09-16-2017, 10:56 PM | #85 |
Drives: 370z, Srt-6 Join Date: Aug 2017
Just my thoughts, I'd like to see a z28 with the new 1le zl1 features minus the blower. Keep it at 500 hp ish n/a with the wider wheels, more aero and the upgraded suspension things of that sort. I know it wouldn't be likely due to the fact gm won't have more power than the stingray but I think it would be a cool alternative to the actual zl1 1le
09-17-2017, 03:28 PM | #86 |
Drives: Silverado Join Date: Dec 2016
I think they might debut their new DOHC engine line in the Z/28, and I hope they developed a 427 for the Z as well as a replacement for the LS7 Crate motor. Get it spinning to 7000 and hook it up to a 10-speed. 550-575hp and that ZL1 1LE body would be a killer combo, especially if they work some weight reduction magic. 3500 lbs. sounds about right
09-17-2017, 07:18 PM | #87 |
Drives: Pre-production ZL1 M6 Join Date: Feb 2016
Can someone explain to me why Z28 fans want LESS horsepower in an engine than what is already available?
09-17-2017, 07:45 PM | #88 | |
Drives: 2015 SS 1LE Red Hot, 1970 Chevelle Join Date: Apr 2012
Weight Balance Supercharging makes a lot more heat in the engine bay. The LT4 weighs more. It puts the weight in the front and up higher.
09-17-2017, 10:16 PM | #89 |
Not to mention the cost and weight of cooling for the LT4 and its torque curve. A higher rpm motor is better with higher gear transmissions. The LT4 doesn't spin that fast and is therefore better off with a manual than the 10-speed whereas a 7500+rpm DOHC motor would take advantage of the 10-speed.
Less weight over the front axle means better steering response and allows a car to carry more speed through turns. Gutting a ZL1 1LE and dropping in a DOHC 427 would make for a better handiling and more responsive car with reduced brake distances and temperatures, and the car could fly through turns better than anything on the market. Did anyone mention that every Z/28 is N/A? |
09-18-2017, 01:35 PM | #90 |
Poppycock
Drives: Pontiac GTO Join Date: Dec 2013
09-18-2017, 03:03 PM | #91 | |
Drives: Slow Join Date: Mar 2016
You mention less weight, but do you think that a dohc 7.0 would already weigh more than an ohv di 6.2? The 5.0 coyote is already physically larger than the ls3 6.2. I get that larger doesn't necessarily mean more weight, especially when you take into consideration the extra cooling/fluids, but I wonder too how much weight is really being saved at the end?
2016 Toyota 4Runner
2017 Camaro ZL1 |
09-19-2017, 12:40 AM | #92 |
A DOHC 427 would probably weigh more than the LT4.
09-19-2017, 06:40 AM | #93 |
@zle_blackwing
Drives: 2018 ZL1 1LE Join Date: Mar 2017
With the weight being up high due to the valve train.
09-19-2017, 08:32 AM | #94 |
Does anyone one have the weight of the lt4? We know the weight of the SB4 it's 498lb with out Accessory drives.
09-19-2017, 09:45 AM | #95 |
You could make that same statement about every Camaro built before 2012.
09-19-2017, 09:56 AM | #96 |
09-19-2017, 09:59 AM | #97 |
Drives: Sold Join Date: Mar 2017
09-19-2017, 11:24 AM | #98 |
Poppycock
