Old 08-27-2020, 11:22 AM   #8779
bigd1276
2017 HyperBlue 2SS
bigd1276's Avatar
Drives: 2017 HyperBlue Camaro 2SS
New fender emblems.
http://www.camaro5.com/forums/showthread.php?t=30755
2010 IBM 2LT RS......Traded for.....
2012 IBM 2SS RS......Traded for.....
2017 HBM 2SS
bigd1276 is offline   Reply With Quote
Old 08-27-2020, 11:28 AM   #8780
3Putt
Drives: 2020 SS
I agree mostly but don't care and to each his own.
I'm 60 years old with a medical weed card and don't relish getting pulled over out of state. We moved from Rockford, IL and know Wisconsin cops love to pull over IL drivers. If you travel out of state, NB and KS come to mind for me as I cross them a lot, you're also a more likely target. Especially with COLORADO tags, home of legal WEED.
I'm good friends with a IL State Police motor officer, so I have some insight. Most troopers will think nice car and let it go. A small percent will see it as a reason start something. He said the hardest car to get a lock on is a black Vet with no front tag. It can piss them off so they pull you over. My buddy said that he's done it if he's having a bad day or he thinks the car was going at least 15 over.
And, it's not always if you run with the plate, it's how you display it. For instance, in NB it's illegal to use plate frames up front. Little things like that.
The same goes for window tint. Before I get mine done I'll check the laws for KS and NB. The car comes with a certain amount of tint built in, if you install the legal limit, say 35%, you are over. I was pulled over in Illinois and given a warning years and years ago.
Now all that said, if I didn't have a medical weed card and Colorado plates I might not run the front plate. And, the chances of getting pulled over for window tint is very slight. The car will do 100 mhp in the blink of an eye, for me it's about reducing the risk.
2020 2SS
3Putt is offline   Reply With Quote
Old 08-27-2020, 11:31 AM   #8781
Nothing like an SS
Faster!!!
Nothing like an SS's Avatar
Drives: 2020 Camaro 1SS 1LE
The alternative I use is the Sto'n'Sho that I often accidentally forget to replace after washing the car, or returning crom a car show, or...
"Accidentally" forget here and you'll get the ticket and pay the fine anyway......
I used the factory mount, no holes, it clamps to the grill, on and off easily if needed, but here where I live, it is on. Too expensive in this area.
Nothing like an SS is offline   Reply With Quote
Old 08-28-2020, 08:30 AM   #8782
Zaqwert6
Zaqwert6's Avatar
Drives: 2SS
Idk, it's never bothered me down here. And I kind of like the brushed silver accents here and there.
Originally Posted by turbo2ltr View Post
In my case it was easily blocked by the steering wheel, but then the wheel wasn't in a good position for me, so it's most certainly possible. I have a theory also that people in the norther regions don't have the issue either because the sun never gets high enough. I think it has to be nearly overhead for it to be an issue, but thats a guess.
Zaqwert6 is offline   Reply With Quote
Old 08-29-2020, 10:05 AM   #8783
Thill444
Drives: 2020 SS1LE Shadow Gray Metallic
RPI side skirts in satin black (to match SS1LE front splitter). Great, price super fast shipping, easy install. About an hour and only because it’s the first time jacking up my Camaro and watched a Lethal Garage video to amp sure I did it right.
Thill444 is offline   Reply With Quote
Old 08-31-2020, 02:11 PM   #8784
rallenrpd
Drives: 2018 Camaro 2SS
Very simple. I bought the harnesses from ******** that make it easy to tap in to speaker wires from the BOSE amp output. They also send the harness that cancels the interior microphones that are supposed to get rid of exterior sounds. The wiring harness for the sub has to be connected to the front speaker wires from the new ******** wiring harness, positive from the battery and a ground. It does not require any special instruments or gadgets. When you turn the car on, the sub comes on automatically from the speaker inputs. When you turn the car off, it turns off. No need to connect a "remote on" wire. I used velcro and it stuck very well to the carpet. It could go anywhere and I will probably move it at some point. I just wanted to get it installed so I could see if I wanted to keep it. Will definitely keep it!
rallenrpd is offline   Reply With Quote
Old 08-31-2020, 02:37 PM   #8785
robertd33
Drives: 2018 2ss redline
lift pads, $38.99
https://www.amazon.com/gp/product/B083TSQMV4
robertd33 is offline   Reply With Quote
Old 08-31-2020, 03:23 PM   #8786
Rhobz
Rhobz's Avatar
Drives: 2018 Camaro 1SS 1LE
Those look great. So, are they Satin Black or Flat Black? The website lists the option as "Satin/Flat Black" but those are not the same thing.
Well, more importantly, how well do they match the 1LE front splitter and spoiler?
I like the style a lot but if they don't match almost perfectly, I know it will bug me enough to make it not worth the purchase.
Rhobz is offline   Reply With Quote
Old 08-31-2020, 03:53 PM   #8787
turbo2ltr
turbo2ltr's Avatar
Drives: 2018 1SS 1LE
The side skirts look good, but I feel like I'd constantly be kicking them or accidentally stepping on them
2018 1SS 1LE Hyper Blue
turbo2ltr is offline   Reply With Quote
Old 08-31-2020, 04:34 PM   #8788
NYblack1le
x2
NYblack1le is offline   Reply With Quote
Old 08-31-2020, 05:45 PM   #8789
Well you probably wouldn't, but your passenger(s)...
Old 09-01-2020, 12:06 AM   #8790
GroundhogSS
GroundhogSS's Avatar
Finally replaced the cabin air filter. After 4 years and 52K miles, I was a little late. Took less than 10 minutes. I watched one of the videos that has been posted on the forum.
Richard
Delivered: 08/15/2016
#TeamBeckyD
Old 09-01-2020, 05:38 AM   #8791
jamala00
jamala00's Avatar
Drives: 2016 Camaro 2SS Hyper Blue Metallic
Originally Posted by bigd1276 View Post
New fender emblems.
Love the heritage badges. I put them on my car (same color car) a couple months ago too. They really look nice on the Hyper Blue.
jamala00 is offline   Reply With Quote
Old 09-01-2020, 05:41 PM   #8792
ItsChristianInHD
ItsChristianInHD's Avatar
Drives: 2017 Camaro 2LT RS 3.6L
Still waiting for my car.
ItsChristianInHD is offline   Reply With Quote
