01-28-2016, 03:38 PM | #85 |
Drives: 2022 F150, 87 Monte Carlo Join Date: Mar 2015
Doesn't the SS already top the GT350, with the GT350R coming out slightly on top mainly due to very sticky tires?
01-28-2016, 03:39 PM | #86 |
01-28-2016, 03:46 PM | #87 | |
#becauseracecar
Drives: 2016 SS Sedan, 2016 Camaro SS Join Date: May 2015
1) The gen 5 had a lower hp engine with the auto and was already at a decided performance disadvantage. The 6th gen with the 8 speed is as quick if not quicker than the manual. It is already a better platform to build on than the 5th gen auto 2) The 3rd and 4th gen autos were pure garbage and no one at that time would try to run an auto as a hard core road racer. With the 6th gen, there is a distinct possibility that the auto will be every bit as good of a road course car as the manual will be. Never thought I would say that but that is a very good reason to finally offer the 1LE in an auto. Not that I want it to happen, but for the first time it might make sense. |
01-28-2016, 03:57 PM | #88 | |
Speed Freak
Drives: 2013 ZL1 Camaro, 2016 Camaro SS Join Date: Jun 2013
Tires are a huge difference but you can bolt on whatever tires you want right now. I haven't found the thread yet but I'm sure someone with access to a few different rims and tires has messed around and figured out how big a tire you can get on the car, and it is much bigger than stock sizes.
2016 SS -AGP twin Borg Warner 7163 EFR's, LT4 mechanical pump, LT4 injectors, Walbro 255 low side, Castrol SRF. 734whp/759 tq
2013 ZL1 -ADM - 427 LSX 6 bolt, O-ringed block built by LME. Twin PT6466 turbos. RPM custom manual trans, RPS Quad carbon clutch, 9" Hendrix rear diff & axles. ADM/squash fuel system, Ron Davis radiator, Spal fans, AGP air to air, turbo plumbing. LPE oil cooler, rear bushing upgrade, roll bar...etc. rwhp 1400+... 212.5mph, best Texas mile to date. |
01-28-2016, 03:57 PM | #89 |
Drives: 1999 Firebird Formula WS6 455ci LS7 Join Date: Nov 2009
I can not see why not. In the past handling was better with the manual transmission. Today the autos blip on the downshifts and can shift faster than a manual. The Z06 has it as an option. It would be dumb of GM to ignore the A8 with the 1LE.
In fact I am going to see if it is offered before ordering a car. I would wait for the 1LE, my current DD is fine and paid for, but an auto is a must for me in a DD. Too much city traffic driving. Plus I have a M6 LS7 4th gen to play with in the garage when I feel like shifting. I regret not ordering the 1LE when I ordered my 99 WS6 Formula in 98. I was asked and said no, as I wanted power windows and a T roof. Hindsight, should have done it.
1999 Firebird Formula WS6 - 455ci LS7
01-28-2016, 04:10 PM | #90 |
Drives: 2015 SS 1LE Red Hot, 1970 Chevelle Join Date: Apr 2012
My feelings on an auto 1LE aside, I don't think we will see one because we never saw one being tested. We saw a manual test 1LE but both an auto and manual Z**.
01-28-2016, 04:12 PM | #91 | ||||||||||||||
I used to be Dragoneye...
More in the news: Two of your site moderators will be attending an early-bird sneak-peek of the car before the show opens to the public. We'll have all the details ready for you as soon as the presentations are over, so stay tuned. If you would like to know anything in particular, let me know - I'll make sure to include it in my questions if I haven't already! Quote:
The most important upgrades were suspension tuning developed during ZL1 engineering - and applied to the lighter, naturally-aspirated SS. It transformed the car into a track animal that could hang with the best in its class at SCCA tournaments. And that deserves a pause, too, Magnetic ride control is NOT legal in many racing circuits...the 1LE's mono-tube dampers were. It destroyed a then-gen Mustang Boss 302, and handily beat the same Laguna Seca edition - which was (like the current GT350) supposed to be Ford's track-focused offering. All for $3500. The wheels alone, retailed for $4000. It was, and is a bargain. The car essentially performed like a "Z/28 lite". It had the same transmission and differential gear ratios, the same square wheel/tire setup...the same balanced handling, and a similar weight. It's a wonderfully composed and responsive car to drive on a track. If you don't track your car, though...then it probably was not a worthwhile option set. Because for $3500, all that really changed in appearance was the wheels, brake calipers, and the hood. Quote:
The fact that the standard SS model can do what it does...with so little in the way of performance equipment, speaks mountains about what a 1LE COULD do. Let's assume that they take the same approach this generation that they did last: touch everything but the engine... Think about it: The current SS can pull .97 G's. The 5th gen 1LE could pull 1.01. The current SS does it with not especially aggressive Goodyear Eagle Asymmetric tires, using 245 up front and 275 in the rear. What might happen if Camaro team equipped it with a square and wider setup using a stickier compound? I expect it could reach 5th-gen Z/28 levels of grip. Yes...I said it. But this isn't all about numbers. The 1LE FELT great to drive. The '16 SS still suffers from minor understeer at the limit. This is a good thing, and the limit is much, much higher than the 5th gen. But what if that was tuned out? I think the neutral balance they could achieve at this weight level would be astounding. How might the car accelerate with a taller differential gearing? What if they incorporated a cold-air intake and adjusted the engine tuning...465hp 480?? What if they used bigger brakes, like the 6-pot accessory upgrade? Could it stop later and become a track warrior? Look at what's currently available as accessory parts for the car - what if they include the lowering kit as part of the package? What are the spring-rates like? Would the 1" lower CoG significantly improve weight transfer while cornering? What if they adjusted the aerodynamics just enough to increase downforce and provide some more stability at high speed? Would it be able to corner at higher speeds? What if they swapped out some components with HD units to ensure it would pass a 24-hour track test at Milford...like they did with the Gen 5 version? I'm certainly not in charge, but if they did this right...I think they could make a Camaro that performed nearly as well as a 5th gen Z/28...for 4,000 - 5,000 dollars over the price of a standard SS. They'd be able to beat a GT350, make a GT350r sweat...and steal all of the thunder because it's so cheap...again. Then consider - the ZL1 or Z/28 or whatever it is they're working on....would be even FASTER. I don't know about you all....but I'm ridiculously excited for this!! Quote:
The 6th-gen SS does feature standard brake cooling ducts, thankfully. Quote:
But unfortunately, one of the biggest factors in this decision is going to be factory cost limitations. If you offer it with both transmissions, you need to accommodate (in pricing) for double the possible build variations. They might do it, for all the reasons you stated above. I believe the Z06 Vette is available as an automatic (but it also likes to overheat, so I've heard) Then again, they may not...because most people buying the package will want a stick, anyways. Maybe... |
01-28-2016, 04:13 PM | #92 |
Drives: Camaro-future Join Date: Dec 2015
No brainier. Will be on the auto
01-28-2016, 04:16 PM | #93 |
17 ZL1 what a car....
I hope so
2017 ZL1 -- WHT - A10 - PDR - NAV
Mods: Kooks 2", Lingenfelter 9.17 18% Pulley, CAI, E85 sensor, and Interceptor Wide-band & Gauge with Pod, 180 Thermostat, BMR Rear suspension parts. |
01-28-2016, 05:02 PM | #94 |
Drives: Want a gen 6 Join Date: Jan 2013
I'm sorry, but if these are the new zl1/1le wheels, I love them!
I would definitely regret not waiting. |
01-28-2016, 05:49 PM | #95 |
01-28-2016, 05:56 PM | #96 |
Dodges all the cones
Drives: Soon Join Date: Sep 2015
01-28-2016, 05:59 PM | #97 | |
--kC |
01-28-2016, 06:01 PM | #98 |
#becauseracecar
