Old 09-13-2019, 09:28 AM   #85
GuywithL86
Drives: Black
Manual mode in the a8 is a joke, it is so slow
You know how manufacturers always talk about shift times being lightning fast? Well what the fail to mention is how fast it is from the time you request the shift to the time it completes the shift.
The shift may be .2 seconds, but that doesn’t help much if it takes .5 seconds to initiate the shift after you call for it.
This is why you leave the a8 in auto, it aint no pdk
GuywithL86 is offline   Reply With Quote
Old 09-13-2019, 09:40 AM   #86
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
In stock form yes. But It's actually a lot faster once you tune the A8 and remove a lot of the torque management and quicken the shift times.
Old 09-13-2019, 09:45 AM   #87
RobbyBeefcake87
RobbyBeefcake87's Avatar
Drives: 2018 Camaro SS 1LE
I refuse to believe this was a real thread.
OP were you doing 0-60 runs starting in 6th gear?
2000 Miata - aventi storm wheels, roll bar.
2019 Mustang GT pp1 - svt pp2 wheels, mbrp cat back, sync 3 upgrade, p1x procharger + stg2 intercooler.
2018 Colorado zr2 - zr2 sport bar, showcase spare tire.
2018 Camaro SS 1LE - GM cai, black bowties, suede knee bolsters, 1le plate frame, black fuel door, dark tails + 3rd brake light, euro side markers + led's, GM all weather floor mats, velossatech big mouth, GM strut brace.
2017 Corvette Grandsport (sold) - untouched.
2006 GTO (sold) - iat relocation, air box mod, monero side marker lights.
RobbyBeefcake87 is offline   Reply With Quote
Old 09-13-2019, 09:51 AM   #88
bdavies11
Originally Posted by 2SS6th View Post
Major update everyone!
So had a “professional” drive the car, and he actually was a hell of a driver.
Took me around for ridiculous pulls, he was demonstrating everything, when he drove it, hd drove it perfectly with no problems, he didn’t even experience any of the lag issues. He did however show me what I WAS DOING WRONG!
I cruise in M mode in 6th gear at 50 mph, he floored it, NO PULL or POWER at all, he then dropped all the way to 2nd gear at the same 50mph, and it pulled like a mad dog. I never knew about this, he also told me that I shift a lot earlier before redline too many times to the point where I’m at 5-7th gear at 40 or less, which was another thing. I was inexperienced over it, he then explained to me about the lag in flooring it in Automatic mode, when flooring in automatic, the brief moment before it pulls, the ECU is downshifting to the lowest gear then pulling, he said it’s normal for automatic mode to have a brief delay before pulling when flooring. He also stated that when in automatic mode, you can press the downshift once, then hold it again and the car will AUTOMATICALLY drop to the lowest gear, he then floored it and it pulled! I didn’t know about the gear and speed thing. After all this, there’s still one last thing... there’s a “dead zone” when slightly hitting the accelerator in automatic mode.
Man, if this isn't a troll post, kudos for the OP for admitting his mistakes and willingness to learn but honestly, if you don't understand how an engine makes power or how gear ratio's work, you have no business buying/driving this car, especially in manual mode. Please just put it in auto for now and be careful, at least until you learn to drive. You will get yourself (and others) in trouble real fast not knowing what you are doing.
bdavies11 is offline   Reply With Quote
Old 09-13-2019, 10:43 AM   #89
laynlo15
Drives: 2022 Lt1 A10
When I drove mine on the street it was fun to use the manual mode but rarely used the paddles. I have never made a pass down the track and manually shifted it and I know it would be a slower pass as its hard to shift these cars on time stock or modified. You'll always run faster letting it shift on its own.
Old 09-13-2019, 12:39 PM   #90
Mighty Mouce
Drives: Camaro
I will change it, I apologize to all other SS owners...
Yes an Apology is needed for you allowing a car with an SS name plate to be beat by 6 banger Mustangs and BMWs.
Mighty Mouce is offline   Reply With Quote
Old 09-13-2019, 12:58 PM   #91
I can’t figure out how to delete/remove this post, I went to thread tools and still can’t find it.
You can't delete the entire thread, only admins are allowed to.
Edit the original post of yours to change the thread title.
Old 09-13-2019, 01:00 PM   #92
NA18CamaroSS
NA18CamaroSS's Avatar
Drives: 2018 Chevrolet Camaro 2SS 1LE 6M
Just turn in your man card and trade your awesome car for a Prius.
Bolt-ons.
NA18CamaroSS is offline   Reply With Quote
Old 09-13-2019, 01:04 PM   #93
^This 2x. Set up your mirrors properly to eliminate blind spots, drive very carefully, expect the unexpected from everyone else on the road. Also, don't even think about disabling traction control or stabilitrak until you mastered the car, you can kill yourself or others in a split second.
Old 09-13-2019, 02:06 PM   #94
Emoto
Sure, why not?
Emoto's Avatar
Drives: 2016 Camaro 2SS, Jeep JKU Rubicon
2nd at 21 years old
OP, you should consider yourself blessed or extremely lucky to have such a hot car at such a young age. I can't speak for anyone else here, but I had to drive really crummy cars until I was MUCH older and could afford something nice.
Someone mentioned instruction. As you learned from that guy you took a ride with, a lot of how to drive fast is about mental skills and knowledge. If you can find some kind of high performance driving school to attend, I think you would really enjoy the heck out of it and would learn a lot that would help you. You could improve your skills in a controlled environment, and I bet that some of what you would learn about how your car performs, could help you to avoid crashing on the street.
This is the sort of thing I am thinking of: https://autoweek.com/article/car-lif...complete-guide
If there are any race tracks near you, most of them have some kind of business associated with the track that does some kind of driver training, so check around.
Emoto is offline   Reply With Quote
Old 09-13-2019, 02:56 PM   #95
Rayvan
Rayvan
Drives: 2018 1SS1LE, Silver Ice Metallic
Someone please educate me on the speed and gear thing, and why it does pull, and doesn’t pull, I want to learn how to pull properly and make it most effective, and consistently.
And to pass cars more consistently as well, or even during a roll race.
It's questions like this that make me wonder how you managed to drive a BMW.
I'm still hearing my BS alarm at full-tilt...
Rayvan is offline   Reply With Quote
Old 09-13-2019, 03:17 PM   #96
GuywithL86
Drives: Black
It’s for sure bs
Nobody is dumb enough to think they have a real problem but then not try putting it in auto
Old 09-13-2019, 03:42 PM   #97
trohde78
trohde78's Avatar
Drives: '17 Red Hot 2SS 6MT
Originally Posted by GuywithL86 View Post
It’s for sure bs
+1
trohde78 is offline   Reply With Quote
Old 09-13-2019, 04:11 PM   #98
2SS6th
2SS6th's Avatar
Drives: 2017 Camaro 2SS A8
My honest thoughts on this pathetic car (sorry to other SS owners)
No, that’s when I was cruising, however I was doing 0-60’s from 1st, but never hit the 4’s this whole thread was made from my ignorance regarding the gears and power band stuff, basically issues with power from cruising/roll ons, I also stated the crappy 0-60’s I was getting because I thought it tied in with the acceleration power similar to roll ons. Yes this is a legit thread and I’ve always played with manual mode. The reason why I didn’t like automatic mode was because of the power response, obviously not being similar to manual response.
For me as a driver, I want the car to respond as I hit the pedal, similar to ZL1’s or cars with superchargers. I don’t like the car taking time to respond and pull as I hit the pedal.
I like/want instant power, or near instant.
Idk how well these A8’s transmissions are compared to the 19’s A10 SS as well as the ZL1’s A10’s, and what’s PDK?
2SS6th is offline   Reply With Quote
