#85 |
![]() Drives: 2016 2SS Join Date: Sep 2016
For what it's worth... 25mm spacers all around gives 1/4" of poke front and rear (with the stock split spoke wheels). 20mm should sit flush. Wish I'd gone 20mm, but will do 'till new wheels. Thanks for the info. Lots of help on what to expect with shaving the studs. My old 370z wheels just bolted on without help, so I would have been lost without the "heads up".
#86 |
Deadpool
Drives: 2016 camaro lt rs m6 redhot Join Date: Sep 2016
Damn hank your car looks great, a few quick questions did you use spray or brush on paint for the calipers and what pecentage is your tint
#87 | |
![]() ![]() Drives: 2016 Corvette Z06 M6 Join Date: May 2009
2013 Dodge Viper #44/150 Launch Edition IG:@absoluthank
20/21 BC Forged Wheels : BC Coilovers: TA Aero |
#88 |
I used a combination of a higher quality conventional brush and a 1" foam brush on the flatter surfaces. The brush supplied in the kit is garbage. The windows are tinted at 20% sides and rear
#89 |
Deadpool
Was there a need for spash guards with the wheel spacers
#90 |
Honestly, ALL stock Gen 5 and 6 Camaros get lower body road rash, particurlary on the bottom of the rear fender/rocker. I had mine Clear Bra'd right after I bought it. I also added side skirts in lieu of splash guards. But SOME sort of protection is necessary, stock or with spacers IMO
#91 |
Deadpool
Thanks hank,guards will probably be my first purchase for the car,dont know who would be able to do clear bra in my area,guess ill check in the regional forums
#92 |
![]() Drives: Chevrolet Camaro SS Join Date: Mar 2015
Now that you've had the GM suspension on for a few months, have you gotten the full 20mm drop and is the ride still stock like?
No bounce or floating feel? When you it bumps they absorb them rather than going over them? It's a pricey kit, but I like the idea of struts designed for the spring to react properly to compression and rebound. Anything other than stock is a compromise once the spring rate changes. This for the reply, look forward to your review. |
#93 | |
Big Samoan ina little car
Drives: 2016 camaro Join Date: May 2014
When I see posts asking "whats the best intake, exhaust, etc" .... the answer to that is like a grandfather telling his grandkids "if you put salt on a birds tail, it'll let you catch it" #ThinkAboutIt "Winning Tip: Don't take my (or anyone else's) word for it. GO TEST IT!" - Dennis Grant |
#94 |
#95 | |
The ride was awesome. Definitely wasn't floaty, but was firm and predictable. I didn't have a lot of seat time in my car before I made the switch to this kit, but I remember it being just about like stock.
#96 | |
#97 |
![]() Drives: 2016 2SS M6 Join Date: Jun 2010
I can affirm the GM Kit rides virtually identical to stock. I got it for this reason, as opposed to just lowering springs, which alone take the stock struts/shocks out of their optimum range of travel.
#98 | |
The GM kit isn't cheap, it's actually more than cheap coilovers, but I know those suck and have limited testing to get the right valving and instead rely on overly stiff springs and adjustable valves. Thanks for the review |
