Old 10-21-2014, 09:44 AM   #883
Camaro_Corvette
36.58625, -121.7568
Camaro_Corvette's Avatar
Drives: Team 1LE
Hell yeah! Look at the meat they put on that truck.
Old 10-21-2014, 12:10 PM   #884
FenwickHockey65
General Motors Aficionado
FenwickHockey65's Avatar
I see the front air dams are already being ripped off.
2023 GMC Canyon Elevation
Old 10-21-2014, 01:22 PM   #885
CamaroSkooter
Retarded One-Legged Owl
CamaroSkooter's Avatar
Drives: 2010 Black Camaro 2SS
Originally Posted by KMPrenger View Post
I thought extended cabs were supposed to go into production late or after this month? Could be wrong about that. Even if true, that still means a god 4 - 6 weeks before you see one on a dealer lot.
In other news...the lift kits are starting to get made for this truck:
This is the single biggest positive I have seen so far. When the last generation came out the aftermarket took FOREVER to bring any kind of lift to market for the trucks.
By the time the diesel comes out there should be plenty of options to choose from
My VIN = 2G1FK1EJ9A9105017
Build Date: 04-23-2009 according to:
http://www.compnine.com/vid.php
CamaroSkooter is offline   Reply With Quote
Old 10-21-2014, 03:22 PM   #886
Camaro_Corvette
36.58625, -121.7568
Drives: Team 1LE
Fen, any chance these trucks will shed some weight and go aluminum in the next three to four years? Try to get that fuel mileage up a little more. Or would that be a next generation thing. Not sure what the current weight is.
Old 10-21-2014, 04:33 PM   #887
CamaroSkooter
In that image, where does the silver (the rest of the cabin shell) and black (frame) metal parts rank next to the higher strength stuff?
Old 10-21-2014, 06:21 PM   #888
DGthe3
Moderator.ca
DGthe3's Avatar
Drives: 05 Grand Am GT
They come in at about 4000 lbs, give or take say 200 lbs depending on configuration and drivetrain.
Switching to an aluminum body would require more extensive retooling than a typical generational changeover. The entire body structure would need to be re-engineered because of the different properties of steel vs aluminum. And likewise, every sheet metal die would need to be replaced because even if you used identically gauged sheet stock (which you can't), and wanted the finished panels to look the same (which might not even be possible), the resultant stampings would still look different due to (among other things) springback -the tendency of a metal to return to its 'original' shape after stamping. Beyond that, if you are drastically altering the weight then the steering & suspension would need to be altered as well.
Plus building stuff out of aluminum isn't the same as doing it with steel -just with a lighter metal. Welding is harder, riveting is common, and structural adhesives are pretty much essential. So it becomes an substantially harder to have a plant building both steel and aluminum trucks (I think HD vans are built in the plant that is doing the Colorado/Canyon).
All in all ... there is no possible way that GM could change the Colorado to aluminum in a couple years without it being a generational change.
........and HE WOULD KNOW!!!!
Camaro Fest sub-forum
Old 12-18-2014, 09:16 PM   #889
KMPrenger
KMPrenger's Avatar
Well, Trifecta is going to town on these trucks...offering tunes and also working on a SC kit. Can't wait to see the results:
Old 12-18-2014, 09:57 PM   #890
Stack4
Drives: 2014 SW 2LT/RS M6
My dad works at the Wentzville plant where they build these and all the workers got a Motortrend magazine and poster today. He sees them all day long and really likes them.
Stack4 is offline   Reply With Quote
Old 12-19-2014, 07:34 AM   #891
FenwickHockey65
Just realized this thread went from people posting every day to going almost two months with nothing.
It's been a long ride.
Old 12-19-2014, 08:02 AM   #892
Camaro_Corvette
36.58625, -121.7568
Drives: Team 1LE
Can't get my wife talked into one. She wants a full size to haul absolutely nothing. A full size with a big bed to entirely ignore. A full size that never fits in a parking space. A full size that can't turn into my garage without swinging into the yard or doing a three point turn. A full size... that I just do not ****ing want.
What she has seen of the Colorado and Canyon she loves. Just not enough. Women
Old 12-19-2014, 08:58 AM   #893
DGthe3
Moderator.ca
DGthe3's Avatar
Then what does she want a full size for?
Old 12-19-2014, 09:00 AM   #894
SpeedIsLife
Drives: Current Camaro-less
Status and security most likely.
Old 12-19-2014, 09:05 AM   #895
PYROLYSIS
Remember the Charleston 9
PYROLYSIS's Avatar
Just go with the Z06. It has a full size motor under the hood.
Old 12-19-2014, 09:22 AM   #896
Blue17CamaroZL1
650HP soon to come
Blue17CamaroZL1's Avatar
Drives: 2017 Chevy Camaro ZL1
We just ordered a laser blue crew cab short bed LT last weekend.
2017 Camaro ZL1
Hyper Blue Metallic
A10, PDR, NAV, Premium floor mats
Blue17CamaroZL1 is offline   Reply With Quote
