#9101 |
![]() Drives: Garnet Red / ZL1 1LE Join Date: Apr 2016
Gorgeous! Twinning here!
#SAVETHEMANUALS
#9102 |
Nothing. Still thawing out from 6F, snow, ice, etc. in Denver
2020 ZL1LE A10.
LME LT4 390 short block, CID Heads, Kong E2650, FBO. 15" conversion, Nitto 555Rii or MT ET Street R or Toyo Proxes RR. 100 octane: 1045hp/1055tq. 100 octane + Alky MAF Meth (1) 10+: |
#9103 |
![]() Drives: 2018 Camaro SS A8 "Dark Knight" Join Date: Oct 2019
Must be global warming
DARK KNIGHT
2018 SS A8 11.37 @ 121.01 GPI Tuned E85 Nitto tires Roto Fab CAI MSD intake |
#9104 |
![]() ![]() Drives: 2021 Camaro LT1 Join Date: Sep 2020
92f here the last two days.
#9105 | |
Drives: '21 Wild Cherry ZL1 Join Date: Aug 2018
I plan on doing mine. Maybe a game of “I’ll show mine if you show me yours.”? Fun times! |
#9106 |
Went all out today. First I hung the Camaro upside down, then I installed the trunk pull.
Sorry about the pic. Two attempts to right side it and I was done.
#9107 | |
![]() ![]() ![]() ![]() ![]() Drives: 2017 Camaro 2SS A8 Join Date: May 2019
I actually thought the upside down picture was intentional.
#9108 |
![]() ![]() ![]() ![]() Drives: 2017 Camaro 2LT RS 3.6L Join Date: Mar 2016
Hit 30,000 miles.
#9109 |
added 1/2 qt. oil
2020 ZL1LE A10.
#9110 | |
Monterey County Camaros
Drives: Stock 2016 Camaro V6 Join Date: Nov 2019
Installed my trunk pull a few months ago. Really makes it easy to close the trunk without getting fingerprints on the car.
#9111 |
#9112 |
![]() Drives: 2020 SS Join Date: Aug 2020
Drove on snow covered streets and through slushy ice, in SPORT mode. Lucky to be alive...
#9113 |
![]() Drives: 17 2SS 6sp Join Date: Jun 2020
changed engine and diff oils. took a smidge over 10 quarts (forgot to fill filter from under but did lube the o ring) of mobil one 5w 30 and about 1.5 quarts of GM recommended diff fluid. Also used new magnetic drain plugs for both from Dimple, which were INCREDIBLY MAGNETIC!!!
I saw slight indented damage (to the subframe aluminum??) caused by improper lifting done at ETD discount tire in Clifton, NJ from 2 weeks ago when I was there to have new ps4s tires put on. Needless to say, DO NOT GO THERE!!! I handed them a set of new lift pads I got from amazon and explained to them that the car should only be lifted using these and I made it absolutely clear that lifting the car from aluminum parts will cause damage. un freakin beleivable is all i have to say. Anyway, the deep pitched grown at slow speeds is gone now that it has fresh diff fluid. expecting to put it in hibernation soon :// picked up a 2020 impreza last week as a winter/daily. Yes, has literally 1/3 the hp as the SS, but man is it relaxing. so quiet so smooth i really like it |
#9114 |
![]() Drives: 2022 Alfa Romeo Giulia Quadrifoglio Join Date: Jul 2020
Finally installed my reverse LED lights.
