#9143 |
![]() Drives: 2011 Infiniti M56S, '04 Tahoe Join Date: Apr 2010
Better get your horsepower now before the end comes....I think it's gonna come sooner than we think.
#9144 | |
![]() ![]() Drives: C63 P31 Join Date: Feb 2010
Ford seemed to have done well with this kit. Congrats to them and I hope many Mustang owners enjoy this power. |
#9145 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2005 STi corn fed Join Date: Jul 2008
#9146 |
Your mustang is not on that list... The only one on there is a stock 2011.
#9147 |
Rice Harvester
Drives: 2014 Bright Yellow 2SS/RS Join Date: May 2008
I'd honestly take the Mustang over the BMW any day. My mother had two BMWs and they had nothing but problems at every turn.
#9148 | |
Drives: Camaro Justice Join Date: Jun 2007
Moving up the chart, I can tell you that both the Mustang and Camaro ran faster than the 2010 Pedders Camaro listed. The Camaro listing was from last fall on a 52 degree day. We tested the Mustang and Camaro on an 85 degree 85% humidity day. The temp and humidity took a toll on HP, but both cars ran faster than the posted Camaro time. ![]() The Mustang and Camaro are flirting with the Ford GT lap times. My guess is on a cool fall day with some incremental adjustments one or both might be beat the GT time. Ford GT Performance 0–60 mph (0–96 km/h): 3.3 seconds[8], 3.6 seconds[9], 3.7 seconds [10] 0–100 mph (0–160 km/h): 7.4 seconds [10] 0-150 mph (0–241 km/h): 16.9 seconds [11] Standing 1/4 mile (402 m): 11.2 seconds @ 131.2 mph (211.1 km/h)[10], 11.6 seconds @ 126.2 mph (203.1 km/h)[12], 11.78 seconds @ 124.31 mph (200.06 km/h)[13] Top speed: 205 mph (330 km/h) (electronically limited) [14] Ford would not do the calculations for us, but GM did. Using our track ready weight with fuel, fluids and driver with the RWHP from the dyno runs the Camaro will top out at 205 MPH at 6,200 RPM. I really wish Ford would have run the simulation for us, but without it we would just be guessing the Mustang top speed. Give or take a mile and hour the Camaro top speed calculation is dead nuts based on real world results compared to other calculations run at GM in other areas of performance. Both cars are faster on track than a C6 Z06. Both cars are faster on track than the elite Pro Touring Cars that ran Gingerman about a month before in similar heat and humidity. Both cars are faster than the Viper at Gingerman. We can debate forever the winner of the Mustang vs. Camaro Wars, but the reality is these are AWESOME AMERICAN MUSCLE CARS. |
#9149 |
one wheelin
#9150 | |
Mustang Hot Lap with Side Views
#9151 |
1 n the head,2 n da chest
Drives: 2002 cadillac deville Join Date: Apr 2010
deleted.
2011GT E85, Kooks 1-7/8", 3" offroad X, 2-7/8" overaxles, Roush mufflers, CobraJet intake, SCJ monoblade throttle body, drew 4.5" CAI, Boss302S exhaust valve springs, Baby CobraJet exhaust cams. 3.73 gears, lightweight 300A. 455rwhp @7800/410rwtq SAE 5000lb roller dynojet
#9152 |
![]() ![]() ![]() Drives: 2002 ws6 Join Date: Jul 2009
undebateable.
Bolt on 2002 ls1 Trans am--- 11.5 @ 121 (1.72) 2000 da
#9153 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 14 Silverado LTZ Z71, 16 Camaro SS Join Date: Nov 2009
You do realize they have track tested the cars and have shown a .1 second difference? You also have a very experienced autoxer telling you the cars are a dead heat stock or modified. Where are you getting this domination from? Now we all know the camaro is about 250 lbs heavier and slightly slower in a strait line. How can you say the IRS is being outperformed when it is a dead heat with the mustang on a slower and 250lb heavier vehicle? Take away 250lbs from the camaro and leave the mustang alone....IRS wins with both cars being equal weight....simple as that. Unless you dont think removing 250lbs could have made up for .1 in that test LOL. Open your eyes. |
#9154 |
Fast around a race track means loose. A professional driver can throw a car around the track that is loose and do it with a degree of safety. The solid axle Mustang is loose because of the solid rear axle. We can't set the Mustang as low as we would like because we bind up the rear axle forcing the inside wheel to come loose so we compromise on the CG and corner weighting.
The Camaro is much easier to drive fast on track because it has an IRS. In a straight line race we are talking about 302 pounds as a weight advantage for the Mustang with fluids and driver ready to run. 300 pounds is significant in a straight line race. I do not have the mathematical skills to convert the weights to the road course, but we are not talking about a 300 pound advantage when you are turning a corner a 1.3 gs The 300 pounds becomes a much larger number. The same is true when you apply the brakes for 100+ MPH. The real secret will be to produce an American Muscle Car that weighs the same as a Mustang with an IRS. It doesn't matter if it is Ford or Chevy that do it. A Mustang weight IRS equipped car would beat either the Camaro or current Mustang. An IRS is vastly superior for everything a car does with the sole exception of drag racing. That said, there are 9 second GTOs running with K member based IRS that are ancient by current design standards so you can drag an IRS vehicle. I own both cars. I know them both intimately. I like them both. At the end of the day I want the Mustang to have an IRS and the Camaro to be 300 pounds lighter. |
#9155 | |
Camaro & Stang Enthusiast
Drives: 2011 Mustang 5.0 in Kona Blue Join Date: Mar 2008
Bought my Camaro from Eric Hall(817) 421-7266
#9156 | |
Go Blue!!!!!
Drives: 2012 Cruze LT Join Date: Mar 2009
I've said it once and I will say it again. when it comes to the 5.0 and SS it's about the drivers and not the cars. Some 5.0 owners want to continue to spread the myth that the 5.0 has topped the SS. From an overall perspective, it is obvious that is not true.
| Thread | Thread Starter | Forum | Replies | Last Post |
| Camaro VS Mustang Mega Thread | Beau Tie | Chevy Camaro vs... | 3644 | 03-09-2012 07:45 PM |
| Gran Turismo 5... No Camaro? | 5thGenOwner | 5th Gen Camaro SS LS LT General Discussions | 111 | 12-06-2011 10:06 AM |
| Official 2011 Mustang GT info released | nester7929 | General Automotive + Other Cars Discussion | 81 | 12-28-2009 03:13 PM |
