11-15-2021, 03:13 PM | #85 | |
Drives: SS 1LE, 89 TTA, 91 GTA, 91 Formula Join Date: Jul 2019
Except for some magical reason you can't get it for 20+ cars now....... I want one. |
11-15-2021, 03:14 PM | #86 | |
Ahhh the gubment adding engineering and taking away fun at our expense, have to love it. I get wanting safer cars, but some of it has gone so far down the rabbit hole as to be laughable. None of the time is spent educating the 80% moron drivers on the road..... |
11-15-2021, 03:17 PM | #87 | |
Drives: 23 LT1/22 Colorado TB/69 Chevelle Join Date: Jun 2006
11-15-2021, 04:05 PM | #88 | |
Drives: 19 Chevrolet Camaro 2SS 1LE Shock Join Date: Apr 2020
And on a stock, unmodified engine, how much standard deviation is there? Everyone has pretty much the same starting point.
Current:
2019 Chevrolet Camaro 2SS 1LE M6 Shock GM Performance Intake and that's it, because driver mods before car mods Past: 2009 Mazda RX-8 GT M6 Velocity Red Mica (Sold) 2015 Chevrolet Corvette Z51 2LT M7 Velocity Yellow Tintcoat (Flood totaled) |
11-16-2021, 04:25 PM | #89 | |
Drives: 13' 1LE Join Date: Apr 2012
100%
13' 1LE
Old setup: TSP 231-236/Tick 660/.105 PR, UDP, SW LT 2'' & HFC, stock NPP & H pipe, VR-DRX CAI, air scoop, Goertz1 manifold, 102mm BBK, 26" Toyo DRs, Forgestars R17x10 & F18x8, rear seat delete, remote Pat G tune Autocal, 7400 limiter, Spec Mini Twin. 91oct. 11.90@122.3, 0-60ft 2.0 / 11.99@123.6, 0-60ft 2.1 DA+819 ...519RWHP SAE Solid roller SBE LS3, FED, LLSR, 91oct, 605rwhp N/A. Tuned by Pat G. Build by me. |
11-17-2021, 12:28 AM | #90 |
Drives: like an old lady Join Date: Jun 2012
ah yes, how easily we forget that one anecdotal dyno graph is the standard. about a cai, no less. i hear 2001 calling, it wants its car forum information back.
the camaros aren't getting any power upgrades. tbh, i'll be surprised if they make more than 10k of them in 23.
11-17-2021, 12:13 PM | #91 | |
If it's an anecdotal butt dyno then yes, of course don't trust it, but this isn't a butt dyno. Again, show your own dyno to counter the information that's available, and I am more than willing to look at your information. Remember, this CAI comes with a tune and a 4~5% bump in power really isn't that unbelievable.
Current:
11-17-2021, 03:41 PM | #92 |
none of my dynographs include that part. plus i don't race dynos, so moot point at best.
fact remains - the camaro is already dead and has been pretty much since it was released 5 years ago. gm add a new engine for it? ha worst selling camaro in history? id guess so but i don't have time to look it up.
11-18-2021, 04:39 PM | #93 |
Drives: 2022 Camaro 2SS 1LE Join Date: Sep 2018
There is one other consideration that has only breifly been mentioned, but is worth considering, and that is emissions. I thought about it some and did some quick googling and found the following bit of information.
In April of this year the EPA issued a proposed rule about revising fuel economy and emissions standards that were set by the SAFE rule that went into effect in 2020. As some may recall, this was the controversial roleback of the 2012 CAFE standards. There were public meetings in August, and the public comment period was closed at the end of September. I don't think a ruling has been made, but if adopted these more stringent standards would go into effect in 2023. Perhaps GM sees the writing on the wall and a "new" engine is required to meet these standards. And by new I mean applying LT2 components to the LT1, primarily in the form of a revised intake manifold and camshaft. GM likely can't axe the Camaro completely without major repercussions - mainly from all the UAW jobs lost. My guess is they need to keep Camaro production moving along while they figure out a replacement built on the Alpha chassis or something similar that can be tooled in the Lansing plant. That would also explain why GM has been cagey about a drop dead date for the Camaro. It might also explain the continued constraint on the V6 engines. Im not saying GM will put the LT2 in the Camaro, and I certainly don't think they want to. But they may be their best option at the moment. |
11-18-2021, 04:42 PM | #94 |
Drives: My wife nuts... Join Date: Sep 2011
I agree with the poster above.
2023 will be a short run |
11-18-2021, 06:15 PM | #95 | |
a big part of what makes an LT2 an LT2 is the exhaust. that setup is not going on any other vehicle gm makes. emission compliance is heavily dependent on such, and that engine is a mid engine chassis puppy. nothing else.
11-18-2021, 08:26 PM | #96 |
Drives: ‘23 SS 1LE Join Date: Nov 2021
LT2 will never come to the Camaro. Aside from the cost of recertifying an LT2 Camaro for EPA and CARB, there’s a fundamental electronics issue. Camaro is a GM Global A platform, and the LT2 engine software was written for GM Global B. The car’s entire electronic architecture would have to be updated to the new Global B platform - BCM, radio, the works. Absolutely not going to happen for a car that has maybe 2 years left.
IF a 7th gen car is ever approved for the A2 platform (which supports Global B) then sure, LT2 would be the obvious choice. But to my knowledge an A2 Camaro has never been planned. |
11-19-2021, 08:45 AM | #97 | |
The exhaust is part of the equation, but its also cam, intake manifold, dry sump oiling system, etc. As Ive said before, the Camaro wouldn't get a "real" LT2 because you are right, it's a mid-engine block. But its still part of the LT1 family. It uses many LT1 parts (crank, rods, pistons, heads, etc.) What GM could/would do is adapt LT2 parts to the LT1 - make a "hybrid" engine. The cam and intake manifold practically bolt right up. An exhaust manifold redesign would require some extra effort though. EPA/CARB certification is not cheap, per se, but not exorbitantly expensive either and could be justified if the Camaro continues out through 2026, which has been a rumor. They may be counting on a sales bump, which I think 30+ HP might give them. |
11-19-2021, 08:51 AM | #98 |
[QUOTE=mRahmani;11099496]LT2 will never come to the Camaro. Aside from the cost of recertifying an LT2 Camaro for EPA and CARB, there’s a fundamental electronics issue. Camaro is a GM Global A platform, and the LT2 engine software was written for GM Global B. The car’s entire electronic architecture would have to be updated to the new Global B platform - BCM, radio, the works. Absolutely not going to happen for a car that has maybe 2 years left.
You're assuming 2 years, which most people are, and its not unreasonable. But I personally think the pandemic screwed things up so much, the successor is getting pushed back, and Camaro is sticking around till 2026. The Camaro is a sales dog, the pandemic, supply chain issues, etc. would be the perfect reason to just axe the Camaro, but they didn't. I think GM has UAW contracts and needs a successor that can be built in the Lansing plant, and its not ready yet. As far as the electronics, part of the rumor is the Camaro will have an unlocked ECU, unlike the encrypted ECU in the Corvette. Theres no reason a Global A ECU couldnt run an LT2-like engine. Again, it wouldn't be an LT2 engine per-se, it will be an LT1 with LT2 parts bolted to it. |
