Old 06-24-2018, 08:30 AM   #9073
Kaizer_911
Kaizer_911's Avatar
Club F1FTY
What was the resistor for when we installed the dark tail lamps? I can't remember.
Heath
The resister we used on my ride or yours when we installed the dark tail lamps was for the LED reverse upgrade.
6000 - 07/08/16 | Club F1FTY
Old 06-24-2018, 08:35 AM   #9074
KyBoy
KyBoy's Avatar
Drives: '17 2SS H50
Ok I see. I couldn't remember.
Heath
1100 - 5/26
0000 - Cancelled - 7/5
Contacted Becky - 7/1
2000 - 7/5
3000 - 7/6
3000 - 7/11 TPW 8/1
3100 - 7/18 TPW 8/1
3300 - 7/20
3400 - 7/21
4300 - 8/3
5000 - 8/5
6000 - 8/13
Old 06-24-2018, 09:53 AM   #9075
AmericanMike
AmericanMike's Avatar
Drives: 2017 Camaro SS FIFTY
The one method were you solder a resister across each LED bulb never worked for me. The bulbs appears off but my battery would die after 4 or 5 days.
I abandoned that idea until I get that ready made harness. Maybe at CamaroFest!!
AmericanMike is offline   Reply With Quote
Old 06-24-2018, 11:34 AM   #9076
Kaizer_911
Kaizer_911's Avatar
Phastek will have the harness as well others. I really like the harness from Phastek.
Old 06-24-2018, 03:46 PM   #9077
jsass
jsass's Avatar
Drives: 2017 50th anniversary
Ownwers Package
I purchased my 50th AE the beginning of March this year. Since reading about the owner's package I am supposed to receive, I went on the Chevy website and asked in chat when I might expect to get it. After having to explain what that is, providing my VIN, and telling them yes I am the original owner; two and a half months I'm still waiting. Does anyone have a better way than chat to expedite this?
jsass is offline   Reply With Quote
Old 06-24-2018, 04:12 PM   #9078
Mrfixxit7
Mrfixxit7's Avatar
Drives: FIFTY 2SS Callaway
Did you change the reverse lights to LED as well? Or just direct swap the red tails to darkened tails?
I would suggest double checking the connections and bulbs. If still hyper flashing then disconnect the battery for 10 minutes. Reconnect. And test again.
I did change the reverse light to LEDs. I used the GEN5 DYI harness. It only hyper flashes when I use the left turn signal.
What harness are you talking about?
What harness are you talking about? Is it for the reverse headlights or the taillights?
Mrfixxit7 is offline   Reply With Quote
Old 06-24-2018, 04:31 PM   #9079
Kaizer_911
Kaizer_911's Avatar
This is the harness we are all talking about. Phastek sells them as well. It is for adding LED reverse lights.
http://www.gen5diy.com/Gen6-Camaro-R...mp-LED-Harness
You only need one. Most people put it on drivers side.
Here are possible causes for your hyper left only blinker....
1) Bad connection. Verify all connections again.
2) Could have the harness plugged into wrong bulb. Verify it’s on the reverse light.
3) The new left tail light could be faulty.
4) There could be a grounding issue check wiring/connections.
5) Because it’s LED sometimes the canbus system gets confused. Have you done the battery disconnect for 10 mins?
Old 06-24-2018, 06:53 PM   #9080
RicSimonis
RicSimonis's Avatar
Drives: '17 2SS H50 Vert
Speaking of immediate throttle response...
Took the dog to the park today and let it off leash. Best run was 12.8 at 109. Several 12.9 runs and a couple over 13
Did they have any time/speed restrictions on Verts because of no roll cage? I don’t remember but I thought it was somewhere around 12.3 seconds or 115 MPH (not real sure on the speed). Just curious.
Old 06-24-2018, 08:27 PM   #9081
Martinjlm
Retired fr GM + SP Global
Martinjlm's Avatar
It never came up. Helmets were required, but no mention of roll cage for higher performing verts.
Interestingly enough, there were more verts than coupes. Two 6th gen verts, five 5th gen verts, including two triple black ZL1s, one 6th gen coupe (ran 12.3) and four 5th gen coupes.
Old 06-24-2018, 08:54 PM   #9082
RicSimonis
RicSimonis's Avatar
Finally back home and I had this waiting for me.
Didn't realize how thick it was going to be.
Thank you Chris Frech.
Old 06-24-2018, 08:58 PM   #9083
RicSimonis
RicSimonis's Avatar
That's awesome. I may have to try my hand at it someday. I'm just too chicken.
I'm sure each track have their own variations. Helmets are a must regardless.
Old 06-25-2018, 03:07 AM   #9084
RightOnTheMark
Drives: 2017 50th Anniversary Camaro SS
got the ACS Composites spoiler and ZL1 addons wicker bill installed.
RightOnTheMark is offline   Reply With Quote
Old 06-25-2018, 03:12 AM   #9085
Soleil
Soleil's Avatar
although I am not the biggest fan of the wickerbill, it looks awsome. Well done.
Soleil
Old 06-25-2018, 03:18 AM   #9086
KyBoy
KyBoy's Avatar
Drives: '17 2SS H50
You done a great job. I like that a lot.
Heath
1100 - 5/26
2000 - 7/5
3000 - 7/6
3000 - 7/11 TPW 8/1
3100 - 7/18 TPW 8/1
3300 - 7/20
3400 - 7/21
4300 - 8/3
5000 - 8/5
6000 - 8/13
