Old 01-12-2023, 11:29 AM   #8653
genxer
Drives: multiple cars
What are Honda's mild hybrids like? on what cars? I had the impression Ram's(Dodge's) were just next gen battery-starter/generators with a higher volt battery. How is that a big difference versus a new vehicle with start-stop?
genxer is offline   Reply With Quote
Old 01-12-2023, 06:00 PM   #8654
Martinjlm
Retired fr GM + SP Global
Martinjlm's Avatar
This is how we defined hybrids when I was at GM. Same definitions hold since I’ve been with IHS Markit / S&P Global:
  • STOP / START: Engine turns off when vehicle comes to a stop. Restarts when driver lifts foot off brake. Provides no tractive effort or assist. Operates off separate 12V battery, usually AGM, or lithium ion. Costs the automaker about $2-300 per vehicle.
  • MILD HYBRID: Usually powered by a 48V battery. Similar to Stop/Start except they can provide engine-off launch and propel the vehicle for very short distance at very low speeds. Ram eTorque system is a 48V mild hybrid. It operates belt driven off of the accessory belt. Can provide torque assistance to the ICE, allowing the ICE to work less, saving fuel. Honda’s Integrated Motor Assist (IMA) hybrid system operates at higher voltage (108V I think?) and has an electric motor positioned between the engine and transmission. It provides some tractive effort at launch. After launch, the motor acts as a generator, putting energy back into the battery. 48V mild hybrids typically cost the automaker $1,200-3,000 per vehicle. Typically use a 48V battery, and less than 1kWh storage battery.
  • FULL HYBRID: What most people think of when they hear “hybrid”. There are several different types of Full Hybrid. The rarest is a Series Hybrid. It runs on either petroleum fuel or electricity, but not both at the same time. When it’s running on electricity, the ICE acts as a generator replenishing the battery. Parallel Hybrids can run on ICE, electricity, or blend both. Prius. Operating voltage varies wildly by automaker. Storage battery is typically right around 1.5 - 2 kWh. Costs automakers $5-12,000 per vehicle.
  • PLUG-IN HYBRID: Pretty much a Full Hybrid but can be plugged in to receive and store energy from the grid. Usually have larger electric motors than Full Hybrids and as a result they are capable of driving engine-off at higher speeds and for longer distances than Full Hybrids. They also are able to provide significant torque and power assists to the ICE, allowing for unexpected performance. Camaros should not line up next to Porsche Panamera 4S E-Hybrids unless you have a lot of faith in your tune. Typical 0-60 is 3.5s. Batteries are typically 12-20 kWh. Costs automakers $15-30,000 per vehicle, depending on number of motors and battery size.
  • EREV: Extended Range Electric Vehicle. Operates as an electric vehicle until it can’t. Chevrolet Volt and Fisker Karma are the two best examples. They have an ICE, but the ICE is typically only used as a generator to replenish the battery. Since these vehicles plug in, they can go for months without the ICE ever turning on. The biggest differences between PHEVs and EREVs is that for PHEVs the top EV speed is typically electronically limited at anywhere from 35 mph to in some cases 70 - 80 mph. Above the EV speed limit, the ICE engages and splits duty with the electric motors just like a Full Hybrid. An EREV can drive its entire speed range on electric only. Batteries are typically 15-20 kWh. Costs automakers $15-30,000 depending on number of motors and battery size.
Old 01-12-2023, 11:48 PM   #8655
genxer
I had been mixing up parallel and series hybrids, oops.
I recall reading the Ram's pentastar is more costly than the hemi.
How much extra cost is the Silverado turbo 4 8speed vs the 4.3 or 5.3 6speeds?
Thank you kindly for the write up, Mr. Martin.
Old 01-13-2023, 08:41 AM   #8656
snizzle
Recalled user
snizzle's Avatar
Drives: '12 Camaro SS, '18 Colorado Z71
Speaking of hybrids, the rotary engine is back
https://www.autoblog.com/2023/01/13/...y-engine-phev/
2012 2SS 45th AE LS3 M6
Borla ATAK Catback
Kooks Stepped LT Headers
CAI Intake
Hexvents
VMAX CNC Ported Throttle Body
RX Catch Can
Hurst Short Throw Shifter
Pfadt ZL-Spec Stage 3 Suspension
Forgestar F14
Tuned by Frost
snizzle is offline   Reply With Quote
Old 01-13-2023, 10:09 AM   #8657
Martinjlm
Martinjlm's Avatar
Yup. We’re not certain if this will be made available in US or not. It will be available in Asia and Europe. Probably in US, but not confirmed. Rotary sets up well for use in EREV applications because they package better than traditional ICE and operating as a generator pretty much masks the problems that killed it first time around (high fuel and oil consumption). Operating as a generator allows for having it run in a very narrow sweet spot instead of the whole rpm range.
[*]EREV: Extended Range Electric Vehicle. Operates as an electric vehicle until it can’t. Chevrolet Volt and Fisker Karma are the two best examples. They have an ICE, but the ICE is typically only used as a generator to replenish the battery. Since these vehicles plug in, they can go for months without the ICE ever turning on. The biggest differences between PHEVs and EREVs is that for PHEVs the top EV speed is typically electronically limited at anywhere from 35 mph to in some cases 70 - 80 mph. Above the EV speed limit, the ICE engages and splits duty with the electric motors just like a Full Hybrid. An EREV can drive its entire speed range on electric only. Batteries are typically 15-20 kWh. Costs automakers $15-30,000 depending on number of motors and battery size.[/LIST]
Old 01-13-2023, 11:26 AM   #8658
snizzle
Recalled user
snizzle's Avatar
I'll be interested in the use case since I invested in the last one previously. But yes, had to top it off quite a bit as well as fuel her up, but boy was she fun to drive. Mazda always has a well sorted chassis.
Borla ATAK Catback
CAI Intake
Hexvents
RX Catch Can
Forgestar F14
Tuned by Frost
Old 01-19-2023, 03:24 PM   #8659
FenwickHockey65
General Motors Aficionado
FenwickHockey65's Avatar
Hopefully GM has something in the works for this segment. There's always the possibility they won't bother with an ICE model and will do an EV.
Sounds like this is indeed in the works.
2023 GMC Canyon Elevation
Old 01-19-2023, 04:36 PM   #8660
HartfordRacingCaptain
HartfordRacingCaptain's Avatar
Drives: 2017 Camaro 1SS, 2023 Colorado Z71
Do the whispers you have heard mention either ICE or EV?
2017 1SS, Summit White, Black 2SS Interior, MRC, NPP
2023 Colorado Z71, Nitro Yellow
HartfordRacingCaptain is offline   Reply With Quote
Old 01-19-2023, 05:27 PM   #8661
FenwickHockey65
EV, 2 door, 4-4.5 foot bed.
Old 01-19-2023, 08:58 PM   #8662
Call that an Ev Camino
Old 01-20-2023, 01:55 PM   #8663
90503
90503's Avatar
Drives: 2011 2SS/RS LS3
...Maybe a "Nova"?...Is it this one ...?
https://insideevs.com/news/632266/gm...type-to-media/
"Automaker has built a two-door electric pickup prototype with a 4- to 4.5-foot-long bed but hasn't released any photos of it yet."
"The automaker announced it is considering an all-electric two-door pickup smaller than the Ford Maverick and the Hyundai Santa Cruz. Envisioned as part of the carmaker's lineup of affordable EVs priced under $30,000, the small truck would have a 4- to 4.5-foot-long (1.2-1.37-meter-long) bed and low roofline.
The automaker has shown a prototype of the mini truck to reporters at its affordable EV design studio in Warren, Michigan. Automotive News has seen the vehicle and describes it as "futuristic and sporty." The name, brand or production timeline for the small truck are still being kept under wraps. That said, Chevrolet looks like the ideal brand for such a model."
Old 01-21-2023, 07:56 PM   #8664
FenwickHockey65
https://brochures.cadillac.com/2024/lyriq/
2024 Lyriq details
Old 01-22-2023, 09:13 AM   #8665
FenwickHockey65
https://gmauthority.com/blog/2023/01...el-year-debut/
C9 Corvette reportedly scheduled for 2028 launch as a 2029 model.
Old 01-22-2023, 09:48 AM   #8666
Martinjlm
Martinjlm's Avatar
Interesting article and it actual makes a lot of sense. The one thing that bothers me though is they say the C8 rides on the Y2 platform.
Under the skin, it will ride on a revised variant of the GM Y2 platform that underpins the current C8 Corvette,
Y2 is the platform that C7 was built on. I think the C8 platform name is ZERV.
fenwickhockey65, gm questions, questions
