07-17-2022, 06:01 AM | #85 |
I promise you crank case ventilation is critical. Yes I was running a lot of boost when I broke mine but we weren't venting the crankcase properly and with at least 16 lbs of boost on a stock Lt1 the seals just won't handle it and cylinders 1 and 8 couldn't either.
07-17-2022, 09:25 AM | #86 |
Or you can just add LT4 fueling and a splash of E and enjoy ZL1+ power levels anyway.
07-17-2022, 09:27 AM | #87 | |
07-17-2022, 12:54 PM | #88 |
Drives: 2020 LT1 M6 Join Date: Jan 2016
The thing is, that is the only thing the coyote has going for it: handles more boost stock. The MT-82 connected to that coyote is one of the worst transmissions i ever drove. Compared to the camaro, the s550 handles like crap. The coyote makes no torque under 5K rpm. The fit and finish was god awful on the new gt I test drove in 2020. Some body part gaps were large enough to kick a field goal through. What good is having a more boost friendly engine if everything else that it is connected to is sub par? I'm happy a SBE LT1 will handle 7 to 10 lbs safely when fueling is set up right. If more is required, drop-ins or a shortblock can sort you out.
07-17-2022, 06:17 PM | #89 |
Old badass
Drives: 14GMC 2.9 16GMC Turbos 2020Silv.6.2 Join Date: Mar 2020
I do like the 4 valves but love wasting them from a stoplight in my work truck.
I've had 7 Camaro's. All gone...for now.
Current build in progress 2016 GMC4x4 RCSB twin hair dryers ~1k whp fbe port inj 1/8 mi & stealth street terror |
07-18-2022, 04:04 AM | #90 | |
Drives: 2016 Camaro 2SS Join Date: Apr 2018
07-18-2022, 12:12 PM | #91 |
Yeah I'm one of those people that does not find any sort of enjoyment owning/driving an automatic sports/muscle car. I could care less about it being quicker than a manual, might as well have a Tesla if that was the point. As far as what they are doing right, it's pretty simple: advertising.
07-18-2022, 04:51 PM | #92 |
The Coyote isn't as bullet proof as the internet makes them out to be. They need oil pump gears above 700-750whp, then they can make some big power. Changing oil pump gears in a Coyote is almost as labor intensive as drop in rods/ pistons in a LT. I do agree they have the edge with boost as they should. It's physically a much larger engine overall. One look at the heads and it's pretty clear that with a power adder they can flow more air.
That doesn't mean the LT can't handle boost if done correctly. I have been FI for 4yrs and have over 100 dragy pulls logged in my app not including what I have deleted. The biggest mistake on this platform is not spending money on fueling and using meth as supplemental fuel. The SBE LT1 doesn't like that combination. That isn't to say Meth doesn't work, it's just there is little room for error such as improper distribution on this engine.
2016 NFG 1SS A8
07-18-2022, 07:18 PM | #93 | |
07-18-2022, 07:57 PM | #94 | |
Drives: 1SS Summit White 6 speed Join Date: Jul 2017
Pardon my ignorance but what would be a good way to properly vent my crankcase ? I'm installing LT4 fueling soon and probably turning up the boost a few #'s
16 1SS M6 White
Magnuson 2.3 Heartbeat Roto Fab Solo Performance Cat deletes and Axleback Hurst short shifter #'s coming soon Riaction coilovers 1LE sway bars BMR mm BMR chassis brace Flow one 19" wheels wrapped in Mickey Thompsons 02 Z28 M6 35th anniversary 80k miles T-tops Leather Bolt ons Joy to drive this classic every day! Daily Driver |
07-18-2022, 07:59 PM | #95 | |
This is in the works Just need a few more parts....also tuner is like 6 weeks booked haha
16 1SS M6 White
07-18-2022, 08:57 PM | #96 |
07-18-2022, 09:08 PM | #97 |
Drives: 2018 Chevy Camaro 1ss Join Date: Nov 2020
I'm currently running the Metco valve cover breather and it seems to be working well. Several hard pulls and no blown seals!
07-18-2022, 09:27 PM | #98 |
Old badass
Will that pass inspection or remove b4?
