#85 | |
#86 |
Darth Martel
Drives: Black 1SS with 20% tinted windows Join Date: May 2009
I'm not exactly sure what cam specs I have. I ordered the cmooth idle N/A cam. So, I'm not sure how aggressive it is. I didn't have the heads ported. I probably would have had it not been for me also needing a torque converter. So, that took precedence with my budget. Otherwise, I have the mods in my signature plus the cam and torque converter. My stock IM and TB were ported by PRAY. So, I'm not making crazy power. 500 horse maybe. I might add a blower and do the fuel upgrades down the line along with some handling upgrades but, really this was supposed to be it for awhile and satisfy my needs for extra get up and go.
So will I be good if I just take the LS7 lifters? I figure the Johnsons would give me peace of mind on longevity. It sounds like I should do preload checks regardless despite JRE telling me they'll work. So, I'll need an adjustable pushrod for that. How do I turn the cam to get it at zero for the first lifter? Or am I really just concerned with the rocker to gind zero lash and not worry about cam position? How do I go about relieving the coolant line pressure? I didn't reslize I'd have to drain the oil after replacing the lifters but, if the coolant is going to end up mixing with oil during this process, then yeah, new oil is a must. What other little things should I be aware of?
2016 Black 1SS w/ MRC, low-gloss black wheels, auto trans. Self-created custom Dark Knight Edition accents. Rotofab CAI with dry filter and sound tube delete, PRAY ported intake manifold and throttle body, Texas Speed cam, Stainless Works headers and exhaust, Skid Mark garage E85 kit, JMS fuel pump voltage booster, Circle D torque converter. Custom E85/mod tune by Jannetty Racing.
#87 | |
![]() Drives: gas powered Join Date: Jan 2019
Hemi guys are cheating somehow and going like .020" which I think it crazy. Guess its why I always liked old school solid cams. Ill try and find the link. I read alot and it might be on FB and might be on a forum I cant remember. As far as the OP I feel for you,man Ill probably never mod my car. I dont really agree "its on you" when you pay for something and then have to pay again just to make it right. I think thats on the shop...but reading here I am in a small small minority.
#88 | ||||
All TSP cams have fast ramp and .635+ lift, you most use a Jonson with the correct preload. This can only be done with: 1) studs and fully adjustable rollers 2) +/- pushrods I think mine were in .025 increments. Quote:
The adjustable rod is to check for proper, you need only one. Then you select a pushrod that will place the lifter plunger in the middle of the throw. Quote:
https://www.tickperformance.com/john...nes-part-2110/ Quote:
Thank god I did NOT order the Rs... so if I read this right, I go with heal of cam, zero lash the adjustable pushrod, measure pushrod add .035 for the Johnson preload and .015 for the aluminum = .050, if you have to make a mistake it is better to longer as the normal Johnson lifter has about near the LS7's .200 travel. Interesting that Johnson does say "NOT recommended for lifts above .630" so even the Johnson lifter is NOT built for the lift of most vendor cams.... interesting to say the least.
#89 |
Darth Martel
JRE should be open today. They've been down several days last week due to power outtages in the area. So, I'll hopefully, find out what lifters they actually gave me and then see if I can get a set of those Johnson 2110's out of them. I think for the headaches I've gotten from all this and what I've had to spend, out of pocket, for this mess, it's the least they could do.
At least, I'll never need to pay anybody to do this type of work again since I'm going to learn to do it myself. Can anybody suggest a good reference book or manual for diving into this engine? I'm taking notes from this thread as well as some others on here. I'm trying to devour as much information as I can so, I have a solid understanding of what I'm doing. thanks guys
#90 |
Darth Martel
The lifters I was supplied were TopLine 345A 2281S
Or as I call them... GARBAGE
#91 |
If you worked on a SBC or ANY V8, this engine is about the same here are the strange things:
1) it is DI and if you have a + fuel lobe that has to shimmed in. There are lots of info on how to do it. 2) the factory DI HPFP to fuel rail has a one time use metal tube, same on the driver's side after the T. The original ones had a blue coating of "sumting" the others that I have ordered are perfectly clean to the naked eye. I have gone 2x reuse, but others insist there is something still magical about these two lines. I literally can't see it. 3)The front damper bolt has a different torque setting new / used 4) The oil pump need to be marked when removed. I just used red spray paint but they do sell doodoo plastic markers. If you screw up, you MUST buy a new pump. 5) the VVT can be locked solid, or have a block put inside for anywhere from 0 to 22 degrees of movement. Most guys just lock it, as most tuners can't or wont make use of it. There are also questions of reliability. Some people go to a complete delete but this requires a new timing cover and is rather expensive. Cam bolt is onetime use. You can't tighten it to the torque to yield spec as it stress the chain. You torque it and then mark it and bump it to yield with a impact gun and if you screw up you have to do it again and again. 6) DoD delete cams have the oil passages blocked. 7) main, rod, and head bolts are throw away items. This is my opinion but the ARP head studs call for WAY too much toque, use ARP lube and torque them -10 ft lbs. My opinion. Factory bolt holes can only take so much, I already feel for yours. One of my factory holes is way over sunk in depth and the stud won't bottom, so I have to loctite it in, let it rest and harden with a preload and then put the nut / washer on. Total pain in the butt. I might if I ever pull the engine apart just use a factory torque to yield bolt in this area. I've already purchased a kit to helicoil this, but the threads are actually mint just the hole is too deep... like it goes to China. 6) If you change clutch the flywheel bolts are also TtY, and the ARP bolts WON'T fit!!!! Even though they say they are for the LT1 Gen V. Oh the fit but no socket can turn them. What was ARP thinking?!??? 7) it is kind of hard to change cam from front of car but can be done, without dropping the pan 8) it is difficulty to pull the M6 short block out of the car due to the length of the dual mass flywheel. 9) 2017 up have the new 1234 freon, which is rape me expensive, all components can take normal R134, you can't order the older line with fittings, it you try you will get the 1234 line. So I had to get conversion fittings for my A/C refill stuff. The original line must be gold now so don't break or bend it (all joints are cheapo single bolt). 10) one A/C compressor bolt is a bear to get to, it is the front lower one. Good luck with that one, takes a lot of swearing. 11) don't overtighten the cat to factory header, you don't hate it, it don't hate you, the hot exhaust will make these a BEAR to get off if you King Torque them on. 12) drain anti-freeze and re-use. change filter after break-in. I then change engine oil at 1000 miles. Then go to more normal change level after that. 13) IMO, no cam over .600 lift and / or fast ramps can last 100K miles, be prepaired to check for wear on the cam every so often and also change out the springs every so often. Sure there maybe internet stories on how my .635 lift cam went 300k miles never had the valvecovers off. Hence I said IMO, everything is a bell-shaped curve and high lift fast ramp profiles will have a mean time between failure sub 100K IMO or course. 14) factory rod bolts get suspect over 6800 RPM... at some point say 7100 RPM the get REALLY suspect. ARP makes a nice replacement set. 15) you can check the degree of the cam, but there is no way to change it if your cam is ground wrong. So people are degree'ing their cam for shiznets and giggles. Large duration cams need to check piston to valve clearance, you should have no issues with your cam
#92 |
![]() ![]() Drives: 2018 Camaro SS 1LE Join Date: Jul 2018
Oldman: lots of golden nuggets there - thanks!
#93 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2SS 1LE Join Date: Aug 2013
For adjusting cam timing use the livernois piece
https://www.enginelabs.com/features/...timing-system/
#94 | |
![]() ![]() ![]() Drives: 17 2SS, 8L90, Cam, Heads, E85 Join Date: Dec 2016
I did my cam, heads, lifters, afm delete from my 19x19 garage with just a cheap craftsman mechanics tool set and a couple of cardboard boxes to put stuff on besides the concrete floor. You should get a few of these: https://www.ebay.com/itm/Thexton-THE...-/192976920517 And you really should get this too: https://www.ebay.com/itm/Long-Reach-...wAAOSw6zheJhM2 Thats not of course a complete list of tools but I would certainly invested in them if id have known beforehand. |
#95 | |
#96 |
Here ya go.
https://www.livernoismotorsports.com/product/LPP821112 I keep flipping between just porting the heads and doing h/c. The idea of leaving the afm lifters in there kills me. I’m seeing 5-10rwhp by just removing the afm lifters. It’s a lot of work just to throw in a lt5 cam. Just like you’re saying about the threads. Tearing through and moving crap around kills the clips and hoses. There’s no clear path
#97 |
LT5 cam is too mild, I do a custom cam motion one with .594 lift or even 585
Here is one off the shelf: https://cammotion.com/gen-5-lt-camsh...218-228-114-5/ 114 LSA and upto 4degrees of motion on the phaser. The cam is installed +5 so the retard ( I think) should put it near straight up.
#98 |
![]() Drives: 2012 GMC Sierra, 2018 Camaro SS 1LE Join Date: May 2016
This is impressive from "oldman" and should be a sticky somehow.
