Old 02-09-2024, 08:35 AM   #85
Katech_Mike
Drives: 2015 Camaro ZL1
The big moment is near. It's back together other than waiting on a new catch can that fits this build. Should fire it up tomorrow.
Do you think I should put a startup tune in it?
If you did not change the fuel system than it should start up fine with your existing calibration.
Katech_Mike is offline   Reply With Quote
Old 02-09-2024, 12:33 PM   #86
JSH
JSH's Avatar
Drives: '20 ZLE
Originally Posted by 94guy View Post
which catch can are you going with?
Correction: This motor has the MM Race. My previous MM Mid never had any fluid in it, but this motor will probably move more fluids.
2020 ZL1LE A10.
100 octane: 1045hp/1055tq.
Old 02-10-2024, 08:48 AM   #87
JSH
JSH's Avatar
Drives: '20 ZLE
No, I haven't make any fuel system changes for this build, yet. So, that makes perfect sense to me too Mike
2020 ZL1LE A10.
Old 02-16-2024, 03:55 PM   #88
JSH
JSH's Avatar
Drives: '20 ZLE
2020 ZL1LE A10.
Old 02-20-2024, 08:42 PM   #89
JSH
JSH's Avatar
Drives: '20 ZLE
We cranked it and let it idle for a while. Gave it some throttle two or three times. The log looked great. Trims were predictably a little rich. Logging some street data tomorrow.
2020 ZL1LE A10.
Old 02-21-2024, 05:40 AM   #90
94guy
Drives: 99 Camaro; 2010 Camaro 2SS/RS
2018 Camaro SS A8 Edelbrock 2650 FBO 93 octane 9.54@144 Pump E 9.12@156
2010 Camaro
Stock bottom end with 46,000+miles JRE remote tuning Whipple A6 and Drive it to and from the track 9.46@146
94guy is offline   Reply With Quote
Old 02-22-2024, 06:18 PM   #91
JSH
JSH's Avatar
Drives: '20 ZLE
I need suggestions on how improve my line and routing on the MM/valve cover line. Maybe a metal one like stock?
2020 ZL1LE A10.
Old 02-29-2024, 10:56 AM   #92
JSH
JSH's Avatar
Drives: '20 ZLE
The car now has a mild road tune and will dyno next week. This time, I'll adjust the tune while on the dyno. I didn't do that last year. Just drove it on, twisted it, and drove it off.
2020 ZL1LE A10.
Old 02-29-2024, 11:22 AM   #93
JSH
JSH's Avatar
Drives: '20 ZLE
I found an LPE BBFP for $800. E85 here I come...
2020 ZL1LE A10.
Old 02-29-2024, 01:32 PM   #94
Joshinator99
Moderator
Joshinator99's Avatar
Drives: 2017 Camaro 2SS A8
Nope you’re not lol. You’ll need big injectors to run with that pump to run E85. Our power levels are similar, am running +52 injectors, and I can only run E50 FYI…
Old 02-29-2024, 07:28 PM   #95
JSH
JSH's Avatar
Drives: '20 ZLE
Yeah, I know 65+ and larger fuel lines and a flex fuel kit and God knows what else is required. The injectors are like 4k retail but people are always selling such stuff used for a lot less.
2020 ZL1LE A10.
Old 03-06-2024, 02:07 PM   #96
JSH
JSH's Avatar
Drives: '20 ZLE
With inlet filter and 2.625 pulley = 1116hp/ 1063tq, on 100 oct.
The 1116 pull made 18.7# boost pressure, within a # or two of the previous motor.
The hpfp does not appear to be working very hard.
The perforated K&N air filter made the same horsepower as the Bellmouth.
The 3" upper made over 100hp less than the 2.625. It doesn't have enough blower now.
Timing advance = 22 degrees (!)
Before, I had more blower than motor. Now, I've got more motor than blower.
I'm not sure it has enough cam now either.
2020 ZL1LE A10.
Old 03-06-2024, 03:24 PM   #97
2018ZL1
2018ZL1's Avatar
Drives: 2018 ZL1 A10 NFG 2019 COPO 350 SC
With inlet filter on 2.65 pulley is 1116hp and 1063tq. On 100 oct.
Those great numbers! Hooking will be your challenge now! If it hooks you will be in the 8's easily! Very nice!
2019 COPO #32
350 SC
8.25 167MPH
2018 ZL1-NFG-A10
388CI L8T
9.32 147MPH
2018ZL1 is offline   Reply With Quote
Old 03-06-2024, 07:02 PM   #98
Joshinator99
Moderator
With inlet filter and 2.625 pulley = 1116hp/ 1063tq, on 100 oct. The 1116 pull made 18.7# boost pressure, within a # or two of the previous motor. The hpfp does not appear to be working very hard.
Very nice, congrats!
