Old 06-09-2020, 09:50 PM   #85
RandRZL1
RandRZL1's Avatar
Drives: 2018 ZL1
So are you planning on selling a package, with the connection pipes and the “X” pipe? Because if you are selling them individually I would buy the connection pipes now. If not how about a waiting list?
RandRZL1 is offline   Reply With Quote
Old 06-09-2020, 11:32 PM   #86
Drizzt ss
Drizzt ss's Avatar
Drives: 2017 NGM 1SS MRC NPP
Originally Posted by Speed Engineering View Post
Our x-pipe normally works with our longtubes, and due to the factory exhaust not having a connection point it requires cutting just before the muffler. We just recently made a set of connection pipes that will work with our current x-pipe, which connects just after the first cats. Those connection pipes will not just bolt up to the factory exhaust without a decent amount of fabrication. Those are now in stock, but we are waiting on our normal x-pipe kit to come back in stock. Normally, we have a pretty good idea of when they will becoming in, but unfortunately 6/26 is our best guess. The way things have been going I wouldn't be surprise if that wait time will be extended.
Thanks
Sean
For my own reading comprehension, you made secondary cat delete pipes that will fit your x and mid pipes and hook up behind the main cats. But you’re waiting for the x/mid pipes to come in to sell them together. My question is will the x/mid pipes fit right on to the factory exhaust? In my case the borla axle backs( because they hook Up right to the stock mid pipes). Or is there some fabrication involved to join them? Also your website now says eta July 24 unfortunately.
Mamo PTB /Borla ATAK NPP /Carbon Fiber lip/ZL1 side skirts/ Black Bow ties/Husky Mats/ Mishimoto CC /BMR strut tower brace/ZL-1 License relocation/Rock guards
Drizzt ss is offline   Reply With Quote
Old 06-10-2020, 04:57 PM   #87
Redlinez
Shifts under load
Redlinez's Avatar
Sorry to beat the dead horse, but any ETA or plans on a catted set up?
22 Suzuki GSX-S 1000GT blue
Old 10-05-2020, 12:35 AM   #88
mano_camaro
IYAOYAS
mano_camaro's Avatar
Drives: 22 1LE 2SS M6 Riverside Blue
How did everything come out so far for the folks that already received their xpipes?
Any soundclips?
2022 Riverside Blue Camaro 2SS 1LE/ PDR
2020 Red Hot Camaro 2SS 1LE/PDR /Sold
2018 black Camaro 2SS M6 Redline Edition/Traded
2016 summit white Camaro RS V6 M6/Traded
mano_camaro is offline   Reply With Quote
Old 05-13-2022, 04:19 PM   #89
MrNoosNoos
Drives: 2019 Camaro 2SS 1LE
Exclamation 1 7/8" to 2" speed engineering headers
So I had 1 7/8's speed engineering (SE) headers on my camaro initially. I'd get some slight rubbing on my headers (drivers side) nothing too much. I've burned 2 spark plug wires on the 1 7/8s (GM and MSD). Then I went to 2" headers, burned through my spark plug wire on the drivers side (MSD) yet again and its making a lot of noise and rubbing on the steering rack badly when I turn left, no issues going straight or turning right. Its already burned through some of the plastic guard on the rack.
What do you guys suggest doing? My builder said to try new motor mounts (OEM). Haven't gone through with them yet because I've had issues with SE headers since I got them. 1 7/8s and even more on 2".
MrNoosNoos is offline   Reply With Quote
Old 05-13-2022, 04:50 PM   #90
Redlinez
Shifts under load
Redlinez's Avatar
That’s nuts. I had no issues with my 2” TSP lt’s.
Old 08-20-2022, 09:32 AM   #91
Wintermute
Wintermute's Avatar
Drives: 2020 LT1
Silly question, but if you're having all these heat related issues, have you tried putting some heat shields on your headers or some boots on your plug wires?
Too weird to live, too rare to die.
Wintermute is offline   Reply With Quote
Old 05-29-2024, 12:10 AM   #92
ilovemusclecar
Drives: '23 LT1
Thank you guys for the business..
Adampau123: The front factory subframe has slotted holes for the motor mounts. There should be enough adjustment for you to move the engine as needed.
Thanks
Sean
Any chance of a discount for forum members on 1 7/8ths headers? I've been watching for over a year but haven't seen any sales put up. I already have your X pipe.
ilovemusclecar is offline   Reply With Quote
Old 06-17-2024, 06:59 PM   #93
19Nasty1le
Craig
19Nasty1le's Avatar
Drives: 2019 ZL1 1LE
Currently have a Corsa Extreme+ Catback on a 19ZL1 and looking at the 2” LTH, what else would be needed to mate up to my Corsa Catback? Believe the Extreme+ already had a Xpipe as it deleted the secondary cats
19Nasty1le is offline   Reply With Quote
