#85 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2020 SS 1LE (previous: 2017 SS 1LE) Join Date: Mar 2012
Wise choice sir ^^
#86 |
Went back and tested 3 modes now that I feel pretty comfy with the car. Here's my impressions:
PTM Sport 1: seems the safest choice, as it retains both the Stabilitrak and TC, but at an expense of some pace IMO. The car felt a bit restricted on both rotation and exits in comparison to the next 2. But one can still drive the car very fast in this mode - just proly not as fast the the next two. Comp Mode (Track mode then press TC once): retains Stabilitrak but shuts off TC - it was faster than the one above and felt a lot less restrictive but one needs to modulate power on exits as 100% is available. The car still felt somewhat restricted on rotation, but overall pace was faster. Note the rear feels looser as you have access to full power with your foot. Since the car has good torque, it can overcome Stabilitrak easily and wag the tail (and/or spin) if you decide to drive it like a hooligan. This mode is an old "advanced" nanny mode, before GM introduced PTM and is defo more "advanced" than PTM Sport 1 (IMO). PTM Race - No Stabilitrak but TC remains on, albeit in the least restrictive fashion as compared to Sport 1 or 2. The car rotates in a fantastic fashion and is easily modulated with throttle. But if you over do it there is no Stabilitrak to save the day. Exits feel very composed yet fast, as TC works in concerts with E-LSD in very seamless fashion. This is the fastest mode save for "all off" (albeit GM Engineers will argue Race is faster if used properly - see my OP), but one has to have knowledge and experience regarding proper "weight transfer" principles (balance/traction) as the rear will come around if you don't, or make a mistake and unbalance a car. No, miracles don't happen and trying to corner on 1 front wheel will always result in a spin Use at own risk, read the official manual, get proper instruction, etc. Results may vary based on a driver, type of track, etc. When in doubt, turn nannies up: it is no fun going home on a flat bed. Cheers! EDIT: cleaned up original post Last edited by TrackClub; 06-29-2017 at 11:31 AM. |
#87 |
updated my OP with PTM info as presented by GM engineers, for each mode. VERY informative and must read, including how to properly use steering angles to get most out of the PTM Race setting (especially valuable to those that may experience push/understeer on exits - wink, wink, nudge, nudge
#88 |
![]() ![]() ![]() ![]() Drives: ZL1 1LE Join Date: Oct 2016
One must wonder, for how optimized PTM Race is for the given tire, how might a stickier tire affect its functionality.
#89 | |
same principles would still apply tho re steering angles to "feed" info to PTM re power distribution vs slip angles allowed. which should translate to faster pace. guessing tho
#90 |
![]() Drives: Sold - Krypton Green 1LE Join Date: Sep 2016
The only thing I would think you can optimize for a tire is a spring rate. Grip changes all the time even with the same tire like between a green track after a downpur and fully rubbered in after some competition a day before.
#91 | |
"M1SS1LE"
Drives: 2017 SS 1LE Join Date: Dec 2015
#92 |
Ya I don't think tire type has much effect on PTM or Comp Mode as they work based on yaw/slip angles and traction levels as far as I can tell. So clearly a stickier tire will simply produce more pace.
#93 | |
![]() ![]() Drives: SW 1SS 1LE / Jeep XJ Join Date: Mar 2016
More infor on eLSD modes
#94 |
Thanks for posting these. The same info is in the manual but good to have it all together nevertheless. Cheers!
#95 |
cleaned up and updated by OP. my thanks to SeanBlurr for "motivating" me via another thread
#96 |
![]() Drives: 2017 SS 1LE Join Date: Jun 2017
With all the options and combinations what is the best to use to achieve the best 0-60 times? lol.
Turning all the nannies off (hold for 5ish seconds) allows for to much wheel spin. So I am assuming using launch control with Sport1 or Sport2 or Race? Suggestions?
#97 | |
#98 |
Added PTM table to OP so all the info is all together now.
