10-08-2020, 11:42 AM | #85 | |
Drives: 2017 SS 1LE, 2016 1SS (previous) Join Date: Apr 2016
On the SS 1LE and ZL1, the front wheels (10"wide with 20mm offset) causes a positive scrub on the tire (inside of tire). I would assume the ZL1 1LE is the same or more-so and an SS of LT/LS car close to zero. I'm talking factory wheel specs here. You can see this for yourself - clean off you front tires, roll onto a lightly dirty, flat surface and turn your car's steering wheel through it's full rotation. Roll the car back and look at the tire contact patch. Negative toe, negative camber and positive scrub up front = a recipe for highly accelerated wear to the inside of the tire. Zero toe, negative camber and positive scrub up front = a recipe for lesser accelerated wear to the inside of the tire. Toe is a very significant component to tire wear. |
10-08-2020, 11:53 AM | #86 | |
I run -2.7 and am pretty happy with that on the SS 1LE on-track. I think -3.0 would be great on-track, but I can see, though, from looking at my tire's inside edge after street driving on -2.7 that I am running on the very edge of the inside tread. I ran approximately -2 in my 2016 SS and a friend runs about that in his SS. From my observations in on-track tire wear, I suggest going more up front. |
10-08-2020, 12:22 PM | #87 |
what is the most you should be able to get up front without camber plates?
10-08-2020, 01:54 PM | #88 | |
On a stock SS 1LE, can be -2.5 to -2.9. On a stock SS, around -1.8 to -2.2 (I think MRC strut housings allow a bit more over non-MRC). |
10-08-2020, 02:03 PM | #89 |
lowering springs and aftermarket shocks lol ok thanks ill have em see what they can do next time
10-08-2020, 02:57 PM | #90 | |
1LE Convert
Drives: 2018 ZLE Join Date: Apr 2017
2016 Porsche 911 GTS (Racing Yellow)
2002 BMW Spec E46 race car (Lizard Green) Previous cars: - 2018 Camaro ZL1 1LE (Red Hot) - 2018 Miata RF GT (Machine Gray/Auburn) - 2017 Camaro 1SS 1LE (Summit White) - 2008 BMW 135i (Montego Blue) - 1996 BMW 328i (Arctic Silver) |
10-08-2020, 02:59 PM | #91 | |
Drives: 22' Porsche PDK GT4 Join Date: Mar 2018
I used to be at -2.5 front and that was even better, but I wasn't able to maintain the toe settings at -2.5, so I went back down to -2.3
Current:
22' Porsche PDK GT4 (MCS 2-way remote dampers) Previous: 18' NFG 2SS 1LE (ZL1 1LE solid rear cradle bushings & Corsa Exhaust) 16' F80 M3 (Ohlin R/T Coilovers) 13' Audi TTRS (APR Stage 1, MSS Springs) 09' C6 Z06 08' E90 M3 06' 335i (KW V2 Coilovers) 03' C5 Z06 |
10-08-2020, 05:21 PM | #92 | |
EDIT: I want to add that there are dynamic reason for non-neutral/non-zero scrub, so don't look at non-zero scrub as "bad" and seek to neutralize it from a wear standpoint. Sometimes pictures are better than words: Last edited by Mountain; 10-08-2020 at 05:34 PM. |
10-08-2020, 09:10 PM | #93 |
Last weekend, by my own shortsightedness, I ran out of tire while at Atlanta Motorsports Park (AMP). I had higher wear on the inner fronts than I saw as I missed a spot already starting to cord. I knew this weekend was it for the tires but I thought I would make it through. Anyway I saw that it wasn’t meant to be and hooked up with Race Analytics to flip the tires on the rim. The tire was smooth on the outside and not tracking or driving in the rain so no major concerns. I was surprised by what I felt. There was zero difference. So if you do run aggressive camber or toe out and don’t daily in rain you can flip the tires for maximum usage. Cost to flip was $50 trackside and helped me finish the day.
10-09-2020, 10:03 PM | #94 | |
Drives: 2020 SS 1LE (previous: 2017 SS 1LE) Join Date: Mar 2012
F toe in will make a car a bit tighter overall, so more stable at high speed and especially under hard braking. But a wee bit more sluggish on turn in. In high speed corners one wants the car to take set (and be on a throttle) before an apex, so not sure that toe plays a big role here per se. Speaking of an SS 1LE specifically (bone stock with 2.6F and 1.6R camber) ive run my 17 with F toe out, but currently running my 20 with zero F toe and can't really tell a balance difference on turn in. But the car is more stable under hard braking. So, in my case, i do prefer a zero F toe. Plus a tire wear benefit to boot. Cheers! |
10-10-2020, 11:05 AM | #95 | |
But same here: I've run minor toe out before, something between 1/16 and 1/8, and switched to zero without much notice in the car's ability in respect to steering input response. Never seemed to have an issue with braking stability in either case as well though. |
10-10-2020, 02:03 PM | #96 | |
10-12-2020, 10:34 AM | #97 |
going to get new tires put on this weekend and my spl toe rods gonna see if i can get some more camber in the front what are you guys running for camber in rear -1.5 ?
10-12-2020, 11:13 AM | #98 |
L8ap3x
-2.5 up front.
-2 rear Stock SS |
