#85 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2022 CT4-V Blackwing Join Date: Sep 2013
Agreed. Owned 25 cars in SFL, including a gen5 I just replaced. None have ever done this. There is a very low humidity threshold required for this issue to pop up. If it is early morning and humid, get ready for the condesation right away. If it is hot and sunny, mid day usually it is dry enough to keep the crop circles minimized or nonexistent. If it has just rained, forget it you are in for some giant condesation crop circles. If it is a muggy evening be prepared to swipe your wipers every minute or so.
2013 Camaro SS 1LE - Black - M6 - Sold 2016 Camaro SS - Mosaic Black - A8 - Sold 2017 C7 Stingray - M7 Coupe - Sold 2019 C7 Grand Sport M7 Vert - Sold 2021 Camaro ZL1 - Black - A10 - Sold 2019 Tesla Model 3 2022 CT4-V Blackwing - M6 |
#86 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: Love the one you're with Join Date: Sep 2009
The average dewpoint in the deep south is around 73degf. That means that any surface below that temp will condense moisture out of the air onto it. Running the evaporator temperature a little higher could keep the outside of the windshield from getting that cold even though air is bypassing the vent. Sorry, but this is an interesting problem for me as air conditioning and refrigeration are my business. We have it happen in older homes with lousy windows and the supply vents are installed under them. If it can't be fixed by controlling the evaporator temperature, I can't see this being and easy fix without gutting the dash. Keep us posted OP. My ZL1 purchase may hinge on this getting fixed along with some of the other issues going on with
this car. Edit: can you guys measure the supply air temp coming out of that vent and report back? I would like to compare it to my ZL1 and a couple of my other vehicles. |
#87 |
![]() ![]() Drives: 2016 Camaro 2SS Join Date: Mar 2016
ive been driving 28 years and many many many cars. I have never experienced this issue with any other car
2016 Hyper Blue 2SS A8,NPP,Moonroof
Pray ported factory intake manifold Ported TB Rotofab ARH 1 7/8 longtubes hi flow cats AFM deleted E85 11.0@124.9 11.65@118.8 pump gas,stock tune/exhaust New combo: Pray Performance Heads/cam MSD intake manifold and Circle D 3C 554/491 on E85 all work & tuning done by Pray |
#88 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: ‘16 1SS & ‘19 1LT Join Date: Aug 2012
#89 |
![]() Drives: 2017 Camaro 2SS Convertible Join Date: Jun 2016
Just to put some facts with all of the statements out there, here is a photo of my fogging. This was a typical morning in Missouri this summer - 78 degrees, 100% Humidity, dewpoint around 74 - Auto Climate set to 72 degrees. It never gets any worse than this no matter the time and/or temperature and, based on my seating position (I'm 6'3"), it does not block anything except some of the hood. Had the exact same issue on my 2013 Cruze and 2014 Cadillac CTS and have the exact same issue on my fiance's 2011 F150...
2SS Convertible, Mosaic Black, Red Hashmark, Adrenaline Red Interior, A8, NPP, MRC, 56R Wheels 6/6/2016 Dealer entered order 6/7/2016 Received order # TMXWV0 - Status 1100 6/11/2016 Status 3000 6/22/2016 Status 3400 - TPW 6/27 6/29/2016 My car is born!! 7/13/2016 Status 4300 7/14/2016 Status 4B00 7/18/2016 Status 4200 7/25/2016 Status 4800 7/29/2016 Status 5000 - Drove home!! Last edited by tcbracing; 08-12-2016 at 02:56 PM. |
#90 |
Tampa Bay Camaros
Drives: '16 Hyper Blue 1LT Join Date: Jul 2016
Here is mine the day I dropped off my car. Approx. 8am, low 80s, near 100% humidity, dew point in the mid 70s. Standard Florida morning 8 months of the year.
This is where the "core" of the foggy area settled. It was larger when I first started driving before adjusting temp/vents/etc., eventually got it 'smaller' and contained. Still partially blocked my view. Notice how the sun on the left side of the foggy area causes it to go from semitransparent to solid; you can't see the Equinox at all. Out of direct sunlight, the right side, you can at least see the taillights of the Cobalt sitting there.
2016 Camaro 1LT | V6 | A8 | Hyper Blue
#91 | |
Pills are for Pansies
Drives: 2023 2SS Red Hot Vert Camaro Join Date: Jul 2008
#92 |
![]() ![]() Drives: ^^^This Join Date: Nov 2015
Anybody considering the Lemon Law route? Seems like the fogging could be dangerous in certain circumstances, which in my opinion is unacceptable. Ill definitely be testing my HVAC all weekend just in case.
#93 |
Look like real issue with this car. Not everyone is 6'3" that could be right in the sight lines of a shorter human. |
#94 | |
![]() ![]() ![]() ![]() Drives: '16 2SS GD1 MX0 NPP F55 IO6 Join Date: Jun 2013
Be mindful of your daily humidity before you go out on a long drive -- especially at night. If the humidity is above 55-60%, I hope the temps are low enough outside in VA that you can turn off the AC or possibly even run the heat. |
#95 | |
Tampa Bay Camaros
If I get it back and it's still like it is in my last picture... it's a definite possibility.
#96 | |
dew point noun the atmospheric temperature (varying according to pressure and humidity) below which water droplets begin to condense and dew can form. |
#97 | |
![]() Drives: 2016 Camaro SS Join Date: Jul 2016
Either the mode valve actuator is not fully moving the door closed or the door is binding which is not allowing the door to fully close. Scan tool would confirm this. The technician also presumably monitored upper duct air temp with the scan tool to verify the cold(er) air is reaching this ductwork to verify the diagnosis of the complaint. It is assumed the technician monitored the HVAC control module and possibly saw the sensor signal is not changing or the mode valve actuator has not moved to the commanded position. This is either a hardware fault or software issue with the controller in the automatic operation mode. |
#98 |
![]() ![]() Drives: 2023 ZL1 Convertible, 1998 Z28 Join Date: Jan 2013
Just got mine back from 2 months in the shop, for other reasons, and this was the first thing I noticed.
2023 Rapid Blue ZL1 Convertible
