#8667 | |
![]() Drives: 2017 Camaro Fifty 2SS Join Date: Sep 2015
![]() Quote:
#8668 |
#8669 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: '17 2SS H50 Join Date: Mar 2016
Nice choice, I would add borla secondary cat delete and mid pipes. You won't be disappointed. Heath
1100 - 5/26 0000 - Cancelled - 7/5 Contacted Becky - 7/1 2000 - 7/5 3000 - 7/6 3000 - 7/11 TPW 8/1 3100 - 7/18 TPW 8/1 3300 - 7/20 3400 - 7/21 Built - 8/2 - PS 1,182/1 of 699US 4300 - 8/3 5000 - 8/5 6000 - 8/13 |
#8670 |
![]() Drives: FIFTY 2SS Callaway Join Date: Sep 2017
I have been working on upgrading my suspension from FE3 to FE4 as well as upgrading to ZL1 brakes.
Here is a list of everything I changed out: Front -sway bars -front links -strut mounts -springs -front knuckle and hub Rear -sway bar -control arms -trailing links -rear knuckles and hub -springs MRC -front MRC struts -rear MRC shocks -MRC controller (with a ZL1) *I think the MRC shocks and struts are the same but my SS had different Part numbers than the ZL1 so I changed them out. Brakes -front & rear calipers, discs, backing plates, hoses I wanted it to look as original as possible so I sent my calipers off to get powder coated. Kevin at TPH Coatings (on the forum) did a great job. 6 piston FIFTY calipers: |
#8671 | |
![]() When will the swap be completed? You've just raised the performance of the car a lot with these changes ![]()
It's been fun, done with GM.
2018 Camaro ZL1 (SOLD) - Blown Airbags 2017 Camaro SS F1FTY Member Journal (SOLD) - Bad Motor |
#8672 | |
I hope to have everything swapped out and installed by the end of the week. I can't wait to drive it. The new knuckles are not required (everything will fit) they just had a different part number between the FE3 and FE4. maybe the bushing material is different between the two. Most of the parts look the same between the FE3 and FE4 (some of the links had the same part numbers stamped in them and then the FE4 parts had a sticker with a different part number put on over where it was stamped. |
#8673 | |
Heath
#8674 |
![]() Drives: 2017 Camaro SS 50th Join Date: Jun 2017
I had something come in the mail today, almost a year later I bought the car.
Kind of a cool box, so I don't want to open it just yet.. Does anyone know what it is? |
#8675 | |
Heath
#8676 |
#8677 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2017 2SS 50th Anniversary Edition Join Date: Aug 2011
Can’t say I know anything off the top of my head to cause it. Have you done a driveability test with chassis ears at the dealership? Sent from my iPhone using Tapatalk
1100 - 04/29/16 | 2000 - 05/03/16 3000 - 05/04/16 | TPW 6/6 - 05/09/16 3100 - 05/25/16 | 3300 - 05/28/16 3400 - 05/31/16 | 3800 - 06/14/16, #125 Built! 4200 - 06/29/16 | 5000 - 06/29/16 6000 - 07/08/16 | Club F1FTY |
#8678 | |
Awesome! Congrats and welcome to Club F1FTY! I only know of one person on Facebook in the 50th group that I help admin who managed to get the certificate has a second owner. Sent from my iPhone using Tapatalk
#8679 | |
Awesome journey! Curious how different it feels once done. And those calipers looks great!!!! Sent from my iPhone using Tapatalk
#8680 | |
Club F1FTY
@V8RWD here ya go!!! It is the 50th portfolio sent to all 50th owners. See below for pics. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() My original set of cards had misprint. They sent out a second set. And I got them mounted. ![]() Sent from my iPhone using Tapatalk
Tags |
50th, club fifty, f1fty, fifty |
