Old 12-14-2023, 08:07 AM   #85
CTRifecta
CTRifecta's Avatar
Drives: 2SS 1LE
Originally Posted by Need4Camaro View Post
The ceracoating was done at a gun shop. I should have clarified, what I meant was have it done by the same shop who originally did the ceracoating to have the colors matched...this was a different shop however. It's not going back to the mechanic who fubar'd my brakes.
Makes sense
2024 2SS 1LE | 6MT | Riverside Blue
1100 - Order submitted - 7/12/23
2000 - Order accepted - 8/22/23
Vehicle Built (per chevy chat bot) - 10/10/23
Window sticker available online - 11/4/23
Arrived at dealership - 11/10/23
CTRifecta is offline   Reply With Quote
Old 12-14-2023, 08:29 AM   #86
Need4Camaro
Drives: '17 Camaro 2SS & '99 Camaro Z28
Can I get a P/N for the 1LE Bolts?
Need4Camaro is offline   Reply With Quote
Old 12-14-2023, 08:43 AM   #87
cdb95z28
cdb95z28's Avatar
The Gen6 caliper mounting bolts are NOT TTY. Just because there is an angle component to a tightening procedure does not mean it is automatically a TTY bolt. GM calls out single use bolts in the service manual. Permatex 27200 high temp high strength threadlocker is the equivalent threadlocker for the GM threadlocker #.
FWIW the part # for the front caliper bolts is:
11570092
BOLT,FRONT BRAKE CALIPER BRACKET
AG, AH, AJ, AK37-67 (J6H) * (M14X2X51, 36THD)
"KEEP THE FAITH"-Fbodfather
Old 12-14-2023, 09:06 AM   #88
m6-lt1
m6-lt1's Avatar
Drives: 2012 Shelby GT500
Where do you see caliper bolts spec'd as TTY? My 2018 service manual says they're reusable, although it's true that it doesn't explicitly list J6H and J6M applications in the torque specs table for some reason (but then neither does it list them with anywhere else in the table, GM may have forgotten to update the application list for the 1LE and ZL1).
Honestly I read they are tty on here but I did a search before replying and it seems I read the wrong info. Found multiple threads were people said they are tty then they got corrected to TTA. Personally though if the bolts are all gummed up I would just use new bolts. They are cheaper than buying the GM red thread locker that GM says to use. I’m sure you can use other brand red thread locker as well but I heard some require heat to remove so not sure if want to do that.
2012 Shelby GT500 with VMP Gen 3R.
Prior:
2023 Camaro 2SS 1LE
2016 Camaro 1SS
2007 Mustang GT
2008 Civic Si
m6-lt1 is offline   Reply With Quote
Old 12-14-2023, 09:09 AM   #89
cdb95z28
cdb95z28's Avatar
No need for heat, just a long breaker bar, but yeah, heat helps! I've reused them multiple times. Clean the threads and apply the threadlocker.
Old 12-14-2023, 11:20 AM   #90
Need4Camaro
11570092
Is this also for the 1LE model as well?
Old 12-14-2023, 11:25 AM   #91
cdb95z28
cdb95z28's Avatar
Yes
Old 12-14-2023, 11:38 AM   #92
Need4Camaro
Yes
cool, so they both do use the same P/N?
Old 12-14-2023, 02:11 PM   #93
cdb95z28
cdb95z28's Avatar
So my car, '22 SS 1LE, has the copper free brakes, RPO codes J6H and BCD.
The non copper free SS 1LE brakes are RPO code J6M.
The non copper free ZL1/ZLE brakes are just J6H.
The part # I gave you is the same on all the above.
ALL Gen6 Camaros use the same front knuckle.
If you have the SS 1LE calipers then #11570092 is correct.
Old 12-14-2023, 02:13 PM   #94
cdb95z28
cdb95z28's Avatar
Good info on brake RPOs here:
https://www.camaro6.com/forums/showthread.php?t=614204
