| View Poll Results: Who has experienced an oil pump failure? | |||
| 2016 or earlier |
25 | 14.88% |
| 2017 |
57 | 33.93% |
| 2018 |
77 | 45.83% |
| 2019 |
4 | 2.38% |
| 2020 |
4 | 2.38% |
| 2021 |
1 | 0.60% |
| Voters: 168. You may not vote on this poll | |||
Thread Tools |
#911 |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2020 Corvette Stingray Z51 Join Date: Aug 2011
Just bought a '17 (4/17) with 14k on it and this is my number one sweat issue. One thing I haven't seen yet is a DIY walkthrough of the replacement procedure. I'd be tempted to put it up on jacks in the garage and replace it proactively before we get to spring just as a precaution and for peace of mind. I have some marathon trips I'd like to make in it this summer.
![]() 2020 Corvette 2LT Z51 2017 ZL1 A10: (SOLD) || 2017 2SS M6: (SOLD) || 2014 2LT Convertible: (SOLD) || 2010 2LT M6 Supercharged:(SOLD) || 1987 IROC-Z 5.0 M5: (SOLD) |
#912 |
![]() ![]() ![]() Drives: 2018 ZL-1 Join Date: Jan 2018
#913 | |
#914 | |
#915 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2018 Hot Red ZL1 Join Date: Nov 2010
Can someone share some insight into what they do when they replaced the oil pump? Meaning what else is replaced? Do they have to flush the coolant out and then refill? I suppose new oil and oil filter is needed. What else is also changed? Does the SC need to be removed?
Sent from my moto g(7) power using Tapatalk
#916 | |
![]() ![]() ![]() Drives: 2016 Camaro 2SS Join Date: Apr 2018
#917 | |
#918 |
![]() Drives: 24 Sliverado 1500 ZR2, 2017 ZL1 Join Date: Feb 2021
If you google up a cam change you can see the prep work you will need to do. You will need to lift the entire engine up enough to remove the oil pan to get the pump out. That's why many of the shops just drop the engine out.
I'm in the process of pulling my engine out for a total refresh prior to a major HP increase, and I can see why the shops charge $3K, which is somewhere around 30 hours for labor. In my case I do all my own work to take the edge off my 80-hour work weeks and am not too worried about how long it takes. YMMV
Finally on the way to 1K.....
#919 |
![]() ![]() ![]() ![]() ![]() ![]() Drives: Hyper Blue 2016 2SS 6M Join Date: Sep 2017
It's not too bad on jackstands, but it is a fairly involved job. I seem to recall member Oldman doing a writeup several years ago.
Baby Blue
#920 | |
#921 |
So is there a certain build date where they fixed this problem? Is it worse on the ZL1 than others?
I have 2018 SS build date 9/17. 64 track days and no issues (knock on wood) |
#922 |
![]() ![]() ![]() ![]() Drives: 2018 ZLE Join Date: Feb 2018
It seems like the earlier build dates are the ones involved for the most part, cars built in 2017 but I think its a relatively low number of cars. My car was built 6/25/18 but I don't think anyone knows for sure.
#923 |
![]() ![]() ![]() Drives: 2018 ZL1 Camaro 6M Red Hot Join Date: Aug 2013
I would like to point out that when my dealership replaced my pump under warranty, they didn't drop the engine out
It has been 6 months now, but the tech did let me back in the shop to see the damage. I remember it was on a lift and they had removed the radiator and fan assembly for more room. So, they would have had to refill coolant. They dropped the oil pan because he replaced all of the main bearings because he saw some scoring on 1 bearing. But again, they didn't drop the engine out. I have some pictures somewhere. When I find them, I will post them.
People are a lot like slinky's: not very helpful most of the time, but they bring a smile to your face when pushed down the stairs...
#924 |
PKG4U
You would think for $3500 they took it apart and a lot more
2020 Camaro LT1. Bought 10/2020 | GM PERF. CAI | GM Muffler Delete (Performance Exhaust 4” tips). | SOLD 1/2022|
2018 ZL1 Summit White | Bought 1/2022 | PDR, Recaros, Carbon Dash, WeaponX Hx System, Apex SM-10 in ZLE fitment w/PS4S Mods after Warranty “Imma keep it stock” ![]() |
