#85 |
Looking to get a set soon, going with 10/11 graphite combo. It is my understanding spacers are needed to fit a stock 2016 SS. Do the spacers come with the wheel or where can I get them?
#86 | |
Id be more then happy to talk fitment with you, pricing and guide you on tire sizing and such that is appropriate for the car. Let me know. |
#87 |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2016 2SS Convertible Join Date: May 2012
Some people running a square setup with 10" wheels and 285 tires report needing a spacer on the front to keep from rubbing. There are a few threads about it if you want to search a bit.
#88 | |
For instance all the 275/35/20 & 285/30/20 tires clear the strut, so im curious to check it out so ill research it. |
#89 |
![]() ![]() ![]() ![]() Drives: 2019 Dodge Challenger Scat Pack Join Date: Jun 2016
I've seen a lot of those threads because I'm interested in that setup as well but nobody ever mentioned rubbing. The spacers were always related to squaring the wheels from front to back based on the differences between the front and rear hub faces. If there is a thread about 285s rubbing please point me to it. I have been looking at this and chatting with the wheel manufacturers and forum members for months.
"Submariners are a bunch of intelligent misfits that somehow seem to get along, understand each other and work well together." - overheard from a surface officer explaining to another sailor about Submariners
#90 |
#91 |
Ok cool. If you could, pm me a quote for the 10" front and 11" rear wheel setup. Thanx
#92 | ||
![]() Drives: 2017 Nightfall Grey Auto 2SS Join Date: Mar 2012
He is correct NO spacers will be needed with the tire sizes listed. |
#93 |
285/30/20 & 305/30/20 is a safe bet for staggered setups no issues guys.
#94 |
SABIO
Too much misinformation and misunderstanding on the use of spacers.
With custom wheels such as these, they are designed to fit properly. No spacers needed. Tire size has little to do with spacers, you buy a tire to big it will rub / hit with or without spacers. If you buy an off they shelf wheel with an offset that is to high, you will need a spacer to push it out away from the suspension. Then you have those that want to keep everything 'square' within a MM or so and use thin spacers to line everything up. The use of spacers...the proper use of spacers....will open up hundreds of options when it comes to wheels
#95 | |
#96 |
Ok great...dont see the pm quote for price as I asked earlier yet....
#97 |
#98 |
| Tags |
| camaro wheels, mrr m017, mrr wheels, need 4 speed motorsports |
