Old 11-21-2017, 01:52 PM   #85
Jason@JacFab
Send a message via AIM to Jason@JacFab Send a message via MSN to Jason@JacFab
Diff swap! (Installing an LSD manual trans differential into an Auto trans car)
Originally Posted by cooper1965 View Post
Yeah, I have been tossing this around a lot. I would love a stall, but the extra work sucks. Rear diff swap would be much easier.
Actual part costs I figure to be about the same if comparing a used diff to having a converter built.
Tuning would be more difficult for the stall.
Improved ET , I would give the edge to gears..
IDK, I would love to see some opinions
I bet a stall would cost more than a used diff. Circle D charges $1200 (plus core exchange) for an 8l90 converter... I'm guessing roughly the same, as long as custom crap isn't needed for an 8l45, so figure $1200, plus you'd have to provide them with a core 8l45 converter to the tune of about $~350...
I like the idea of a 3800-4000ish stall converter, but as it is, I can't even launch at max stall on the stock converter at the drag strip. Of course, I attribute a lot of this to my ghetto drag tires. A guy would have to have some good tires to properly utilize a higher stall converter at the track.
The tuning probably isn't bad. My G8 has a 3000ish stall converter, and tuning changes were minimal to get everything working properly.
*edit* well I sent circle d an email, they're considering the 8l45 custom at this time, and the custom department is booked up until spring time, they said to check back then.
Old 11-23-2017, 11:02 AM   #86
ChicagoTommy
Drives: 2017 Camaro; 2017 Acadia Denali
You might want to look into Yank, as they are significantly cheaper for restalled stock-ish style converters. I know you could get their 4th gen 4L60 Street Converter for under $500.
I was looking in the V8 section recently and noticed that Circle D is no longer requiring the use of a stock core. I believe they have a full billet piece now.
This is in no way a personal attack or confrontation, and is not necessarily the view
of the management or sponsors, and the thoughts contained herein are mine,
and is not intended to hurt anyone's feelings or ruin their delicate self esteem, or
to invalidate anyone's personal views or thoughts, nor is it a condemnation of anyone's
race, religion, sex, sexual preferences, handicaps, or intellectual abilities.
ChicagoTommy is offline   Reply With Quote
Old 05-23-2018, 11:35 PM   #87
dpelow07
Drives: ats
any updates on converters, or has anyone tried the gm 3800 ltg stall? Not sure if that will work with stock trans
dpelow07 is offline   Reply With Quote
Old 08-26-2018, 01:27 PM   #88
cooper1965
Coopers Camaro
cooper1965's Avatar
Drives: 18 Flex Fuel LTG
Joining the select few. Should have this done Thursday, and I am pretty exited! Double thanks to Jason for this thread!!
Flex Fuel tuned by me using HPT-:-
---My Build Thread---
-----My IG PAGe-----
Old 08-09-2023, 02:37 PM   #89
jacekpuzio
jacekpuzio's Avatar
Drives: Camaro 2.0T 2020
Are 2.0 MT and 3.6 MT both 3,27 and both have LSD?
jacekpuzio is offline   Reply With Quote
Old 08-09-2023, 07:04 PM   #90
Bumbleboy92
Long hauler
Bumbleboy92's Avatar
Drives: 2022 Camaro 2SS 1LE
Only the manuals have LSD for LT’s
2.0 T has 3.27 non-LSD
2.0T & 3.6 Manual have 3.27 LSD
If you want more info, here’s my chart: https://www.camaro6.com/forums/showthread.php?t=584316
2016 1LT v6
- Totaled
Happiness: Infinite
Old 08-10-2023, 07:25 AM   #91
jacekpuzio
jacekpuzio's Avatar
Thanks a lot 👍🏻
