Old 02-03-2017, 01:53 PM   #85
AlphaCamaro7
AlphaCamaro7's Avatar
Drives: 2016 Camaro 2SS, NPP, A8, FBO, E85
Originally Posted by Benb View Post
Why isn't anyone using Launch Control in your cars????
Launch control? On the V6? Lol
Well............ At least you tried. lol
AlphaCamaro7 is offline   Reply With Quote
Old 02-03-2017, 01:55 PM   #86
AlphaCamaro7
Originally Posted by PhillyGuy15 View Post
5 flat? Wow that is an amazing improvement from 5.3 with just a throttle controller. I may have to pick one up
Yea first couple times I had to get the hang of the tire sliding because of sp9 mode which is insane to control but once I got the tires to stick at 80 percent throttle it was a piece of cake after that.
Old 02-03-2017, 03:10 PM   #87
Michigan1LTRS
Blessed ❤️
Michigan1LTRS's Avatar
Drives: 2017 1LT RS I4
nice!
Old 02-03-2017, 07:51 PM   #88
cellsafemode
cellsafemode's Avatar
Drives: 2016 Camaro 1LT
you dont need actual "launch control" features to just launch under control. Grand Tour guys pretty much called it the single most useless gimmick sports car feature invented in recent history.
Old 02-04-2017, 08:10 PM   #89
Benb
Benb's Avatar
Drives: 2016 1LT RS
Oh you're right, very much a gimmic. I used to work for VW and back when the r32 released with the same idea...but that was a dual clutch. (practically a whole building banged on that poor trans because a lot of people wanted to try it, but it held up after a 3 day event lol)
Benb is offline   Reply With Quote
Old 02-04-2017, 08:13 PM   #90
Benb
Benb's Avatar
Drives: 2016 1LT RS
Yep.
The one and only time I recorded it with an Rode external mike...I just like hearing it over and over, saves on the trans
Old 06-27-2017, 11:52 AM   #91
Abrown3118
Drives: Summit White 2017 RS V6 A8
Fastest for me so far. 5.6. stock. A8. Cincy Ohio. 20' tires. launched from 2k with some tire spin.
Abrown3118 is offline   Reply With Quote
Old 06-27-2017, 03:13 PM   #92
DougCBJ
Drives: 2016 Blue 2SS
Why don't i have this performance timer option? This only for the 2LT models (v6)?
DougCBJ is offline   Reply With Quote
Old 06-27-2017, 03:26 PM   #93
Michigan1LTRS
Blessed ❤️
No you have it. You have to select it so it will show up.
Old 06-28-2017, 01:09 AM   #94
lopezangel886
Drives: 2016 v6 camaro rs
Originally Posted by ussj4brolli View Post
The timer starts if you go above IDLE no matter how hard you are breaking it
You have to break and gas then when timer starts just reset it while still holding the pedals then release the brake to launch so you get a good 0-60 time.
I have the m6 so it's a little different, the timer doesn't start unless the car actually moves. The best I've gotten is 6.0 flat with a little bit of tire spin.
lopezangel886 is offline   Reply With Quote
Old 06-28-2017, 01:28 PM   #95
jingaling
Drives: 2016 Camaro 1LT V6 MT
What's a good rpm to launch at? =D
jingaling is offline   Reply With Quote
Old 07-03-2017, 11:30 AM   #96
Jason@JacFab
Send a message via AIM to Jason@JacFab Send a message via MSN to Jason@JacFab
Thanks for that idea about resetting the timer just before/as you start to move... I haven't actually tried that yet. I know I lose anywhere from .4-.6 on an average launch on that timer because it starts counting as soon as it leaves idle.
My best times in my 4 cylinder car on the dash timer have been around 4.4-4.6, but when checking 0-60 on an external source(s) it's closer to 3.9-4.1 on a real good launch.
Old 07-03-2017, 11:53 AM   #97
Zack46
Zack46's Avatar
Zack46
Production Sequence Number 98
NEOCC Camaro Club Member
Old 07-07-2017, 11:50 AM   #98
Jason@JacFab
0-60 Time
Thanks for the idea on the reset trick! Best time yet, shaved .2 off my best without doing it. But it still translates to 4.05 seconds in my hptuners log... With practice maybe I can get the dash timer closer, but that's a lot of messing around just to get it "right"
