View Poll Results: Who has experienced an oil pump failure?
2016 or earlier 25 14.88%
2017 57 33.93%
2018 77 45.83%
2019 4 2.38%
2020 4 2.38%
2021 1 0.60%
Voters: 168. You may not vote on this poll
Old 10-29-2021, 12:40 PM   #855
Mark R
Drives: 2018 ZL-1
Originally Posted by Camaro18&67 View Post
new member, first post and what a post to respond too.
Count me as part of the group with a destroyed oil pump at 13K miles.
No problems whatsoever, brought in for an oil change and after the oil change the oil pressure was non existent......So for a week they tested and tested and finally determined the oil pump wasn't working.
Pull the engine and what do you know, the words they used was the "oil pump was destroyed in pieces."
2018 Camaro ZL1
Build Date 5/1/2018
That is a bummer. I feel the walls closing in on me, as I have build date of 5/2018, and 14,000 miles on mine.
New engine coming, paid for by GM?
Old 10-29-2021, 01:35 PM   #856
TLSTWIN
Romans10:9-13
TLSTWIN's Avatar
Drives: /\yes, this is me/\
2018 Camaro ZL1
Build Date 5/1/2018
come on guys, I dont want to hear this. I have an 02/2018 with almost 13,000 miles no issues, so far.
TLSTWIN is offline   Reply With Quote
Old 10-29-2021, 02:55 PM   #857
ZX-10R
ZX-10R's Avatar
Drives: 2019 ZL1 Riverside
Just a matter of time, the factory pot metal gear is prone to failure. See video above 45 seconds in
If I didn't have a six year warranty and was planning to keep the car I would upgrade the pump and not roll the dice
ZX-10R is offline   Reply With Quote
Old 10-29-2021, 03:00 PM   #858
TLSTWIN
Romans10:9-13
TLSTWIN's Avatar
I also have the extended warranty just for this
Old 10-29-2021, 05:12 PM   #859
Mark R
Drives: 2018 ZL-1
I'm probably going to get the Katech pump and have it installed at the dealer. I have a warranty, but if the pump were to let go far from home, it would be a massive PITA.
My dealer quoted me $2200 to change it out, plus the cost of the pump.
Old 10-29-2021, 05:20 PM   #860
Wuiquen
Wuiquen's Avatar
Drives: 2018 Hot Red ZL1
I guess for those of you that bought the car used, please check with your service department to check any warranty work done before your current ownership.
I was planning to pay to have the oil pump replace because I would rather not get stranded and have to get towed in the middle of nowhere.
Luckily, i had my cat back replaced under warranty so i was able to see the warranty work print out and see that oil pump as replaced before i got my car.
Just saying this to prevent any owner paying for something that could have been done. No the Carfax didn't show anything about this being done. I suppose i should have know something was done with the engine when there is torque marks all over the place to include the exhaust manifold hear shield botls. But what did i know?
Sent from my moto g(7) power using Tapatalk
Old 10-31-2021, 12:43 PM   #861
Camaro18&67
Drives: 2018 Chevrolet Camaro ZL1
In my case the oil pump decided that it would blow up at the dealership while in for an oil change, so no new motor for me.
This is what they found and I am quoting.
"The pump to the filter, minimal contamination right after the pump, the rest of the port is clean. Flushed out oil port inside block from pump to filer (with oil pan off). Removed sump from oil pan and thoroughly cleaned out debris, and cleaned out oil pan. Reassembled oil pan. Installed new oil pump and reassembled."
This was all part of the drive train standard warranty as I do not have an extended warranty. According to the dealership this was a $3245.35 oil pump replacement cost.
I guess I count myself lucky that it happened at the dealership but again the pump that they went in with was a GM OEM pump, so now I have to wonder if all the problems have been resolved with these newer pumps.
Camaro18&67 is offline   Reply With Quote
Old 11-01-2021, 12:19 AM   #862
ZX-10R
ZX-10R's Avatar
I'm not convinced it has (Katech isn't either, granted they have a vested interest in selling pumps but I doubt they would lie about it) - the gear is the weak point, if it's been upgraded it's definitely not billet
Old 11-01-2021, 04:11 AM   #863
Z OH 6
Drives: 2024 CT5-V Blackwing
I'm not convinced either way. I will say if it hasn't been fixed, seems like a lot more 2019 and newer cars would be posting about their failures and we're just not seeing that so at this point, I'm more inclined to believe it has been fixed but certainly wish I had more definitive proof.
Old 11-01-2021, 04:27 AM   #864
avalonandl
avalonandl's Avatar
Drives: 2019 ZL-1
Is the LT4 oil pump that different than the LT1 pump? I had a 17 SS for 4 years 32k miles not ONE issue.....
Old 11-01-2021, 04:48 AM   #865
Tricksta
Tricksta's Avatar
Drives: 2018 ZL1 A10
I believe the oil pumps are the same, just that they are assembled at different plants.. The LT1 was made at Tonawanda and LT4 at Bowling green... Bad Batch of oil pumps to bowling green
Modifications
GM Dark Tail Lights / 3rd Brake Light & Reflectors | LED Reverse Lights | Diode Dynamics Side Markers | Borla "ATAK" Cat Back Exhaust
Tricksta is offline   Reply With Quote
Old 11-01-2021, 10:51 AM   #866
Mark R
Drives: 2018 ZL-1
I just ordered the pump from Katech, after calling to check availability.
I'll have it installed at the dealer pretty soon after getting it. I'm tired of worrying about getting stranded with a destroyed engine, even though I have a warranty.
Old 11-02-2021, 10:25 AM   #867
pauly1119
pauly1119's Avatar
Drives: 2018 ZLE
Would your warranty stay valid? Even if the dealer installs a after market part you can void it.
pauly1119 is offline   Reply With Quote
Old 11-02-2021, 02:48 PM   #868
Mark R
Drives: 2018 ZL-1
I'm not going to worry about it. The oil pump is literally the only weak link in this entire car. I'm going to fix it proactively, rather than wait for disaster.
