Old 09-04-2017, 01:52 PM   #85
glamcem
glamcem's Avatar
Drives: '19 RivrsdBlu 1LE ('17 1LE HB sold)
Originally Posted by finney84 View Post
How do you fit the 18mm socket on with the 6mm Allen key in the way holding the stud?
You can either use open end sockets or offset wrenches so that you can use the 6mm allen key through it. Once you tighten the inner 6mm bolt a little bit it should stay in place and you can torque the outer 18 mm bolt
glamcem is offline   Reply With Quote
Old 09-04-2017, 11:55 PM   #86
finney84
Drives: 2017 ZL1 A10
Dumb question, does 6mm bolt tighten up by turning clockwise or ccw with the Allen key?
finney84 is offline   Reply With Quote
Old 09-05-2017, 01:04 PM   #87
glamcem
glamcem's Avatar
should be clockwise
Old 09-06-2017, 09:19 AM   #88
JusticePete
Drives: Camaro Justice
Originally Posted by mr965 View Post
I took Pete's suggestion and got the NordLoc but no LocTite. So far so good. No rattling. Thank you Pete!
You are welcome.
Originally Posted by Infern0 View Post
This seems strange to me. It appears most are stating this will repeatedly break loose, and the GM bulletin is simply re-tighetning it, which is just a bandaid on the symptom versus fixing the issue. So it's GMs intent to simply re-tighten this thing until the warranty expires or what?
GM is looking for a better long term solution, but we already know what that is
LocTite and Nordloc are a bit like belt and suspenders, but we don't like to fix the same problem twice
JusticePete is offline   Reply With Quote
Old 09-07-2017, 12:51 PM   #89
mike'SS
mike'SS's Avatar
Drives: Gen 6 Camaro 2SS M6
I started to hear the clunk noise after i lowered it. is it just a coincidence that this started to happen or is it because i lowered it?
mike'SS is offline   Reply With Quote
Old 09-13-2017, 07:26 AM   #90
skydvr8029
Drives: 2018 Camaro SS 1LE
Same issue
I have a 2018 SS 1 LE and had to take it back to the dealership to have it looked at. After about 1000 miles on the car I started to hear the same noise from the front left. It appears a bolt had loosened. It was a 30 minute fix but seeing all these post about the same issues has me concerned.
skydvr8029 is offline   Reply With Quote
Old 09-13-2017, 08:26 AM   #91
JusticePete
No need to be concerned a drop of Loctite and a Nordloc washer on each of the four endlink studs is a permanent fix.
Old 09-16-2017, 06:04 PM   #92
JusticePete
Originally Posted by Lt1z350 View Post
Well shit mine are tight so need to keep looking and see what's clunking. It's getting worse so something it loose somewhere in front end.
See below.
So took it all apart tightened everything ball links ball joints tie rod ends then retorqued wheels to 110 and noise is gone. Everything tightened allittle but nothing really loose. The right lower ball joint did take over a turn which was a little freaky. Stuff settles aluminum gets hot and cold stuff gets loose so not going to say it's GMs fault for this. I drive it very hard so it's expected for stuff to get loose. Just glad it's quiet again and nothing is bad.
EXACTLY! We'll done sir.
Old 09-16-2017, 06:53 PM   #93
2SSRS@Gen5diy
2SSRS@Gen5diy's Avatar
Drives: 2014 Z/28 #82+#192, 18ZLE 66Nova
Originally Posted by JusticePete View Post
See below.
I have a small mouse living in my car, any time I go over a bump he speaks. Lol
2SSRS@Gen5diy is offline   Reply With Quote
Old 09-16-2017, 06:58 PM   #94
JusticePete
Introduce the mouse to your new pet cat.
Old 09-16-2017, 07:25 PM   #95
2SSRS@Gen5diy
The mouse is in the cat, ZL1LE.
Old 09-16-2017, 07:26 PM   #96
2SSRS@Gen5diy
Do you think it's the metal to metal of the struts in the car?
Old 09-30-2017, 06:46 PM   #97
ScottMZ3
ScottMZ3's Avatar
Drives: 2018 ZL1 A10, 2019 BMW X5
My new 2018 ZL1 with 402 miles just started making the clunk. Have an appointment on Wednesday morning to get the end links tightened. How is this still an issue on 2018s??
2018 Nightfall Gray Metallic Camaro ZL1 - A10
Purchased 9/23/2017
ScottMZ3 is offline   Reply With Quote
Old 10-01-2017, 06:44 PM   #98
MAGAUSA
MAGAUSA's Avatar
Drives: 2017 Hyper Blue 1LE
I've noticed this in my parking garage on occasion. Seems not a fix to just tighten. This also is not normal for a car to do this. Using loctite or the nord lock may work.
Anyone with aftermarket end links have this issue? I'd rather go that route if there were good alternatives.
MAGAUSA is offline   Reply With Quote
