#85 |
Camaros Of Northwest Ohio
Follow. Mine started doing this as well. Called and scheduled an appointment. The service writer confirmed this problem on trucks too, and said I didn't have to demonstrate it.
Bill
2023 2SS 1LE Red Hot
2016 2SS Black / Black & Arenaline Red (sold) 2023 GMC Canyon Denali 2013 2SS / RS - AGM / Jet Black (sold) 1970 1/2 Z/28 Classic Copper / Tan (sold many years ago) |
#86 |
![]() Drives: 2016 Camaro 2SS SILVER ICE METALLIC Join Date: Oct 2016
A8 tsb
Well mine went in today for the notorious shudder! Also second time for the loose shark fin antenna, and rear deck pack rattle where the speakers are. Rattling when hitting bumps or on certain songs😡 Not happy!
#87 |
![]() Drives: 2015 2SS Join Date: Aug 2017
#88 | |
![]() Drives: 2017 Camaro 2SS Join Date: Dec 2016
The slight vibrations when stopped may just be from the engines low RPMs at idle.
I also have the extremely hard shifts from Park to Reverse or Drive. Feels like I've been rear ended about 1/4 the time. Dealer claims this is due to pressure build up in the lines. I also can't imagine this being good for the transmission or any mounts on the vehicle. As for TSBs, my car is currently at the dealership (yesterday) for replacement of the torque converter. This is GMs current "fix" for the transmission shudder while driving. I don't feel like this is a permanent fix as I believe they are only replacing with the exact same part. Unless it is a defective part it will only be a matter of time before this new torque converter is ruined. A little background I have 7,600 miles on my 2017 2SS A8. I do not have mag ride...not sure whether this makes any difference. Initial shuddering began around 2k-2.5k miles. GM flushed system per TSB. Shudder returned at approx. 6-6.5k miles. However, for the first 500 miles of returned shudder it was too intermittent to bring into the dealer. Once the shudder was consistently present Hurricane Harvey devistated the Houston area and loaner cars were a thing of dreams. I will update once I get my car back...hopefully later this week. Until then I will enjoy driving the 2LT V6 although I already miss the added power and V8 rumble. Quote:
#89 |
#90 |
![]() Drives: 1979 Corvette Join Date: Mar 2017
Recently had the flush done my 17 1SS (3.7k miles, 08/16 build) and it drives so much smoother and no more vibrations, time will tell if it holds. If your having trouble with the dealership I would recommend printing out the TSB and putting it on the desk in front of them.
I've also been reading a LOT about this issue on this forum, the Corvette forums (since they got the 8L90 before us in 2015), and the CTSV forums, and it turns out that GM has gone through 3 different torque converters for the LT1. Apparently the earlier 2 versions of the converter required a straight up replacement at any sign of shudder, but the newest version (Part #24280631 TC) is the one that requires them to first do the triple flush. There's no consensus on the cause, some suggest that GM used the wrong transmission fluid, others suggest that AFM/DOD is paired with software that pulses the converter to lock/unlock constantly to smooth out the transition from V4-V8 (with manual drivers reporting that in eco mode the V4 transition is really rough and would be a huge bother for A8 buyers if it wasn't smoothed out somehow). This theory makes the most sense, with the rapid lock/unlock causing excess wear. However, it is interesting that overall it seems like only 5-15% of cars are affected with no real rhyme and reason, and with some people even having received multiple bad converters, some having failures at higher mileage, and some having failures early on. A number of GM techs on different forums have also reported that they've done a fair number of TC replacements but it's definitely not an across the board failure situation. Just thought I would summarize for everyone what lots of research has led me to. |
#91 |
![]() Drives: 1996 z28 Join Date: May 2016
got a couple 100 miles on mine after the flush and update. 100% better. Zero vibrations and while mine never shifted "rough" it does shift a bit smoother.
#92 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: Wife's 14' IS 250 Join Date: Mar 2014
Mine still shifts like a bucking bronco Sent from my iPhone using Tapatalk
-11% tint all around Ordered • 2/06/16 Built on • 3/22/16 Adopted • 4/07/16 Sold on 2/05/16: 2014 Camaro SW L99, 2SS, RS, NAV, Inferno Orange Interior: -Borla ATAK catback -Range AFM delete -15% tint all around -Red LED interior bulbs -55k white Cree LED fogs -License plate LED bulb swap -12" Sub Kit, BA amp swap -Oracle ghosted LED sidemarkers |
#93 |
Just got my Camaro back from the shop 30 minutes agofrom a torque converter replacement. Drove about 5 miles back to work and I have to say it shifts 1,000 times better and the vibration appears to be gone. Now, mind you with the initial flush it took a couple thousand miles to start up again.
I will have to wait until the morning to see if the shifting from park to drive is still horrible. Last edited by 17txcamaross; 10-12-2017 at 02:18 PM. Reason: torque converter replacement |
#94 |
#95 | |
Bill
#96 | |
![]() ![]() ![]() ![]() Drives: 67 goat, 69 goat ram air III Join Date: Mar 2009
Please give us some feed back. |
#97 |
Darth Martel
Drives: Black 1SS with 20% tinted windows Join Date: May 2009
I have an anonymous source at a GM test facility in Pontiac (Michigan) that told me they are testing the A8 for this issue with the torque converter and they still can't figure out what the deal is. It's good to know that it's at least being investigated but, at this point, not knowing what's causing it, after over a year and a half of complaints, doesn't give me much confidence. I'm getting mine triple flushed next week and if that doesn't fix it, I'm going to spring for an aftermarket torque converter. I love the car otherwise so, it's a keeper. I don't mind investing in it since I plan on keeping it.
2016 Black 1SS w/ MRC, low-gloss black wheels, auto trans. Self-created custom Dark Knight Edition accents. Rotofab CAI with dry filter and sound tube delete, PRAY ported intake manifold and throttle body, Texas Speed cam, Stainless Works headers and exhaust, Skid Mark garage E85 kit, JMS fuel pump voltage booster, Circle D torque converter. Custom E85/mod tune by Jannetty Racing.
#98 | ||
![]() ![]() ![]() ![]() ![]() ![]() Drives: Wild Cherry LT1 Join Date: Dec 2016
I'd really like to know what to expect long term from a GM on this issue. Many people, including me, drive very few miles ( 4750 6/3/2016 build date) and store their cars for 50% +/- of the year. Meaning we could be out of warrantee when and if a TQ issue does arise. This could easily turn into a 8 speed class action suit, which would be unfortunate. If GM can't or won't permanently fix rattling NPP systems, I'm not holding out hope that a "real" fix will occur for the TC's. I truly hope that I'm wrong, on both counts. |
