drives: 2010 2SS/RS A6 & 2011 1LT/RS Join Date: Apr 2012
Gears are a little different. Low gears, 2.70's for example, is a low gearing and is more high speed, for highway cruising and economy. 3.90's is a higher gear which will help you accelerate faster but you won't have as high of a top speed. Gears can be confusing because you need to take the gearing of the transmission into consideration when picking rear end gears. |
08-22-2013, 09:52 AM | #10071 |
Emerald Coast Camaros
Drives: 2010 Camaro 2LT/RS M6 Join Date: Nov 2009
Well coil overs are more of an improvement for a auto cross types of events. With that being said they do make drag coil overs for better traction and also just about any coil over will give lower weight no matter if its for drag or a auto cross event.
08-22-2013, 09:56 AM | #10072 | |
You got that backwards. A 2.70 is a higher gear ratio since its lower numerically and a 3.90 is a lower gear ratio since its higher numerically. Other than that all the other info is correct. |
08-22-2013, 09:59 AM | #10073 |
Yes your right. Stupid stupid stupid lol had too much going on in my head. I have a hard time trying to explain technical stuff through text. I'm surprised any of it actually came out making any sense.
08-22-2013, 10:00 AM | #10074 |
Don't worry gears are by far one of the most complicated things to get right in upgrading a car because there is so much to consider when doing the change. And all of it is a math based equations to get a final drive ratio. You really have to consider what you want your end result to be when doing gears.
08-22-2013, 10:02 AM | #10075 |
08-22-2013, 10:04 AM | #10076 |
08-22-2013, 10:09 AM | #10077 |
08-22-2013, 10:13 AM | #10079 |
08-22-2013, 10:40 AM | #10080 |
Let's take a break! Let me entertain you with a inspiration poem!
