10-05-2023, 11:12 AM | #85 | |
I mean I just put a 6-in turbo inlet wire screen cover on it so I don't know what else I can say other than the fact that it's 6 in or 152mm reducing to 112mm.
'20 ZL1LE A10.
LME 390, E2650, FBO. 1116/967. 15" conversion/Weld/MT ET Street R 325/50R15. 100 octane: 1.35/9.25/151 at 3500 ft. (only one pass so far). 100% meth/100 octane: Alky Twin 10+10 MAF; No dyno or ET. |
10-05-2023, 12:00 PM | #86 |
Gents
What matters is I.D. not O.D. and the BG necks down to 4.5” through the MAF as Jason posted much earlier in this thread. I didn’t believe him so I pulled my filter off and measured it myself with my calipers. It is indeed 4.5” internal diameter. So having the 6” filter is all well and good, but the intake is only as strong as it’s weakest link. I think there is room for improvement at higher power levels.
10-05-2023, 12:07 PM | #87 | |
'20 ZL1LE A10.
10-05-2023, 12:25 PM | #88 |
fo'shizZL1
Drives: 2017 ZL1 Join Date: Aug 2017
Yeah, i understand ID is what matters. Just was comparing on OD, as im pretty sure that was apples to apples with what JSH was looking at.
I had no idea the maf cross section was 4.5", btw. I agree with the weakest link, but will say that due to some research with air compressor intakes, I know that even with a small orifice or a neck down in diameter, the larger pipe nets more intake flow. Friction factors and mass flow area are in play I imagine.
2017 ZL1 M6 Black | Maggie 2650 // 103TB // Big Gulp // CSP LT's & Ultra Cats // JMS // Elite Ultra CC // BMR MM // BC Forged KL13
Past Rides- 2014 ZL1 M6 Red Hot | Tons of mods 2004 CTS-V M6 Silver | Many mods 1995 Corvette M6 Torch Red | A few more mods 1992 Camaro M5 White | A few mods |
10-05-2023, 12:32 PM | #89 |
Drives: 2017 Chevrolet Camaro ZL1 Join Date: Jul 2018
This is our current prototype with a 5.5" ID from bellmouth to TB. We are going to play with bellmouth size, and as mentioned, blocking the bellmouth in so most of the air is pulled from the headlight opening rather than the engine bay. As soon as we put it on the throttle body started to get forced closed.
2017 ZL1 - PB 7.85 @ 175 MPH @ 3682 lbs @ 1313 DA (work in progress)
Built by Vengeance Racing, tuned by Elite Tuned |
10-05-2023, 12:46 PM | #90 | |
You're pulling so much more air than the rest of us making your situation unique. Btw, one of my insulated intercooler lines runs thru the intake route just behind the headlight and the air blew the insulation off of it on my first jaunt with the ram air headlight mods. It's getting more air now. I'm now wondering if the RF is useless.
'20 ZL1LE A10.
10-05-2023, 01:03 PM | #91 | |
I don't think the RF is useless in most applications. I'm fairly certain I would suck a stock air tube closed with this setup now. Lol
10-05-2023, 01:37 PM | #92 | |
2016 NFG 1SS A8
10-05-2023, 04:55 PM | #93 |
fo'shizZL1
Jason, off topic- are your coil packs mounted on the firewall, I assume? Looks clean.
10-05-2023, 04:56 PM | #94 |
Thanks and yes they are.
10-05-2023, 06:15 PM | #95 |
Tuners always have to be right
'20 ZL1LE A10.
10-10-2023, 03:40 PM | #96 |
Using the second tune for this setup, the boost increased 1# to 20.1 and the total manifold pressure to 32 (+1#). So, the air intake mods (ram air, headlight backing, bellmouth, RF area seals) made since my last run in April 2023 have done some good. I plan to make some hits at the strip on the 20th, and we'll see.
'20 ZL1LE A10.
10-10-2023, 04:26 PM | #97 | |
Having FUN in the SUN...
Drives: 2022 M6 ZL1 1LE Join Date: Jan 2022
Thats great feedback JSH... I am taking a better look at my RF set up now also...
2022 M6 ZLE: Katech Standard Ported Blower + Ported Heads + 103mm TB + Oil Pump + C5R Chain + Valve Covers + Coil Relocation Kit
TSP VVT and DoD Delete Covers + LME Chain Guide + DSX Billet Lid + ATI Damper + 9.17" Lower + 2.4" Upper + MM Wild CC + RF BG Coated AR Headers + GESI UHO Cats + V Bands + AWE Touring + Magnaflow Center X + MSD Coils + Banks iDash + JMS Booster ALL the BMR Read End Goodies + BMR Motor Mounts + JRE Terminator Cam Package + FIC 30 + DMS Front HX + Fender Tank GMS High Flow Impact Bar + GMS Stage II Oil Cooler + GMS Stage III HX System = 770rwhp 815rwtq @E55 13.5psi |
10-10-2023, 05:43 PM | #98 | |
Drives: 19’ ZL1 A10 / 16’ C7Z M7 Join Date: Apr 2021
https://www.lethalperformance.com/wh...9-0017-rc.html Last edited by CamOnlyJabroni; 10-10-2023 at 06:34 PM. |
