Old 07-24-2018, 07:29 PM   #855
big dave
Drives: 2017 ZL1
Originally Posted by Speedy1975 View Post
This isn't too inspiring, tires, pulley, bolt ons reasonable DA - 10.78 @126
I thought maybe it was a manual, but no, it's an A10.
https://www.camaro6.com/forums/showp...postcount=1495
Tires used on the pass: MT ET Street R 305/45R17
Performance Mods (if any): Lower Pulley, Headers, Cat Delete, Exhaust, CI, PT, Meth, and tires.
Category submitted for: Please List the Category or Category # (8) Camaro 2017+ LT4 ZL1 Bolt On's No Internal Mod's (Stock Displacement)
R/T........... .376
60'............. 1.638
330'........... 4.560
660'........... 6.956
660’ mph... 104.87
1000'.......... 9.026
1320'.......... 10.786
1320’ mph… 126.31
Name of the track: Woodburn Drag Strip
Date of pass: 7.21.18
Weather conditions: Include Density Altitude if known. (Optional not required) DA 649
Something is definitely going on. The time isn't too far off in my opinion, but he should definitely be seeing more than 21 mph after the 1/8th. The DA wasn't too bad, but I think he'll see at least another .3 in great air, once he gets the tune sorted out.
'17 ZL1 10.99@129 stock. 4225# raceweight. Best 60'- 1.66 on factory tires. 10.48@132 E50, intake and tune. 4270 lbs
https://youtu.be/EyHtdH9XOkY
https://youtu.be/Lcu41obbTf8
'13 ZL1 BRM A6. 11.591 @ 119.2 factory stock with a 1.68 60'! Best stock mph 121.8. 11.29 @ 123 RotoFab, drag radials and skinnies. 4360# raceweight.
http://youtu.be/yggIA3C_kkA 2014... back to stock
http://youtu.be/spQLaTWbThs 2013... stock & RotoFab
big dave is offline   Reply With Quote
Old 07-25-2018, 06:06 AM   #856
newmoon
newmoon's Avatar
Drives: 2019 GT350
Why is this time so far off? Lets rule out the questionable hero runs for the A10 and the average is 11:20s - 11:50s, this puts him anywhere from a half second or more improvement over stock. Considering his mods I would think that is right in line with the improvements to be expected. What is his RWHP?
2019 GT350 RR
2013 Boss Mustang
2012 SRT Challenger 392 auto 12:40s 112 stock
2012 Ford Mustang 5.0. Brembo, 3:73s
2010 SS, LS3, Cammed, LTs, 12:20s
2004 Redfire Cobra, Pullied & Tuned
1986 GT, Ed Curtis 347ci, 11:20s motor. 10:30s 100-hp shot
newmoon is offline   Reply With Quote
Old 07-25-2018, 07:52 AM   #857
Fraxum
Fraxum's Avatar
Nailed it.
Old 07-25-2018, 08:54 AM   #858
IneedAZ
IneedAZ's Avatar
Unless you compare his similar mods to that of the GM ZL1 drag test car running 10.0 @ 138 He is running meth vs the test car running 110 octane. Seems like a wash to me.
Old 07-25-2018, 04:08 PM   #859
big dave
Drives: 2017 ZL1
Like I said, I don't think his time is too far off...I do question the mph though. 104 mph in the 1/8 is ok, but I think he should be somewhere in the high 120s to low 130s with those mods. It doesn't make sense that he only picks up a little over 21 mph after the 1/8th
Old 07-25-2018, 04:22 PM   #860
Stefano
Stefano's Avatar
Drives: 6th Gen NicKey Camaro & others.
Heat kills these ZL1s and with high IATs they will pull timing and nose over on the big end.
Stefano is offline   Reply With Quote
Old 07-25-2018, 05:28 PM   #861
kttxz06
kttxz06's Avatar
Drives: '18 Zl1. '18 GT350.
U ain't lying man. Can't even get in back to back pulls in these things down here in Houston. It's a dead stick.
There's only 2 people I trust. 1 of them is me, the other's not you. 2018 Zl1. 1199 RWHP/931 TQ.
kttxz06 is offline   Reply With Quote
Old 07-25-2018, 05:29 PM   #862
Blackdevil77
Blackdevil77's Avatar
Drives: 2008 Pontiac G8 GT, Shelby GT500
I'm sorry but that tiny a$$ blower was a mistake
Blackdevil77 is offline   Reply With Quote
Old 07-26-2018, 07:26 AM   #863
Fraxum
Fraxum's Avatar
Another nailed it. If I end up keeping this car I might go Procharger. Problem solved and it's a little easier on the drive train at sane power levels.
Old 07-26-2018, 08:30 AM   #864
17CamaroZL1
Life's Short, Live Fast!
17CamaroZL1's Avatar
You can't discount any time on the list, because even the best driver or the fastest car can run a time anywhere on that list, depending on the conditions and experience with the car. Ask me how I know. That's why you're actually better off comparing these "hero" runs as you call them, because there is going to be fewer variables in those times. You know they were made in the best conditions possible and the driver more than likely got all that could be gotten out of it at that time. The further down the list you go, the more likely it is that something held the car back from it's TRUE potential, whether it be temperature, elevation, track conditions, car setup, driver experience/ability, or any combination of those.
I totally agree. Even though he got a good time out of it, I think there is some time that could and would be shaved off, if the car pulled like it should, and I'd think the car should 60 better. Maybe torque management hasn't been removed to let it come out of the hole as hard as it should. Idk. It's plain as day though, that the car isn't pulling the back half and likely even losing some in the front half, even though the 1/8 mph looks good. Even at stock power levels, he should've ran around 130 in the 1/4 with his 1/8 mph. So I'd think the car should run between 132 and 135, depending on the air temp. Maybe better.
12/26/2016 Ordered!
2/8/2017 Built!!
3/2/2017 Brought Home!!!
Old 07-30-2018, 12:50 PM   #865
IneedAZ
IneedAZ's Avatar
Most people seem to be 550rwhp range stock yet 10.9 is the best on the fast list, and most are in the 11.2-11.6 range. I saw a post from a Bolt on SS at 490rwhp run 10.85, so why are our bolt on guys not doing much better with more power. I know the TQ management is killing 60ft times, but with some of the bolt on guys that have posted i assume are tuned and still only running 10.7 range.
Old 07-30-2018, 02:56 PM   #866
17CamaroZL1
Maybe they didn't remove TM in their tune? Nonexistent track prep where they ran? They should definitely have better 60s than 1.6s. Big Dave and myself have both managed high 1.6s bone stock on the factory tires, so something's not right. If it is TM, then you'll see a bigger gain than what you'd see just from a traction improvement. So instead of the typical 1.5-2× lower 1/4 ET from better grip, you're likely to see 3-4x or more whatever the 60' gain is, because TM is active for more than just 60'. It may take a trans tune as well to get the true potential out of these cars.
12/26/2016 Ordered!
2/8/2017 Built!!
Old 08-06-2018, 04:33 PM   #867
Speedy1975
FASTER!
Am I the only person that sees like 65 pages of this thread but seem to be stuck on page 62?
Old 08-06-2018, 04:38 PM   #868
Can'tHave2MuchHP
Can'tHave2MuchHP's Avatar
Drives: Fast
You're not alone. Mine is the same way. Not sure what's up...
