Old 11-02-2017, 03:10 PM   #897
ULTRAZLS1
ULTRAZLS1's Avatar
https://themustangsource.com/forums/...0-rwhp-520806/
Around 450 rwhp depending on Dyno in this thread. I’ve heard guys claim as low as 400 high as 500. Such an accurate tool them dynos are lol
Plus sc cars suffer heat soak etc
It’s all over the place
Those gt500 is hooked to over decade old drivetrain as well
Old 11-02-2017, 03:14 PM   #898
Speedofsound
Drives: 2007 Trailblazer SS
a 2007-2009 will not put down anywhere near 509whp.
a great majority of videos on youtube point to 430-445whp. Technology has come a long way in the last decade.
Speedofsound is offline   Reply With Quote
Old 11-02-2017, 03:17 PM   #899
SuperSound
SuperSound's Avatar
Drives: '17 Camaro 2SS A8
You're right, I was looking at 2010. 430's to 460's seem to be the range for non-Mustang dynos.
Just look at all the guys still using 15, 17, or 20% for driveline loss calculations. It's total uneducated crap. Take 10 or 12% numbers to these dynos from FCA, GM, and Ford and you get the variances you would expect. It's not a conspiracy as some make out, it's bad math.
Old 11-02-2017, 03:59 PM   #900
SSfriendly
Drives: Looking
Lol. A dyno from 2 years apart ? Were they in the same gear. Same gear ratio. Air pressure in tires. How tightly strapped down. Conditions of the day. Operating temp of the engine. Weight of drivetrain/efficiency. Driveshaft and half shaft weight. Fluid viscosity. Dyno calibration and or correction. The list of variables is ridiculous
VS
A controlled environment directly measured at the engine.
I’ve seen my own cars on the very next pull change by 8 rwhp for no reason. A rear wheel dyno is just a tuning tool. Most shops will do money pulls as well. Let the car sit for an hour. Fire it up cold and produce a pass about 10 rwhp higher. Was that done with every car compared ? There’s too many variables
Hennessy had the new SS at 43x rwhp as soon as it came out as well. Seen Scat pack autos in the 43x range.
Manufacturers are making everything more efficient. A huge chunk of this is an efficient drivetrain. Which = less hp losses with every new model. Not under rating of the engine.
Even compared side by side with a 15 model I’m sure it could show possibly more than 25 hp gain. But there’s 100 reasons why other than the engine being under rated
This exactly. When the dust settles, I expect the new GT to dyno slightly above the Camaro...enough to give it a comparable HP to weight ratio.
I'll reserve my opinion until I see a lot more dynos.
SSfriendly is offline   Reply With Quote
Old 11-02-2017, 05:23 PM   #901
SS 1LE
マスタング = 遅い
SS 1LE's Avatar
So how does a 435hp car dyno 370whp on a dyno and a 460hp car dyno 437whp on the same dyno and they're 20hp apart.
Because chassis dynos are nothing more than a tuning tool. Only way to legitimately compare engines exactly is on a motor dyno, which just isn’t possible. People put way to much interest in chassis dyno numbers.
Old 11-02-2017, 05:24 PM   #902
BlaqWhole
Drives: 2017 Camaro ZL1 A10
Originally Posted by SuperSound View Post
Actually the Challenger R/T is the cheapest V8 and has been for sometime. Course driving one compared to a Mustang for a few bucks more was probably underwhelming, hence why more bought the GT.
The R/T is cheaper than a base GT?
Old 11-02-2017, 05:27 PM   #903
SS 1LE
マスタング = 遅い
SS 1LE's Avatar
I too expected the new Mustang to dyno a little more hp, but less tq then the Camaro. Which is exactly what happened so far...
Old 11-02-2017, 05:33 PM   #904
SuperSound
SuperSound's Avatar
Yep it's not much. Less than $1K
Sent from my SM-G950U using Tapatalk
Old 11-02-2017, 08:08 PM   #905
L99BEN
L99BEN's Avatar
Drives: 2023 BMW M4 Competition
Looks like the 18' mustang GT gained some weight?
https://youtu.be/jXQUWVWJDU0
Curbweight: 3860 lbs
2023 BMW M4 Competition (daily)
2022 ZLE M6 (weekend toy)
2022 BMW X3m40i
Past:
2022 Tesla S Plaid
2020 Shelby GT500 sold
2019 Hellcat Redeye-traded for new GT500
2019 ZL1 A10 - sold (meh)
2019 Tesla M3P
2016 Hellcat Challenger - A8 sold but never forgotten
2016 Camaro 2SS M6
2014 Mustang GT A6
2012 Mustang GT M6 "brembo" 3.73/FBO
2012 Camaro SS L99 (Wife's)
- slow
L99BEN is offline   Reply With Quote
Old 11-02-2017, 10:37 PM   #906
ULTRAZLS1
ULTRAZLS1's Avatar
Rumor has it the LMR gt went 11.69@118.99
Its faster than the SS period. If its true and on stock tires. Could be pulling my chain
Maybe GM will do more than just bring it even with a 10 speed next year. But I doubt it.
Old 11-03-2017, 01:22 AM   #907
BlaqWhole
Yea maybe with DRs, FBO, they cut some weight, took out the sway bar, started the clock at -0.20, ran it on a downhill track with a strong tail wind, and had Jesus behind the wheel...
Old 11-03-2017, 07:28 AM   #908
ST1LE
ST1LE's Avatar
Drives: E92 BMW M3
J-Rod Built and Matt@FSP Tuned
ST1LE is offline   Reply With Quote
Old 11-03-2017, 09:32 AM   #909
SpeedIsLife
Drives: Current Camaro-less
Considering there are no bolt-on's for the 2018's yet..
I'd say we can eliminate the FBO part.
Old 11-03-2017, 09:51 AM   #910
shaffe
Drives: 21 Bronco
I haven't seen that rumor yet, so I'll stick with their GT ran 12.0
Lets keep it simple. ..
