Old 08-02-2017, 03:31 PM   #85
PinHead
Drives: Duramax
Originally Posted by Zach495 View Post
Mine was crap, 505 torque, not a happy camper
Your car probably has the NYS Turnpike Detune...j/k
An engine performance can improve after break in
If you haven't already send an engine oil sample to Blackstone for analysis.
I'd also do a cylinder leakdown check.
IMHO, If the tests are positive you can pursue a warranty claim.
PinHead is offline   Reply With Quote
Old 08-09-2017, 12:50 PM   #86
djfury05
djfury05's Avatar
Drives: 2017 ZL1 A10
Just got back from the dyno. Sunny and 98°F 60% humidty in Corpus.
2017 ZL1 A10:
- 1520 miles
- Bone stock
- 32psi in tires
- DynoMite Dyno outside no fans
- 93 Shell gas
- 549 rwhp/539 rwtq SAE
djfury05 is offline   Reply With Quote
Old 08-09-2017, 03:28 PM   #87
17CamaroZL1
Life's Short, Live Fast!
17CamaroZL1's Avatar
2017 ZL1 A10:
- 1520 miles
- Bone stock
- 32psi in tires
- 93 Shell gas
Nice numbers for an auto. Especially in that temperature
12/26/2016 Ordered!
2/8/2017 Built!!
3/2/2017 Brought Home!!!
Old 08-10-2017, 12:07 AM   #88
Zeke.Malvo
Zeke.Malvo's Avatar
Drives: 1969 Mustang MaCh1
SAE corrects for temperature.
1969 Pro-Touring MaCh 1 - CHP 427w 10.8 comp - 3140 lbs. - 460 rwhp / 490 rwtq
T56 Magnum || 14" 6 piston front / 13" 4 piston rear Wilwood brakes || Hydraulic clutch || 9" Detroit Locker || TCP Coilovers || Forgeline Wheels 18x10 275/35 front, 19x12 325/30 rear
Zeke.Malvo is offline   Reply With Quote
Old 08-14-2017, 12:17 AM   #89
cwebster
Cal
Drives: 2017 6th Gen Camaro ZL1 Coupe M6
Originally Posted by PinHead View Post
Thanks Cal,
What type of Fuel and Octane rating where you running>
At the time of the dyno run and up until a few months ago I was running straight 93 octane pump gas (E10 - 10% ethanol). Now I run ethanol-free 93 octane gasoline (aka recreational fuel). Can't be sure if it makes much difference, though. Because of the heat, humidity, and DRs my ETs have been slower overall.
If I can get someone to follow me to the track with my truck next visit I'll try running out all my pure gas, cool down, then give it a slurp of the E10 and see what happens on the same day. Pure gas should be better because it takes higher compression (more boost), more fuel volume, and tuning to take advantage of the ethanol. Otherwise it just dilutes the gas.
--Cal
cwebster is offline   Reply With Quote
Old 10-10-2018, 08:22 PM   #90
1st 2019 ZL1 Dyno
https://www.camaro6.com/forums/showp...&postcount=106
Old 08-07-2022, 07:29 AM   #91
Xelor
Drives: 2022 ZL1
Any 2021 or 2022 on the Drums?
Xelor is offline   Reply With Quote
Old 08-07-2022, 10:16 AM   #92
JSH
JSH's Avatar
Drives: '20 ZLE
575/598
2020 ZL1LE A10.
100 octane: 1045hp/1055tq.
Old 08-07-2022, 11:18 AM   #93
Xelor
Drives: 2022 ZL1
JSH are those numbers stock?
Old 08-07-2022, 11:49 AM   #94
Gunkk
Thank you Al Oppenheiser!
Gunkk's Avatar
HPE's custom long block <-- probably has something to do with it.
Old 08-07-2022, 11:50 AM   #95
Schlok
Schlok's Avatar
Drives: 2015 Z/28 #397 2022 ZL1 #1799
My car made 540/570 on the dyno, 6 spd. Only 200 miles on it...
Schlok is offline   Reply With Quote
Old 08-07-2022, 12:21 PM   #96
JSH
JSH's Avatar
Drives: '20 ZLE
Yea, totally stock baseline DynoJet pull
2020 ZL1LE A10.
Old 08-07-2022, 12:49 PM   #97
Camaro1973
Camaro1973's Avatar
Drives: 2019 ZL1
Its in STD, subtract 3-4%.
550ish (SAE) is pretty much what almost all 10speeds make, given the temp during the pull.
LME 377 LT4 Short Block | Magnuson 2650 80mm upper w/13% lower (9.06) | DSX Lid & Valve Covers | CSP Custom Cam w/32% fuel lobe | CID Heads | NW 103mm TB | Roto Fab Big Gulp | CSP 2" Headers w/Green GESI Gen 2 Cats | Borla 3" Full Cat Back w/ S-Type| Mighty Mouse Wild Catch Can| Custom Holley Low side Fuel system| TooHigh PSI Port Injection w/Holley Controller | Forced Inductions Interchiller w/2 gallon fender tank | TK Performance built 10L90
Old 08-07-2022, 12:59 PM   #98
Mike is laying down the law, as always. 598 rwtq stock means a happy/uncorrected/miscalibrated dyno.
