10-17-2017, 04:36 PM | #85 |
Drives: SS 6 speed of course Join Date: Jan 2016
maybe a non-intercooled Maggie....
10-19-2017, 12:35 PM | #86 |
Drives: 1968 Camaro SS 350 Join Date: Nov 2015
No sir this is the intercooled Maggie
1968 Camaro SS 350 Lemans Blue
-350 10.4:1 comp, Edelbrock Etec 200 heads, Comp XR288HR cam,AED750dp worked, Tremec TKO 600, console gauges w/tic toc tach, Moser 12 bolt, 4 wheel Willwoods Hyper Blue 2SS/6 speed, NPP, MRC, Nav, 5LQ 6 piston brakes, Black split spoke, Magnuson 2300 Heartbeat Supercharger, Flowtie upper grill |
10-19-2017, 01:50 PM | #87 |
Drives: 2016 1SS Hyper Blue. Join Date: Dec 2016
Hey 1968ss350, have you had any issues with the Maggie or with the car since going with boost? I have to say that 470 rwhp sounds pretty low compared to what they advertise. However, I’m not looking to squeeze every bit of hp I can get. I’d be happy with a 100 rwhp gain.
10-19-2017, 10:30 PM | #88 |
Drives: 2015 C7 Z06 M7 Join Date: Dec 2012
The first "canned" cals from magnuson ended up pretty rich on some cars, they have since been corrected. Did you contact Magnuson with the issue?
A custom tune is the best way to go if you want the max power from your combination though...
10-19-2017, 10:49 PM | #89 |
Does anybody know if you can run a very conservative tune with the LT4 blower kit? Can the tune and psi level be tuned down to say 6-7psi? Trying to play it safe as possible for a daily driver. I want boost but don’t want to go crazy with it.
10-20-2017, 06:57 AM | #90 |
My original SCT handheld Power Enrich was off on mine, Mike corrected that quickly while I was on the dyno. Then it kicked some ass at 544/559 on the next pull on 93 octane. Then we went out and ran 10.91@129 on the first pass and 10.82 on the second on the handheld tune. Not bad I would say. We progressed just a little from there.
10-20-2017, 07:40 AM | #91 | |
2016 NFG 1SS A8
10-20-2017, 12:28 PM | #92 |
Drives: 2019 CTS-V Join Date: Feb 2016
Andy’s tune puts out 8psi. Which from what I understand is pretty conservative.
10-20-2017, 01:36 PM | #93 | |
That being said, ADM's base kit is designed to make 8psi with stock exhaust.
2016 NFG 1SS A8
10-20-2017, 01:49 PM | #94 |
What psi would be considered “safe” to run on the LT1 stock internals? I’ve heard horror stories about guys throwing a piston at only 10psi, however, I think that has to be a tune issue more than anything.
10-20-2017, 05:02 PM | #95 | |
10-20-2017, 06:10 PM | #96 | |
Drives: Black 2017 Camaro SS 1LE Join Date: Dec 2016
I did see a 2016 SS get a maggie installed and it popped on the dyno just over 500hp so sometimes it's the luck of the draw.
2017 1LE SS Black - Mods - Forged - lowered compression - BTR custom Cam - Whipple, 3.500 upper and 8.0 lower pulley, Roto-Fab, 1 7/8 Kooks headers, off road pipes, & 3" Kooks full exhaust. LT4 fuel system, with Alky single nozzle running 100% meth. (not installed yet) DSX Tuning flex fuel and DSX tuning Aux pump
10-20-2017, 07:19 PM | #97 |
Blowing at just over 500hp had to be a defect from the factory. That’s scary though because you never know. That’s exactly why I’m worried. 😬😬😬. I can’t afford to spend $6500 on a supercharger and then have to spend thousands more on a factory defect I didn’t know about.
10-20-2017, 07:48 PM | #98 | |
2016 loaded 2SS
Drives: Maverick X3 Turbo R Join Date: Feb 2015
stay n/a if you're so worried. if you want to play you need pay. |
