02-25-2023, 04:58 AM | #85 |
Drives: 2012 Chevrolet Camaro l99 Join Date: Aug 2020
Thanks bud.
DSS FX Forged Pistons, Eagle ESP L19 Forged Rods, ARP Head and Main Studs, TSP PRC 260 CNC Ported Heads milled .030, Cometic .040 Head Gaskets, GPI SS3 VVT Camshaft, GM Performance Racing Lifters, CHE Trunnions , Molly Pushrods, Melling 10355HV Oil Pump, Cold Air Inductions CAI, Fast LSXR Intake Manifold, Nick Williams 103 TB, TSP 1 7/8" Longtubes with 3" TSP Exhaust, ZL1 Fuel Pump, Mishimoto Radiator, Mishimoto Oil Cooler, Tru Cool 40k Tranny Cooler, 3600 Circle D Converter, Fluid Dynamics Balancer
Build Thread https://www.camaro5.com/forums/showthread.php?t=609817 |
02-25-2023, 05:34 AM | #86 | |
GPI Sales Consultant
GPI Max Package 2.0: Brodix BR7 heads/GPI porting, MAX3 cam, ST2116LSR, BSR Max Lift rockers, LS7 LSXR with 103mm TB, Vararam OTR, Mcleod RXT, G-Force/Strange 9" IRS setup with 4.63 gear. 551whp, 11.1@124mph.
Got a question about a GPI product? Feel free to shoot me a message! |
02-25-2023, 08:47 AM | #87 | |
02-25-2023, 08:34 PM | #88 | |
Drives: 11 Camaro V6 RS, 03 BMW Z4 Join Date: Oct 2013
02-27-2023, 08:24 PM | #89 |
Thank you sir.
02-28-2023, 05:56 AM | #90 |
Drives: 15 Camaro 2SS M6 Join Date: Jan 2020
02-28-2023, 07:43 AM | #91 |
Oh he was just one of the instructors.
03-06-2023, 01:46 AM | #92 |
A few new pictures from Sunday's meet.
03-06-2023, 04:42 AM | #93 |
Looking good. Where is that at? My stepson lives in Georgetown and could stop by and check things out if timing ever works out.
2014 Camaro SS L99, Ashen Grey w/Black Leather - Build thread - http://www.camaro5.com/forums/showthread.php?t=491561
Mods - GPI 416 w/Custom Grind Cam, Ported Heads & Tuned by Ben, Holley Dominator ECU, Mag Heartbeat, ZL1 Fuel Pump & DSX Aux Pump, NW 103 TB, FIC 1650's, Alky Meth, Circle D 3600 Triple Disc, Kooks Headers, Viking Coil Overs & all the BMR Goodies in the rear, Zl1 3.23 Diff, DSS Axles, Gulfcoast Driveshaft, Hendrix Offset Diff Bushings, AFE Solid Subframe Bushings, 875HP/843TQ 5FDP |
03-06-2023, 05:21 AM | #94 |
That was actually right next to Georgetown in Hutto at Tint World. We do the Pistons on the Square in Georgetown every month usually and the Round Rock Car Show. Tell him to come say hi sometime. We're C3 Car Club.
03-16-2023, 12:56 AM | #95 |
Well I noticed a couple months ago that I had a couple drops of oil on the garage floor and I thought oh great a darn oil leak. So fast forward a couple months later and it turned into three or four spots. So it looks like the rear main so I take it to the shop to get the rear main replaced and well it still leaks. I think it's actually coming from the rear of the pan gasket.
Does anyone agree that your supposed to use gasket sealer on the corners of the pan where it meets the rear main cover and the same for the front cover?
03-16-2023, 05:22 AM | #96 | |
04-14-2023, 10:04 AM | #97 |
A couple updates. First off I had the rear main replaced and it still has a drip or two from the back of the pan. My thought are when they put the pan on they did not use any silicone on the corners of the pan where it meets the rear cover. Now I'm going to have to try and get them to replace the pan gasket with sealer this time which will probably be like pulling teeth but I'm gonna try. I could do it myself, but I don't feel like I should have to.
I did my second autocross and felt a lot more confident then the first time and did do a lot better. But I found my limitations of the car. The front definitely seems heavy because I don't know if it's the grip on the tires or what but if I take a corner too fast then it plows over the front tires when braking. I tired lowering the tire pressure a little bit but on noticed a little bit better. Now I think it's about time to hit the drag strip.
04-14-2023, 11:42 AM | #98 | |
EDIT - I see the aftermarket wheels - if it's already square then rear swaybar is step 2 on the understeer. Just be careful, to get a big heavy car real neutral for auto-x is likely going to leave it pretty aggressive for higher speed corners!
Got a question about a GPI product? Feel free to shoot me a message! Last edited by acammer; 04-14-2023 at 12:37 PM. |
