08-21-2020, 06:27 PM | #85 |
Drives: like an old lady Join Date: Jun 2012
yeah it has had nothing but ethanol since it was tuned in april. i highly doubt vacuum leak but i'm going to ether test it again in the morning. first test was negative.
08-22-2020, 06:57 PM | #86 |
Drives: 2013 camaro ls v6 Join Date: May 2014
How do you remove the lt1 manifold bolts?
08-22-2020, 07:34 PM | #87 |
Are the lt1 bolts the same as LS? Seems like it...
Would these work? https://briantooleyracing.com/arp-in...-130-2001.html
08-23-2020, 03:27 AM | #88 |
remove them from the intake manifold? i used a hammer and lightly tapped them up.
the ls1 bolts do look similar. it is nice that the lt1 & lt2 intake manifolds use the same bolts.
08-23-2020, 04:06 AM | #89 | |
Edit:worked perfectly. Thank you. Last edited by ttyler333; 08-23-2020 at 04:28 AM. |
08-23-2020, 10:00 PM | #90 | |
Drives: 2017 SS 1LE, 2016 1SS (previous) Join Date: Apr 2016
08-29-2020, 06:26 PM | #91 |
Drives: 2019 Camaro 1ss Join Date: Aug 2020
Extensions
Did you need any other extensions besides the map hardness extension brotha ?
09-06-2020, 10:26 AM | #92 |
Drives: 17 2SS, 8L90, Cam, Heads, E85 Join Date: Dec 2016
09-09-2020, 01:26 PM | #93 |
Man I bet MSD is counting the loses in sales. GPI didn't do them any favors posting the Video and HP gains. Wish it would work on my Vette also but won't clear the cowl.
09-09-2020, 03:23 PM | #94 | |
Drives: 2019 Camaro 1LE Shock Candy Join Date: Mar 2016
LT4 1.7 Supercharger snout ported & 100% Meth
103 Katech TB, KATECH Custom Heads, DSX In-line fuel TSP Headers, Spec P Super Twin Clutch, TSP EL C7 CAM Diamond Piston & Manley Rods, Roto Fab Big Gulp BTR Push Rods,LS7 Lifters, ARP, FI Chiller, Kirkey Seats SJM Line Lock, Hurst Pistol Grip. 747/739 RWHP street tune - 821/794 RWHP track tune 101 octane. 2014 Mini Cooper countryman S All4 M6 daily driver Last edited by BlackbeastSS2; 09-09-2020 at 03:35 PM. |
09-09-2020, 03:36 PM | #95 |
Looks like no adapter plate on yours? Is that correct?
103 Katech TB, KATECH Custom Heads, DSX In-line fuel TSP Headers, Spec P Super Twin Clutch, TSP EL C7 CAM Diamond Piston & Manley Rods, Roto Fab Big Gulp BTR Push Rods,LS7 Lifters, ARP, FI Chiller, Kirkey Seats SJM Line Lock, Hurst Pistol Grip. 747/739 RWHP street tune - 821/794 RWHP track tune 101 octane. 2014 Mini Cooper countryman S All4 M6 daily driver |
09-09-2020, 03:46 PM | #96 | |
I know we have Dyno numbers, are there any driving results with just putting the intake manifold on and no AF tweaking?
09-10-2020, 01:54 AM | #97 |
Drives: 2018 Camaro SS/1LE Join Date: Jan 2018
Mines been installed for over a week but haven’t driven till yesterday. With no real history with these I didn’t want to just slap it on and assume not tweaking the af was ok.. when I actualy drove it over to drop off with the tuner it seemed like it was running fine. Didn’t go wot or anything but regular driving and just getting on it a little bit was ok
2018 SS/1LE... summit white.. E85 ,Ported LT2 IM, Roto Fab, soler performance ported throttle body, secondary delete, mbrp axle back, tuned by CCNC
09-10-2020, 08:27 AM | #98 |
I seen somebody on Facebook report that after swapping to the LT2 intake the AFR leaned out from 12.8 to 13.4. I suggested getting the AFR back into the 12.8-13.0 range before running it hard and somebody else posted that is still too lean "They set their cars up for 11.8" lmfao...gotta luv these internets.
2016 NFG 1SS A8
