#85 |
![]() Drives: Camaro 5 SS Join Date: Jun 2020
Thanks for the useful information.
#86 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2020 SS 1LE (previous: 2017 SS 1LE) Join Date: Mar 2012
![]() I think we should pause before arriving at conclusions of "the same as" - as frankly we would need to compare many details to be remotely factual. The closest incident in "the same as" category regarding the OP is the Supra. Same event, same day, same RBF600 fluid, same corner and seemingly the same result of no pedal in a very sudden fashion. At least that's as "the same as" based on my observation. Yet clearly, many details are missing to make it an objective conclusion. Btw, I recall reading some posts previously about folks having some sort of difficulties with RBF600 if my memory serves me right. Some fluids have different viscosities and other properties (beyond temp ratings) which may, or may not be liked by some internal systems. This is a guess only, but Tadge eludes to it in his response, albeit in a very generic fashion. It is also a mystery to me what he means by "DOT4 for track vs race fluids like SRF and RBF". Is he suggesting that some DOT4 fluids should not be used? Again, i find his statement rather incomplete and hence confusing. Clearly, cooking RBF600 with stock pads even during longer session throws big question marks for me. Until last season, when i switched to SRF, i had used Willwood 570 Racing fluid. It is an old and proven DOT3 formula (yes, a racing DOT3 fluid!), with lower temp ratings than RBF600, yet i had no issues with it. Except for ST43s which cooked it in just a couple of laps (no surprise). As a matter of fact, i had used it on my previous cars, including several 45min sprint w2w races with top dog DSUNO pads in my C5Z (see note) However, unlike SRF i had to bleed it every 3-4 track days. Note: not all race pads deliver the same levels of torque. As one previous post in this thread demonstrates, some manufacturers don't necessarily believe more torque is better, or required to make a pad a race category. Majority (if not all) *warn* against mismatching pads vs tires. Yet tons of folks put incredibly high torque pads on their street cars, with little or no mods to their street braking systems. Moreover, some folks also change factory brake bias by putting different pads F vs R. Etc. Bottom line: let's keep examples coming for the benefit of our community. But resist the urge to draw definite conclusions without detailed data. Or being overly critical of the posters, who volunteer their experiences. C7 experiences aside, there seems only 1 Camaro who reported "loss of brakes" thus far? Of course i had lost brakes as well in my 1LE, but clearly it was due to a complete mismatch between high torque pads and inadequate brake fluid. Cheers! |
#87 |
One more note: i would categorize the amount of fluid on calipers in the pix above is normal.
Lastly, i would NEVER take my car to a dealer to have brakes bled, as they probably never do it and probably would assign the task to a jr tech, who probably would have zero idea about it. |
#88 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: '18 1SS 1LE Join Date: Sep 2017
...or worse, introduce air to the system.
I've found if you want something done right, do it yourself.
'18 1SS 1LE Black, PDR
#89 |
#90 |
![]() Drives: '19 ZLE, S54 E36M3 Join Date: Feb 2018
I use a syringe and a short length of tiny tubing to suck the residual fluid from the bleeder screws. No sign of “leakage” after abusing them for two days at Road Atlanta last weekend. I was really impressed with the performance with stock pads, RBF660 fluid. Rotors still look like new.
#91 | |
#92 | |
![]() Drives: Chevy Camaro Join Date: Nov 2019
#93 | |
There was a good article on this from Willwood, but i cant find it anywhere either. You also make a very good point about the wet vs dry boiling points. In addition to it, DOT4 absorbs moisture much faster than DOT3. That's why it is unsuitable for long term use vs regular OEM fluids. Of course i am not suggesting using an OEM for track, but that's something to keep in mind. Looking at the posted tests, looks like SRF is worth every penny. Given that it lasts a whole season with just a mid season bleeding, it is my choice anyway. It seems very stable and when we bled it last year after about 10 track days, it came out looking hardly any different than new. This was my experience anyway, with stock pads, so nobody should take it as a scientific proof of anything and make their own educated choices. Albeit a very fast and a very prolific top driver here (Provoste) expressed a very similar experience on his car (with DTC60 pads). Lastly, while BRF600 may work for some, it appears that it won't for others. Clearly you had managed to pass its limits yourself even with stock pads (!!!), the Supra driver boiled it suddenly and catastrophically and Sam may have run it as well (with very aggressive pads) albeit it is not clear what exact fluid he called "600", or what really happened. Cheers! |
#94 | |
#95 | |
#96 | |
![]() ![]() ![]() ![]() Drives: 1LEs Join Date: May 2009
https://my.chevrolet.com/content/dam...ers-manual.pdf The brake/clutch master cylinder reservoir is filled with GM approved DOT 4 brake fluid as indicated on the reservoir cap. |
#97 |
European makes have always specified DOT4, but they also call for periodic fluid changes every 2 or 3 years. In deference to lazy American owners, the domestics call for DOT3 and don’t mandate fluid changes. Supposedly the real world performance of the DOT3 degrades less over time. I’ve read a number of technical papers on the subject.
It might be overkill, but I push at least 1/2 a liter through my brake system before every track weekend. The plan has served me well for 30 years now. I also have a lot of used brake fluid to get rid of somehow...... |
#98 | |
