Old 07-17-2017, 11:29 PM   #981
hogwild87
hogwild87's Avatar
Drives: 2016 2SS Camaro
I run the 109 with the Meth, basically that is all the mods I have besides the drag pack. I think it does help when its hot like we have here in the Midwest from July to the end of August. Is your motor still 376 or did you stroke it a little also? The forged motor can take a lot more boost and I'm sure your going to test it with the pulley change. Are you going to the LS Fest in September?
Stock crank and not sure yet but only time will tell
hogwild87 is offline   Reply With Quote
Old 07-18-2017, 02:49 AM   #982
Merc
In The Circle
Merc's Avatar
Originally Posted by BlaqWhole View Post
Can someone update my times?
Just got in the door and back from Fest. I'll be updating both C 5 and C 6 fast lists in the next few days.
Old 07-18-2017, 12:04 PM   #983
1LEMATT
1LE enthusiast
1LEMATT's Avatar
Drives: 2017 SS 1LE
Originally Posted by G2K View Post
Tires used on the pass: Stock
Performance Mods (if any): None
Category submitted for: Please List the Category or Category # 10
R/T..........300
60'.............2.248
330'...........5.790
660'...........8.642
660’ mph...86.71
1000'..........11.055
1320'..........13.093
1320’ mph…110.69
Name of the track: Palm Beach International Raceway
Date of pass: 7/7/2017
Weather conditions: 1808
Jeez man, with that ET you are gonna kill the SS 1LE ET average...
Crappy DA, but guessing your first time at the track? If you have any questions hit me up...I got mine down to 12.2 in 500ish DA. You gotta practice and get that ET down!
2017 SS 1LE
1LEMATT is offline   Reply With Quote
Old 07-19-2017, 03:10 PM   #984
Guess I have to post this is Category 8 due to a cold air intake.
Totally stock otherwise including full air pressure and super hot weather.
Finally cut a decent 60'. Hot lapped 3 more times with the same result. zero heat soak.
Old 07-19-2017, 04:54 PM   #985
laynlo15
Drives: 2022 Lt1 A10
Great pass Mlee, street tires seemed to do pretty well for your setup. Sorry I never got to meet you, we had a great time and thanks for all your hard work.
Old 07-19-2017, 04:58 PM   #986
Thanks... and next year for sure.
Old 07-20-2017, 10:34 PM   #987
Merc
In The Circle
Merc's Avatar
All I can say is WOW!
Updated!
Happy now?
BTW July 16th I was still in Bowling Green helping with Camaro Fest VII.
Old 07-20-2017, 11:12 PM   #988
Merc
In The Circle
Merc's Avatar
Updated!
Old 07-22-2017, 05:55 AM   #989
Updated!
Happy now?
How dare you go out of town and spend time at the drag strip...
Old 07-22-2017, 10:02 AM   #990
Chevy71
Drives: 2016 2SS
Well, I suppose I'll post mine up. Had to soft launch due to tire spin and stock driveshaft & axles. I also had to get out of it in second gear all night due to tire spin.. Street tires can't hold it and I knew that, was just too anxious to get on the track. She will be nasty when I resolve my 60' with better traction.
I'm car 1757 and I believe category 5
Extremesport Conti tires
Pro charger
X pipe
Cam
LT's
M6
Chevy71 is offline   Reply With Quote
Old 07-22-2017, 03:03 PM   #991
Joe's_cool_1le
Drives: Black 2017 Camaro SS 1LE
Pro charger
X pipe
Cam
LT's
M6
Very nice trap speed. What tire size were you running? 305's?
2017 1LE SS Black - Mods - Forged - lowered compression - BTR custom Cam - Whipple, 3.500 upper and 8.0 lower pulley, Roto-Fab, 1 7/8 Kooks headers, off road pipes, & 3" Kooks full exhaust. LT4 fuel system, with Alky single nozzle running 100% meth. (not installed yet) DSX Tuning flex fuel and DSX tuning Aux pump
Joe's_cool_1le is offline   Reply With Quote
Old 07-23-2017, 09:27 AM   #992
Chevy71
Drives: 2016 2SS
My tires are what kept me out of the 10's. Soft launch due to lack of traction and soft shifts due to lack of traction. Running stock tire size, 275's. I'll be back with traction under wraps. I knew it would blow the tires butnwas too anxious to try it on the track.
Old 07-23-2017, 06:27 PM   #993
laynlo15
Get a drag pack and run slicks to hook that M6. Tens aren't that easy with the Manual, so get it hooked and then we'll see if that makes the difference. The MPH is there, you'll need to get the 1/8 mile into the low 7's to get that 10 second pass. Good luck.
Old 07-23-2017, 08:53 PM   #994
Chevy71
Drives: 2016 2SS
It will be tricky for sure, but like you said I have the power/speed for it.. I just need to get the first half of the track covered better.. I can't 60' in the 2 second range and ever make 10's
