#85 |
![]() ![]() Drives: 2018 HBM ZLE Join Date: Aug 2017
Plenty of choices in Houston, but still have some bad ones there too
#86 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: E92 BMW M3 Join Date: Oct 2012
I was saying the same in another thread. We are lucky here, but its almost the 3rd biggest city so no shock I guess.
J-Rod Built and Matt@FSP Tuned |
#87 |
![]() Drives: Z06 Join Date: Oct 2021
yeah ill be going to matt when im ready to get it going. LMR is just out of their mind with pricing. I get it but damn u really got to pay to have that sticker lol
#88 | |
#89 |
![]() Drives: 2019 ZL1 Join Date: Oct 2020
Dyno numbers are in. Will pick up the car tomorrow morning.
stock it dyno'd around 520hp after all that work, 632whp @5400rpm 703tq @3750rpm says the weak point is heat on the headers with all the back pressure since I still have the stock factory exhaust. I'll probably do a corsa extreme in a few months or something. I forgot to ask how much boost they were running with the smaller pulley. But depending on how it runs and stuff I can always retune later for higher or lower after that exhaust is added. |
#90 | |
#91 |
#92 |
5400 rpm is nothing, you should easily be around 720-730 rwhp or above at 6500-ish rpm. Hope they didn't abort the pull because there is an issue with the car in higher rev ranges.
#93 |
yeah that's the range I was expecting too. Guess I'll find out when I pick it up tomorrow
#94 |
9psi of boost...I was under the impression that by going with the smaller pulley I'd be able to make back that 10-11psi it was making stock back in indy.
that explains why I'm 630ish instead of 700+ most likely at this point I'll probably retune for that higher number somewhere else with the addition of the corsa extreme exhaust |
#95 | |
![]() ![]() ![]() ![]() ![]() Drives: 2019 ZL1 Join Date: Mar 2019
Did you get uncorrected numbers or corrected numbers? From looking at your profile, your in CO, you elevation is high. Your going to make much less power there. Forgive me if I didnt read correctly
LME 377 LT4 Short Block | Magnuson 2650 80mm upper w/13% lower (9.06) | DSX Lid & Valve Covers | CSP Custom Cam w/32% fuel lobe | CID Heads | NW 103mm TB | Roto Fab Big Gulp | CSP 2" Headers w/Green GESI Gen 2 Cats | Borla 3" Full Cat Back w/ S-Type| Mighty Mouse Wild Catch Can| Custom Holley Low side Fuel system| TooHigh PSI Port Injection w/Holley Controller | Forced Inductions Interchiller w/2 gallon fender tank | TK Performance built 10L90 |
#96 | |
Boost is just a restriction. With the addition of the cam, your using 1-2lbs of boost that would of been a restriction before. So that 9lbs could of went down to 7, with the pulley it brought it back up to 9. So your making more power with the added airflow, *you didn't lose boost per say, the engine is just now able to use it*
#97 | |
#98 |
Yes, I understand that I'll be making less power. Those are SAE numbers. However, to me, I only had the car for a month before it got upgrades and most of it was here in CO. Now I've been without it for nearly a month & it's making 110hp more than I sent it in with. I'll feel the difference for sure. So will the other cars around here that wanna try me...lol
| Tags |
| cai, cam, headers, mods, street build |
