Old 06-24-2019, 11:30 AM   #85
JANNETTYRACING
JANNETTYRACING's Avatar
Interesting that DI has a different Lambda target.
If you ask the internet they will tell you to run a DI engine with boost at .88 or 13.0 AFR LOL
There is a difference just not as big as the internet will have you believe.
.82 is = to 12.0 with non ethanol gasoline
www.jannettyracing.com
email tedj@jannettyracing.com
Old 06-28-2019, 03:25 PM   #86
chross12
chross12's Avatar
Drives: 2016 ss whipple,rotofab,A8,magride
WHIPPLE
chross12 is offline   Reply With Quote
Old 07-01-2019, 11:51 PM   #87
95 imp
Dumb Ass Deluxe
"You are using methanol injection....."
How much do you squirt? I understand the "your mileage may vary" depending on hp etc.
Just want a ball park.
Also, how do you know how much you have in the tank? It would really suck to turn your motor into boat anchor when you ran out of juice.
Old 07-02-2019, 02:39 PM   #88
Umbriel
Drives: 2016 Camaro SS
Kits have a low level light that comes on when it's low. The kit will only spray when it hits a certain boost level so it depends on driving but my 4th gen meth kit took forever to empty, 5 gallons would last me a few months.
Sent from my SM-G955U using Tapatalk
Umbriel is offline   Reply With Quote
Old 07-02-2019, 11:00 PM   #89
DorkMissile
DorkMissile's Avatar
Drives: DZ
For reference - my build is as noted below:
LT1 - SBE, Stock Cam, Stock Intake, Stock manifolds / headers
CA Perf Primary Cat Delete, remainder of exhaust is stock w/ NPP
ECS / Vortech Novi 1500, 9lbs of boost, Flex Tune on E85, Alky Control Meth Kit with dual 10# nozzles, stock 1LE / ZL1 low side pump, LT4 HPFP w/ LT4 Injectors
612FtLbs / 702hp
DorkMissile is offline   Reply With Quote
