Old 11-05-2009, 07:08 PM   #90063
Xanthos
PWA Relapse
Xanthos's Avatar
Drives: Formerly-Stick
Originally Posted by ShnOmac View Post
When I had my CBR I was constantly "out ridiing" my lights...... kinda scary at times.
Gotta love nice BRIIIIIIGHT lights!
HIDs it is then! Both are budgetable, and both look good (in my opinion) though in different ways. One has the pure retro look and the other has the retro futuristic look like the new camaro does.
Just thought I'd ask some of the more experienced riders - didn't realize you rode, 'mac!
- X
2017 1LT/RS A8 Hyper Blue Metallic
Xanthos is offline
Old 11-05-2009, 07:09 PM   #90064
drivingincamaro
drivingincamaro's Avatar
Drives: 95 civic
damn guys lil problem in auto tech we took apart and rebuilt our engines and when my group tried to start it up again it didn't start our spark plug is dry and sparking, the compression is at 80 psi i have no clue what the problem is
drivingincamaro is offline
Old 11-05-2009, 07:11 PM   #90065
Xanthos
PWA Relapse
Xanthos's Avatar
80 psi is only 5.47:1, right?
Sounds really, really low to me, but I'm not a mechanic...
- X
Xanthos is offline
Old 11-05-2009, 07:13 PM   #90066
ljustin293
ljustin293's Avatar
Drives: 2010 VR CAMARO 2SS/RS
i think there may be a problem with my car..gonna take it in soon, weird noise when I push the clutch all the way in
ljustin293 is offline
Old 11-05-2009, 07:13 PM   #90067
Zabo
Gunning for Sixth
Zabo's Avatar
Drives: '03 ZR2 Blazer
You have spark
You have 80psi Per Cylinder (normal from what I know)
Dry plug troubles me..
Sure the plugs are wired correctly for the firing order?
Is it carb'd or fuel injected?
Zabo is offline
Old 11-05-2009, 07:14 PM   #90068
drivingincamaro
Drives: 95 civic
- X
well the teacher said it should be 90 (tecumseh) lev105 lawnmower engine but since its dry in the cylinder or something that would make it lose pressure,
i know everything torqued right
Old 11-05-2009, 07:14 PM   #90069
Xanthos
PWA Relapse
Xanthos's Avatar
Try spraying some starter fluid in there and see if that fires it up?
May just need a kick-start the first time...
- X
P.S. - And be sure to follow Zabos advice; he knows a lot more about this than me, lol.
Xanthos is offline
Old 11-05-2009, 07:15 PM   #90070
drivingincamaro
Drives: 95 civic
95% sure my partner stays after school and works on it
- X
ill ask my teacher if we can do that
Old 11-05-2009, 07:17 PM   #90071
ShnOmac
Drives: 2006 Silverado SS, 2009 G8 GT
- X
Im a man of many hobbies....
I sold my 600RR before I came out here... I plan on getting either a R6 or a Ducati 848 ASAP I reaaally want the Ducati but I dont know if I want to spend the extra $!
ShnOmac is offline
Old 11-05-2009, 07:18 PM   #90072
ShnOmac
What kind of noise it making?
ShnOmac is offline
Old 11-05-2009, 07:20 PM   #90073
ljustin293
ljustin293's Avatar
kinda like a popping rattle
Old 11-05-2009, 07:21 PM   #90074
Zabo
Gunning for Sixth
Zabo's Avatar
Heh.. we inadvertently did that with our o-200. We had a weird con-rod that had a bushing that was totally out of whack. So what did we do? Ground down the rod on a bench grinder and plunked it on. Put the engine together then went to start it.
Jammed inside the cylinder. Started burning up the starter so what was our solution?
WD 40 in the cylinder. Ran just fine.. turns out the piston was jammed a few mm's to the side and caused it to rub hard. If we had oiled the rings (like we were supposed to) we wouldn't have had that problem..
But I'd venture a guess to say that since it's a lawnmower engine, starter fluid in the carb. Or just try to prime it before you start it again.
Pic is of our engine. Cylinder right over my right arm is the one we WD-40'd into working.
Zabo is offline
Old 11-05-2009, 07:22 PM   #90075
ShnOmac
Does it sound like it could be the linkage making noise? If so Its probably normal...... But hell its under warranty it doesnt hurt to take it in!
ShnOmac is offline
Old 11-05-2009, 07:25 PM   #90076
Dave_O
Needs a Camaro
Dave_O's Avatar
Drives: 2007 Chevy Trailblazer
not that I know of
Ask JUNK
Junkie would probably be able to point ya to someone!
you took the words right out of my computer!
that sucks....
edit: 5 pages to go!!! i know, i read slow!!
Originally Posted by Camaro gal View Post
PQ does the seat move up far enough for you to touch the pedals? LMAO!
I LOVE GM vehicles, and particularly Chevy's, but would buy any GM vehicle if I had the $$...Hopefully, one day, soon enough, a 5th Gen CAMARO! Dave_O
Dave_O is offline
10 tags for dg, 3.4l of ram-air fury ftw!, all tags for fake palm tree, always remember to not forget, call tactical z peanut, dg's tag empire restored, hail to da hose, lol@xsoptifail, nick is a delicate flower, post if you notice this tag, potd extended to weekends, pq is still shorter than frodo, pq is the coolest.........., sugar shack, votw every friday
LOUNGE Forum camaro5 Site Related Announcements / Suggestions / Feedback / Questions 37 01-04-2009 08:29 PM
