Old 08-20-2020, 11:29 AM   #85
Apex Wheels
Apex Wheels's Avatar
Drives: Camaro Z28
Originally Posted by 20Bluezl1 View Post
Planning on running a group deal anytime soon?
No plans for a GB but there are many Camaro wheels on sale now with more coming soon!
Apex Wheels is offline   Reply With Quote
Old 08-20-2020, 11:30 AM   #86
Apex Wheels
Drives: Camaro Z28
Jeremy's has been tearing up the AutoX courses lately with his 19x11" ARC-8 setup and 305 meats at all four corners.
Front: 19x11" ET11
Rear: 19x11" ET43
305/30-19 RE71R square
-2.7* camber front, -1.4* rear with coilovers and camber plates
- Cory
Old 09-03-2020, 02:38 AM   #87
sr71bb
sr71bb's Avatar
Drives: 2019 Camaro Z-28
Originally Posted by sr71bb View Post
OK Here are some pics of SM10's along with some pics of the actual weight of the SM10 with MS 4S 305 30 19 mounted including TPS sensors (53.4 pounds). Another pic shows the STOCK 2019 SS 20 x 9.5 wheel and MS 4S 285 35 20 mounted WITH TPS sensor (55.8 pounds) and ALSO the front Stock SS wheel 20 x 8.5 and GY 245 40 20's with TPS sensors (55 pounds).
Notes: the setup you see DOES NOT require a 5MM spacer because part of the strut mount was ground down about 6MM to allow for proper clearance. Negative camber is 1.5 degrees on EACH wheel and that for the most part eliminated the top tire poke (see pics).
The suspension is STOCK SS WITHOUT MAG RIDE. Wheel gap is roughly 2 inches currently which will be reduced to roughly 1.25 inches when the SG3 suspension is installed. This is the WIDEST rotatable combination that can be run currently on an SS. Ground clearance is roughly 6.5 inches in FRONT of the rear wheels and 5 inches in the BACK of the front wheels.
The 305 30 19 tires mounted on the 19 x 10.5 rims give you roughly 11.5 inches of rubber on the ground (section width is of course wider to the tune of about 12 inches). It is doubtful you could run a wider tire on the front without having alot of top tire poke regardless of how much negative camber you used.
Black gorilla locks were used and the stock APEX wheel cap was painted a satin black to match wheel. A big shout out to AMP (clearancing), APEX (quick delivery and superb support) and DISCOUNT TIRE (no installation damage).
I added the last pic showing where AMP modded the strut to get the necessary clearance. It doesnt take much here about 6MM.
I wanted to update this thread to provide more information in regards to ground clearance using this combination AFTER I had my SG3 suspension installed. GM documents that you should see about a 1/2 inch drop vs. STOCK suspension settings. The following comparisons were done using the THESE wheels and tires so I am lower than stock anyway because of the overall diameter of the 19 inch wheels and 305 30 19 tires.
In doing the measurements, I have 4 1/4" of ground clearance just AFTER the front tires (compared to stock 5") and 6" of ground clearance (compared to stock 6.5") just in FRONT of the rear tires. IF you use the old finger method, I have two fingers of clearance ABOVE the top of the rear tire and fenderwheel and slightly LESS than two fingers clearance above the top of the FRONT tire. That makes sense since the ACTUAL drop AFTER the SG3 suspension upgrade was 3/4" on the front and 1/2" on the rear.
I might also add that I upgraded the brake package on the car to ZL1 1LE Rotors and Calibers and I can report that even using the 15.3" front rotors and bigger SIX piston calibers, there are NO interference issues AT ALL with these wheels. Another note of interest in that the ZL1 1LE REAR calibers and rotors look to be nearly identical to the stock SS setup. Of course I wasnt expecting interfence issues either since APEX is great about testing for these things up front.
I will update with new pictures soon.
2019 SS 1LE BIG NA A10
Eagles Canyon Raceway 2.7 CCW Below
https://youtu.be/c9M5UHDftcA
4-15-23 at SCCA TT U1 Class
MEGA Thread on THIS car:
https://www.camaro6.com/forums/showthread.php?t=602092
Retired Cars BELOW:
1973 Camaro, 1969 Camaro, 1969 Camaro SS RS
2010 Camaro SS with 1000HP F1R, 2019 ZL1 1LE A10
sr71bb is offline   Reply With Quote
Old 09-03-2020, 04:57 AM   #88
Danew_377
Chief Bief
Danew_377's Avatar
Drives: Nightfall Gray Camaro 1SS
So we are going to have more wheels on sale period or more wheels on sale made to be direct fit for us...?
2016 NFG 1SS M6
JLT Intake, LT2 Manifold, LT5 TB, CSP 2" headers, AWE Catback Exhaust, Apex ARC-8 Wheels.
426whp/434wtq
Danew_377 is offline   Reply With Quote
Old 09-04-2020, 10:58 AM   #89
Pcormier66
Pcormier66's Avatar
Drives: 2019 ZLE
New shoes for track days. Arc 8 OEM size for ZLE. Will run Goodyear F13R on these and I have mich PS4S for OEM wheels. Painted in C2T Acid Orange Metallic which is the oem paint for the BMW M4 GTS wheels and splitter.
Pcormier66 is offline   Reply With Quote
Old 09-04-2020, 01:40 PM   #90
20Bluezl1
looks sharp
Old 09-06-2020, 02:36 PM   #91
JonDaddy82
JonDaddy82's Avatar
Drives: 2018 ZL1 Coupe NFG M6
Pcormier66, do you run that hidden hitch setup to pull your track gear around? If so, how do you like it?
1989 Forumla 350 WS6 <- High School
2000 Trans Am Firehawk <- After High School
2017 Colorado Z71 <- Daily
2018 ZL1 M6 <- Not Daily
JonDaddy82 is offline   Reply With Quote
Old 09-06-2020, 03:22 PM   #92
CaliforniaKid
Drives: 2018 ZLE
Apex has a good sale right now for ZLE fitment
CaliforniaKid is offline   Reply With Quote
Old 09-06-2020, 04:19 PM   #93
20Bluezl1
I saw that they are running a labor day sale but im still not sure if I want a square setup or just run 305 - 325.
Old 09-06-2020, 04:22 PM   #94
sr71bb
sr71bb's Avatar
updated pics
Here are some updates pics AFTER AMP installed the SG3 suspension. As I indicated before it lowered the front of the car about 3/4 of an inch and the rear of the car 1/2 inch. These pics were also taken AFTER AMP installed the ZL1 brakes front and rear. No clearance issues with brakes or tires.
Retired Cars BELOW:
Old 09-07-2020, 02:02 AM   #95
Pcormier66
Pcormier66's Avatar
Drives: 2019 ZLE
It's a curt hitch and yes I installed it to tow a small trailer for my wheels and misc. I've only pulled the trailer once when I picked up my painted wheels and it tows great. with a little weight on the tongue the ride quality improved, which will be a bonus for far away tracks. Trailer plus gear will be a little over 1000 lbs. I aim to keep the tongue weight less than 200lbs. Should do nicely.
With the curt hitch I did had to cut a small section of the bumper cover. About 1.25" square. It's so far under you can't see the cut.
Old 10-20-2020, 04:53 PM   #96
Apex Wheels
Drives: Camaro Z28
New 18" and 19" SM-10 fitments coming soon for you Camaro!
APEX Wheel Fitment Specs: Front: 19x11" ET11, Rear: 19x12" ET41
Tires: Goodyear 3R Front: 305/30-19, Rear: 325/30-19
Old 10-21-2020, 01:29 PM   #97
Srt-cuatro
Drives: 2017 SS 1LE
SM-10 are my favorite Apex wheels. ����
Srt-cuatro is offline   Reply With Quote
Old 10-21-2020, 03:08 PM   #98
NYblack1le
Drives: 2018 1SS 1LE
I wish they had a direct fit 19” for Camaro !!!!!!
NYblack1le is offline   Reply With Quote
