05-04-2021, 08:01 AM | #85 | |
Surely headers are near the top of the list.
'20 ZL1 1LE A10.
LME 390, E2650, FBO, 100 oct. Not a DD. |
05-04-2021, 08:35 AM | #86 |
Drives: 2021 Red Hot ZL1 Join Date: Sep 2020
Nothing is cheap on these cars. For a forced induction vehicle though, typically increasing boost is the most cost effective HP mod which means a pulley swap, however because the stock exhaust manifolds are so restrictive on these cars, it pretty much becomes necessary when increasing the boost. Headers are not cheap, nor is installation if you pay someone to do it and hen you must also have the PCM tuned which adds more cost. The way these cars are designed, its almost like there are no cheap effective HP mods without some expensive supporting mod to go with it. Even after you go full bolt on, then you have to go into the engine to add a cam for more fuel, even if you didn't want a cam, it becomes a necessity to continue to increase power.
05-04-2021, 06:32 PM | #87 |
Drives: Gen V Viper GTS Join Date: Jan 2018
With respect to Headers, just remember that they pose warranty challenges and almost always make the car less drivable. There are also often issues with heat in the engine bay (requiring ceramic coating or heat wrapping) and non-– OEM gasket fittings. So while headers may be very effective, you will be happiest if you know what to expect.
05-04-2021, 06:44 PM | #88 |
I haven't noticed any negative effects of my Kooks. On the other hand they look good, sound good, and add 15 hp or so
'20 ZL1 1LE A10.
LME 390, E2650, FBO, 100 oct. Not a DD. Last edited by JSH; 05-04-2021 at 06:54 PM. |
05-04-2021, 06:47 PM | #89 | |
05-04-2021, 07:55 PM | #90 | |
Drives: 2018 Camaro ZL1 Join Date: Aug 2018
What I think of for daily use issues would big a big ass cam. Exhaust is at the bottom of my list on making a vehicle less drivable. |
05-05-2021, 05:34 PM | #91 | |
What comprises an acceptable modification will vary from person to person and especially from state to state. People in some states (for example Texas) seem to be more willing to accept big camps, no catalytic converters, etc. in a daily driver. My point is simply that the person choosing the modification should just understand what they are getting into. |
05-05-2021, 06:57 PM | #92 | |
My point is that headers do not cause any significant issues to the car being drivable. It made it perform better and had 0 side effects. A cam is what I consider something that'll affect a vehicle driving aspect or a very stiff clutch. Living in California, people might as well just drive hybrids or EVs. California even hates OEM parts. They stopped the selling of Camaro's...... just saying. |
06-09-2021, 05:08 AM | #93 |
Drives: '17 ZL1 M6 Join Date: Apr 2021
Update for my setup and some tests
Added a braided snow WMI (40/60) using a single 9GPH nozzle. Fuel adjustment only for cooling purposes (Summer is HELL here) 95F temp & 93 octane Same tune - 626whp (AFR was in high 10's) WMI ON Map 1 - 676whp (AFR High 11.8-11.9) WMI ON Map 1 - 661whp (AFR 12.3-12.4) WMI OFF Map 2 with 1.5* of added timing - 685whp (AFR 11.8-11.9) WMI ON Goal was to add this for cooling only and not be dependent on meth whatsoever since I am against these kits as a fuel source and ultimately ran out of options
'17 ZL1 M6
8xxwhp Magnuson 2650 |
02-28-2022, 01:24 AM | #94 |
Makis
Drives: 2020 Red Hot ZL1 A10 Join Date: Apr 2019
Great thread. Why did you ever stop posting!
Mosaic black 2018 Camaro 2SS A8 (sold) |
06-07-2022, 05:12 AM | #95 |
Drives: 2008 Pontiac G8 GT, Shelby GT500 Join Date: Mar 2011
Any drivability issues going with a larger TB?
06-07-2022, 05:20 AM | #96 |
06-07-2022, 11:05 AM | #97 |
Petro-sexual
When we switched the car over to a 103, it acted like it didn't even care. It could be because we fought with an over-ported LT5 TB earlier, so some of the homework was already done, but moving to a 103 didn't change much. The torque model is off, because calculated HP has gone up crazy, but drivability-wise - no biggie.
06-27-2022, 06:44 AM | #98 | |
Having FUN in the SUN...
Drives: 2022 M6 ZL1 1LE Join Date: Jan 2022
Thats a great question... I would guess a FlexFuel kit would win hands down?
2022 M6 ZLE: Katech Standard Ported Blower + Ported Heads + 103mm TB + Oil Pump + C5R Chain + Valve Covers + Coil Relocation Kit
TSP VVT and DoD Delete Covers + LME Chain Guide + DSX Billet Lid + ATI Damper + 9.17" Lower + 2.4" Upper + MM Wild Catch Can Coated AR Headers + GESI UHO Cats + V Bands + AWE Touring + Magnaflow Center X + MSD Coils + Banks iDash + JMS Booster ALL the BMR Read End Goodies + BMR Motor Mounts + JRE Terminator Cam Package + Big Gulp + GMS High Flow Crash Bar DMS Front HX + Fender Tank + FIC 30's + APEX SM.10's + TOYO 305/345 R888R's = 775rwhp 815rwtq @E55 13.5psi |
