Old 01-19-2020, 06:44 AM   #85
bereic
bereic's Avatar
Drives: Camaro SS 2018 Convertible
all those who installed the Oxilam LED bulbs... any issues until now? Or still working fine?
bereic is offline   Reply With Quote
Old 01-19-2020, 09:36 AM   #86
Originally Posted by cmitchell17 View Post
Yeah mine worked fine. The backup lights will give you problems though, unless there is a special backup light that I don't know about. The backup light leds will stay on when there is no backup light power. They will stay very dim though, I've had mine for a few days and overnight and it hasn't run my battery down. The bcm will usually shut down anything running for that long to keep the battery from dying but it dosent work in this case.
You need a resistor for LED reverse lights, that'll prevent the dim residual illumination. Gen5DIY has a harness with a heat shield around the resistor, I've run it since day 1 and works perfect.
Old 01-19-2020, 10:07 AM   #87
warren3537
warren3537's Avatar
Drives: 2019 Red Hot ZL1 1LE: 2012 RAM 2500
I still have had no issues, I took them out of the 1SS when I traded it in for a 19 ZLE and no issues there ether.
warren3537 is offline   Reply With Quote
Old 02-17-2020, 06:31 AM   #88
bereic
bereic's Avatar
I ordered them from Amazon.. now i got these 2 bulbs in the package but 2 resistors as well?!
Did you also got them and did you had to install them?
I'm a bit confused now, as i thought they have built in resistors.
Thank you
